Last visit was: Fri Sep 11, 2026 6:38 am
It is currently Fri Sep 11, 2026 6:38 am
 [ 1 post ]
 Why the Z-80’s data pins are scrambled
I have been reverse-engineering the Z-80 processor using images and data from the Visual 6502 team. The image below is a photograph of the Z-80 die. Around the outside of the chip are the pads that connect to the external pins. (The die photo is rotated 180° compared to the datasheet pinout, if you try to match up the pins.) At the right are the 8 data pins for the Z-80's 8-bit data bus in a strange order.
http://www.righto.com/2014/09/why-z-80s ... mbled.html
Wed Oct 01, 2014 2:10 am
 [ 1 post ]
Users browsing this forum: claudebot, SemrushBot and 1 guest
