EGO - a 16 bit TTL machine from BYTE http://anycpu.org/forum/viewtopic.php?f=22&t=622 |
Page 1 of 1 |
Author: | BigEd [ Sun Aug 18, 2019 8:59 am ] |
Post subject: | EGO - a 16 bit TTL machine from BYTE |
. Quote: Byte had a 2 article series in September and October 1985 of EGO, a 16 bit TTL cpu: https://www.americanradiohistory.com/Ar ... ersary.pdf https://www.americanradiohistory.com/Ar ... 985-10.pdf Also visible on the Internet Archive:
EGO A homebuilt CPU, Part 2, The Hardware by Clifford Kelley via Will Cooke on classiccmp |
Author: | joanlluch [ Mon Aug 19, 2019 9:47 am ] |
Post subject: | Re: EGO - a 16 bit TTL machine from BYTE |
Thanks for sharing. That's quite interesting!. I found this quote from the article quite mind blowing: "I have produced a computer that reasserts 8-bit computing in a 16-bit world and outperforms standard IBM-PC by 20 to 100%". The processor was allegedly a modern version of the Z80, and the operating system was apparently coded entirely in assembly to take full advantage of it. I found that the hd64180 processor is apparently still on sale on some ic stores. So in theory this could still be built today with possibly only minor changes... |
