Last visit was: Sat Oct 17, 2026 6:45 am
It is currently Sat Oct 17, 2026 6:45 am
 [ 120 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8
 Virtual 36 bit computer
The sun was shining, the birds where chirping., the grass... OK no birds or grass.
I decided since I had sun, to put the computer on the bench, and scope the signals.
A good bit of bounce on the clock A. power off. Lets check clock B.
Got every thing hooked up. and POOF a loud bang from the scope.
Time to order new test equipment. So the measuring will be delayed for a bit.
Wed Mar 25, 2026 11:23 pm
Oh no! A good old-fashioned scope with CRT and high voltages?
Thu Mar 26, 2026 7:44 am
Yes, I have the Classic Boat anchor. Something went wrong in the sweep the section.
So for the price of a new VALVE, I have cheap digital scope on order.
I only want to test a few signals, so there is no need for fancy device at this time.
Thu Mar 26, 2026 5:45 pm
It works only under a **FULL MOON**. Could be heat related, cool here. Only when warmed up,does it work.
Address #15 gets set to 1 when at fault. Does not work at all with other ALU card. Need to order more parts for testing.
Got the new scope in, and any changes i make don't seem to change any thing. Crashes after a few minutes, but no memory
address error. Too dark to do anything today.
Sat Mar 28, 2026 10:52 pm
Built a new mother board with different bus pull ups. That seems to have fixed the problem.
Running my test program now.
APE's drink 67304 Bottles of beer,232696 Bottles on the wall
Waiting for parts for final tweaking.
Rather than rebuilding a better version of this computer. now that I have it working I plan to move to
a 10/20/40 bit cpu and go to a hex display. Only the data path needs to go from 18 to 20 bits. This will be my
spring project.
Wed Apr 01, 2026 12:53 am
Still a lemon, and buggy.
After working on the PCB for the 32 bit computer, the 9 bit bus transceivers came in.
The 36 bit instruction set is based on the 32 bit instruction layout. The max clock is 8 Mhz.
2 uS core, state decode timing 1970. Address and data lines are buffered now on the alu card.
Fri Jun 26, 2026 7:12 am
The lemon lives. Stuffed the PCB and burnt the CPLD's. Front panel and halt works.
Need to revise software now.
Not sure how long I will stay with 18/36 bits. May move soon to a 20 bit version
after the 10 bit bus transceivers come in.
Thu Jul 09, 2026 4:42 am
Not accessing the 6850 ACIA. thus no bootstrap. Bad ACIA or CPLD.
Giving up on 18 bits, Moving to a 16/32 bit CPU in the style of the late 60's
like the IBM 1130. Ordered a whole bunch of new parts for the new design.
Only CPLD's will be the ALU and 22v10's just for address decoding.
With no byte addressing memory and I/O cards will be simple.
Sun Jul 12, 2026 10:20 am
Now working on Komputer 69 a 16/32 bit computer, with a 12 phase clock.
Wed Jul 15, 2026 1:58 am
That's a lot of clock phases! Have you a diagram or explanation?
Wed Jul 15, 2026 7:16 am
That is a divide by 6 (ring counter) and a divide by 2 to give a 6502 style memory cycle.
Wed Jul 15, 2026 2:01 pm
Now with 10 states, and using chips I have off hand.
Yes the 16V8 I have on hand. Decodes the timing for the ring counter
and a 1200 bit baud rate at a 16 x clock. The memory card is mostly done.
Thu Jul 16, 2026 4:04 pm
The motherboard is out the door.
Thu Jul 16, 2026 11:24 pm
The mother board showed up at 11:30 am today, and is now mostly stuffed and working.
Had to hack the bus termination resistors to fix a bug. The alu card is on the way and the memory
card pcb is being processed. The i/o card is waiting for parts to arrive to check footprints
before I lay out the card.
Sat Jul 25, 2026 2:41 am
Digging through my junk under the bed today, I found some other parts I was keeping for IO.
I now plan use that rather than the stuff I ordered for the SD card interface, since the io bug was fixed.
The 74XX299 has bit 0 as the MSB bit rather than the LSB as I expected it to be.
A 22v10 and a 74HCT299 gets me a basic SPI interface over bit banging. I also revised it to use parts on
hand. The PCB is out the door. The set of 5 PCB's is $120 U.S, with shipping. Customs is $25 Canadian.
Sat Jul 25, 2026 11:14 pm
