View unanswered posts | View active topics It is currently Sun Aug 25, 2019 2:30 pm
Reply to topic  [ 12 posts ]
 Small FPGA CPU
Here's my small FPGA CPU called X18-32. I've used it in a few commercial products as an embedded controller inside an FPGA.
It was inspired by Bowman's J1 CPU, but I decided I didn't really like the stack architecture, mainly because of all the extra shuffling that's needed to get data where it needs to be. The X18 CPU has 16 registers, each of which can be used as a pointer, and you can load and store in a single instruction with either post increment, pre decrement or a small (4 bit) offset. This makes it very easy to operate on small structures (such as peripheral registers), or arrays of data.
Sun Nov 29, 2015 9:31 am
Arlet:
Read through your readme file and had a read through the code. Looks well thought out, and as usual, concisely and elegantly written. Have you built an assembler, and if not, what tool(s) do you use to program it for your applications?
Sun Nov 29, 2015 1:56 pm
I have a very simple assembler written in C. It does the very minimum to write some programs I needed. If I get a chance to clean it up a bit, I'll add it to the github repository.
Sun Nov 29, 2015 2:01 pm
Arlet, good job. How fast does it run?
The source refers to a file called 'code.v'. Is that where you put the instructions to execute? What does it look like?
Thanks
Tue Dec 01, 2015 4:39 am
Yes, the code.v is the block RAM initialization, using a bunch of defparam statements like this:
defparam code_data.INIT_05=256'h41850000cffd410141850000cff6e2014043c027f001f03ac0301404001ca040;
It runs 100 MHz on a Spartan6 without extra effort.
Here's some source code. You can see how I just allocate some registers (r8, r9, r10) to fixed locations. R8 points to the peripherals, and with the 4 bit offset, I can reach all peripherals in this project.
reset:
        jmp     init
const:
        .long   0x80000000              // start of sdram
init:   mov     r4, #0x40
        mov     r8, #0x200              // r8 = peripherals
        mov     r9, #const              //
        mov     r10, (r9)               // get sdram start
        mov     r2, #0x1                //
        lsl     r2, #8                  // r2 = 1 << 20
fill:
        mov     (r10)+, r2              //
        sub     r2, #1                  //
        bne     fill                    //
mainloop:
        call    wait_trigger1           // wait for trigger signal
        mov     r0, #1                  //
        mov     (r8+4), r0              // start recording
        call    wait_record1            // wait for record to start
        call    wait_record0            // wait for record to stop
        mov     r11, (r8+4)             // get maximum pixel count
        mov     r0, r11                 //
        call    putlong                 // send to uart
        call    crlf                    //
Tue Dec 01, 2015 5:50 am
Thanks. That's a good-looking instruction set.
Wed Dec 02, 2015 6:34 am
Arlet, could you clarify - in your github readme you state:
smode/dmode can be one of the following:
  00 direct register load/store ("mov reg, reg" not supported)
In your example code above, you do just that - mov r0,r11
Mon Dec 07, 2015 1:56 am
I noticed the apparent lack of reg-to-reg move, too, but eventually I figured it out (I think). The instruction format called "Move" lets you encode lots of stuff, but as noted the encoding for a reg-to-reg move is not supported. Dunno why that wasn't feasible. However, the instruction format called "ALU" lets you specify an "operation" between registers, and operation 1010 is move. I guess it was just easier to support that than to support the other way??
Overall, this machine's instruction encoding seems a bit sparse, and I suppose from one point of view it might be considered somewhat inefficient. But, paradoxically, I find it charming! And it's hard to argue with an effortless 100 MHz. :)
-- Jeff
Mon Dec 07, 2015 3:34 am
Indeed, the ALU has a move operation because the only path to the register file is through the ALU, which helps to keep the design fast. The move operation is used for immediate moves to registers, for instance.
The separate "move" instruction is intended for load/store, and I figured that any effort to get the reg-reg variant working would be wasted, since there's already a reg-reg move through the ALU operations.
Mon Dec 07, 2015 6:14 am
The hardest part of a new CPU core design is making choices, especially at the beginning when you're starting at a blank piece of paper.
Mon Dec 07, 2015 7:58 am
Nice work ! How many logic cells ?
Wed Dec 09, 2015 2:51 am
Targeting Spartan 6:
Slice Logic Utilization:
  Number of Slice Registers:                   179 out of  11,440    1%
    Number used as Flip Flops:                 176
    Number used as Latches:                      3
    Number used as Latch-thrus:                  0
    Number used as AND/OR logics:                0
  Number of Slice LUTs:                        663 out of   5,720   11%
    Number used as logic:                      609 out of   5,720   10%
      Number using O6 output only:             534
      Number using O5 output only:               9
      Number using O5 and O6:                   66
      Number used as ROM:                        0
    Number used as Memory:                      52 out of   1,440    3%
      Number used as Dual Port RAM:             46
        Number using O6 output only:            22
        Number using O5 output only:             6
        Number using O5 and O6:                 18
      Number used as Single Port RAM:            6
        Number using O5 output only:             0
        Number using O5 and O6:                  4
Without the 32 bit barrel shifter it drops to 387 LUTs.
Wed Dec 09, 2015 4:42 am
