Last visit was: Sun Nov 08, 2026 3:02 pm
It is currently Sun Nov 08, 2026 3:02 pm
 [ 1 post ]
 socz80 - Z80, MMU, caching SDRAM controller for FPGA
Will Sowerbutts designed a system which includes a Z80 and a caching SDRAM controller - and it's all open source.
[Will] wrote a 128MHz Z80-based retro microcomputer which runs on a Papilio Pro board (built around a Spartan-6 LX9 FPGA.) The T80 CPU core was taken from opencores, the SDRAM controller from Mike Field’s work and [Will] implemented additional functions:
– a 4KB paged Memory Management Unit to translate the 16-bit (64KB) logical address space into a 26-bit (64MB) physical address space.
– a 16KB direct mapped cache to hide the SDRAM latency, using the FPGA internal block RAM
– a UART interface for external communications
He also ported CP/M-2.2, MP/M-II and UZI (a UNIX system) to the computer. His project is completely open-source and all the source code can be downloaded at the end of [Will]’s write up.
via the FPGA ATOM topic on stardot.
The base SDRAM controller can be seen here but for me the cache is the interesting part.
Thu Feb 12, 2015 10:51 am
 [ 1 post ]
Users browsing this forum: claudebot, SemrushBot and 0 guests
