View unanswered posts | View active topics It is currently Mon Apr 29, 2024 12:14 pm
Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 8 bit counter for breadboard computer
prpplague wrote:
joanlluch wrote:
Hi prpplague,
Thank you very much for your info and pointers. That's exactly what I needed to know.
glad to help when i can! let me know how it works out for you! try documenting your project at hackaday.io !
Dave
Hi Dave,
Actually, I have already thread on the "projects" section about something I'm currently at: http://anycpu.org/forum/viewtopic.php?f=23&t=583&start=75 I'm documenting it all here, but I may post something in hackaday,io too as soon as I have photos to show.
I have already made my first steps with the wincpul tool and at first glance it looks easy enough. But I have difficulties at finding the ATF16V8 or equivalent on Eagle CAD. I want to design a PCB for it, but I got stuck because I can't find the part in the library. Any ideas?
Thanks.
Fri Apr 26, 2019 6:33 pm
joanlluch wrote:
prpplague wrote:
joanlluch wrote:
Hi prpplague,
Dave
Hi Dave,
Thanks.
i created an eagle symbol and footprint for my hex decoder project - https://hackaday.io/project/163274-4-bi ... ex-decoder
i've add the 16v8.lbr to the files on that page. you can download it from there!
Fri Apr 26, 2019 7:06 pm
Next question is could you squeeze 2 or even 4 one byte flip flops into one chip? Basically a register file with W/R, OE and 1-2 bits of address.
Fri Apr 26, 2019 7:21 pm
i don't have a good answer for you... but based on my experience, it seems very possible...
Fri Apr 26, 2019 7:39 pm
i did a quick test on my bench and it seems completely doable....
Fri Apr 26, 2019 8:25 pm
Sounds like 74LS670 register file might be handy. IIRC it has four registers with separate read/write address and data. (Something newer than LS might be desirable (eg.74HCT670)).
Fri Apr 26, 2019 9:01 pm
Ha! i didn't know those were still in production!
Fri Apr 26, 2019 9:06 pm
Hehe, 74HC670s are exactly what I'm using. You need four though to get two registers visible at the same time.
Fri Apr 26, 2019 9:16 pm
so i was looking based on your comment, actually a ATF22V10 would be a single chip solution. it has enough pins and gates for you to implement a single 8-bit register design... same wincupl and programmer as the ATF16v8...
Fri Apr 26, 2019 9:34 pm
Thanks Dave, This has been useful !
Fri Apr 26, 2019 9:50 pm
So, can the ATF22V10 be programmed with the TL866 series eeprom programmer as well, same as the ATF16v8 ?. I recall having read elsewhere that the ATF22V10 is particularly difficult to "burn", but maybe that was an outdated info...
Fri Apr 26, 2019 9:54 pm
i ordered some ATF22v10's in to give it a try... it will be a few weeks before i will get a chance to test...
Fri Apr 26, 2019 9:59 pm
I've been playing with the 74LS593 register/counters in the past few weeks. I've written a blog post with a description of how they work and some gotchas with using them.
I got my 74LS versions from Utsource for only a few dollars each. I think the HCT ones are much more expensive, and I don't think you can get HC versions.
Hope this is useful.
Thu May 16, 2019 12:50 am
great write up! you should move some of that content to hackaday.io !
Thu May 16, 2019 1:06 am
Update: I just got a decent enough logic analyser to measure the real waveforms. I've updated my 74LS593 notes with a commentary on the waveforms at the bottom. Cheers, Warren
Sun Jun 09, 2019 12:02 am
Users browsing this forum: No registered users and 35 guests
