Last visit was: Sat Sep 26, 2026 1:02 pm
It is currently Sat Sep 26, 2026 1:02 pm
Joined: Sat Feb 02, 2013 9:40 am Posts: 2513 Location: Canada
I got the clock gating logic in place.
Made the core more configurable. Parts of the core not needed may now be left out. Added a second fpu. Well I tried running the cpu in a minimal configuration and it ran about 85% as fast as a full configuration. This is due to the test program which is zeroing out a bunch of memory. All the stores cause the processor to stall more in the full configuration. A write buffer might help. So, I wrote a simple write buffer. With the write buffer for the test it ran about 35% faster. I decided to try the icache hammer test. Well it crashed. I traced the problem to a word in the icache that is being loaded with zeros. I haven’t figured this out yet. The word is in the middle of the cache line, and the rest of the line loads okay.
| Mon Sep 17, 2018 3:58 am |
I am in favour of write buffers!
| Mon Sep 17, 2018 9:03 am |
Figured out the middle word problem. It was software, a sync instruction was needed after invalidating the cache to allow preceding store operations to complete. The cache was being loaded from an incompletely updated source. Code: ; Now jump to the test code cache #3,[r1] ; invalidate the cache
; The following is important to allow the last few store ; operations to complete before trying to execute code. sync
jal r29,[r1] ldi r2,#14 ; this is the value that should be returned
I was able to trim some bits off the cache line length. While five words (320 bits) are loaded into the cache line only 288 bits are really needed. Fixed up the RSB a little bit. It’s slightly better at predicting the return address now, though it still doesn’t work the way it should. Ran some timing experiments (runs of 601 us) With a minimal core (1IDU, 1ALU, 1MEM, no FCU, no Write Buf, 1 CMT path): 2200 insts. Adding a WB: 2285 insns Adding bypass networks: 2285 insns Adding FCU : 2270 insns Adding 2nd CMT path: 2358 insns Adding 2nd IDU: 6910 insns Adding 2nd MEM: 6911 insns Adding 2nd ALU: 6911 insns The biggest impact on performance seems to be having a second instruction decoder. With only one decoder the core is limited to one instruction per clock max. Interesting is with the flow control unit branch predictor, RSB enabled the number of instructions executed actually went down.
| Tue Sep 18, 2018 3:24 am |
I tried synthesizing the core again after numerous changes, and got a bit of a surprise. The core size is down to 62,000 LC’s from 210,000 LCs. There’s only a couple of reasons I can think of a) synthesis didn’t work properly (the core sims okay) – this is unlikely. or b) the drastic size reduction is due to the implementation of a more efficient instruction decoder. Previously for decode I used a bunch of functions all over the place (a simple first effort). For instance the IsStore() function was used in about six places. Functions cause hardware to be instanced. I cleaned up the core so that most of the functions are called in only once per decoder (two decoders) places and voila it’s much smaller now. I think code bloat is still expensive hardware-wise. The core’s small enough now to fit into a smaller FPGA  I had to drop the clock gating on functional units; the design couldn’t be placed with all the clock gates.
| Wed Sep 19, 2018 2:48 am |
That's a big win! With a design this big, it must be worthwhile to track the synth results on a hierarchical basis - you may lose out on the dissolving of boundaries, but win on the information gained about what's costing you. Over on 6502.org we once compared a number of 6502 cores, and there was quite a large variation in size - all of them, of course, are meeting the same spec. In fact, a 6x variation. http://forum.6502.org/viewtopic.php?f=10&t=1673&p=12227
| Wed Sep 19, 2018 7:00 am |
Quote: With a design this big, it must be worthwhile to track the synth results on a hierarchical basis - I don't think there's way to track synth hierarchically. I just set individual components as top level and re-synth. It's a pita to get the synth results that way. Quote: Over on 6502.org we once compared a number of 6502 cores, and there was quite a large variation in size - all of them, of course, are meeting the same spec. In fact, a 6x variation. It shows that it's possible to create different code for the same spec. with different results. Some optimized for size and others for clock rate. Expanded the number of queue entries to 10, but kept issue logic for only the first eight slots. It’s extremely unlikely that instructions would be able to issue in later slots because they typically depend on instructions in prior slots. It’s a case of diminishing returns on the value of being able to issue from later slots. There is also instruction decoding to do which effectively occupies slots preventing issue. Expanding the queue by two entries gained about 10% in performance. (7552 instructions got executed versus 6911). Added a control bit to disable write merging for I/O devices. This is as opposed to having I/O instructions. It might be more efficient to have I/O instructions. There's already volatile loads in the design adding store for I/O wouldn't be a big leap.
