View unanswered posts | View active topics It is currently Mon Apr 29, 2024 11:42 am
Reply to topic  [ 2 posts ]
 EGO - a 16 bit TTL machine from BYTE
Byte had a 2 article series in September and October 1985 of EGO, a 16 bit TTL cpu:
https://www.americanradiohistory.com/Ar ... ersary.pdf
https://www.americanradiohistory.com/Ar ... 985-10.pdf
Also visible on the Internet Archive:
via Will Cooke on classiccmp
Sun Aug 18, 2019 8:59 am
Thanks for sharing. That's quite interesting!. I found this quote from the article quite mind blowing: "I have produced a computer that reasserts 8-bit computing in a 16-bit world and outperforms standard IBM-PC by 20 to 100%". The processor was allegedly a modern version of the Z80, and the operating system was apparently coded entirely in assembly to take full advantage of it. I found that the hd64180 processor is apparently still on sale on some ic stores. So in theory this could still be built today with possibly only minor changes...
Mon Aug 19, 2019 9:47 am
Users browsing this forum: No registered users and 47 guests