| Fri Sep 21, 2018 2:55 am |
You're right, of course, that there are often tradeoffs of size vs speed: adders and multipliers are obvious examples. But I don't think that's what's going on with the 6502 results. I think it's mostly about coding styles and microarchitectural decisions. I think Arlet's core is both smallest and fastest. (One thing Arlet's core isn't, is very flexible, unlike say a microcoded machine might be. It's built very closely to the way the NMOS 6502 was built. As a possibly consequence, it was gratifyingly easy and low-cost to extend it to 65C02.)
I wouldn't want to quibble - I just wanted to note the effect of microarchitecture on synthesis results. When a design seems too large or too slow, it might be possible to do a round of microarchitectural review, and see where the costs are, and what might be done. Clearly, it won't always be possible to improve things.
| Fri Sep 21, 2018 4:26 am |
Rob:
Don't know what particular tool you're using, Vivado or ISE, but under ISE I am able to get a fairly accurate resource utilization report for the module hierarchy. I have to have two sets of process options set. Under the synthesis Process Properties, in the Synthesis Options tab, I set -keep_hierarchy to NO and I set -netlist_hierarchy to Rebuilt. Under the Implement Design Process Properties - MAP Options tab, I check the -detail (Detailed MAP Report) option.
With these settings, I can synthesis and MAP/PAR the design, or just MAP the design, the Module Level Utilization Report provides a detailed resource utilization report. In my experience, the module resource utilization values reported make sense when used with these settings.
| Fri Sep 21, 2018 11:45 pm |
I searched around briefly in the options and I can't see any that set the map detail. I'm using Vivado 18.2. There probably is an option, as there is a "more options" field to allow you to specify. IIRC I've seen a breakdown of resource usage, just not by hierarchical module. Vivado has tons of reporting so it must be in there somewhere.
I started working again on an Audio/Video core (AVIC128). It has some accelerators for text and graphics blitting, point plot, line and curve drawing. This was a 16-bit core that used block ram for display ram, modified to be a 64-bit core using ddr ram. So there's quite a few changes to it.
| Sat Sep 22, 2018 7:09 am |
Hey, I just found a spot to be able to specify a hierarchical report. You have to click on reporting strategies, then specify custom reports. I'm re-running synth now out of curiosity.
| Sat Sep 22, 2018 7:18 am |
Cool. Looking forward to seeing your report.
| Sat Sep 22, 2018 3:44 pm |
Added macro support to the assembler. A macro can be defined like the following example: Code: macro mGfxCmd (cmd, dat) lh r3,dat ldi r5,#cmd<<32 or r3,r3,r5 sw r3,$DC0[r6] memdb sw r0,$DD0[r6] memdb bra .testbr@ dc 0x1234 .testbr@ endm
The ‘@’ symbol substitutes a macro instance number for the ‘@’. So, Code: memdb bgtu r2,r4,.0001 ; allow up 24 entries to be in progress mGfxCmd (12,fgcolor) mGfxCmd (13,bkcolor) mGfxCmd (16,_DBGCursorCol)
expands into: Code: FFFFFFFFFFFC0504 02 00 40 04 memdb FFFFFFFFFFFC0508 30 44 50 FF bgtu r2,r4,.0001 ; allow up 24 entries to be in progress FFFFFFFFFFFC050C 60 60 08 00 00 FD lh r3,fgcolor FFFFFFFFFFFC0512 27 05 06 00 49 A0 00 00 ldi r5,#12<<32 FFFFFFFFFFFC051A 00 00 FFFFFFFFFFFC051C 02 A3 8C 25 or r3,r3,r5 sw r3,$DC0[r6] FFFFFFFFFFFC0520 02 00 40 04 memdb FFFFFFFFFFFC0524 24 06 50 37 sw r0,$DD0[r6] FFFFFFFFFFFC0528 02 00 40 04 memdb FFFFFFFFFFFC052C 81 70 bra .testbr0 FFFFFFFFFFFC052E 34 12 dc 0x1234 .testbr0 FFFFFFFFFFFC0530 60 60 18 00 00 FD lh r3,bkcolor FFFFFFFFFFFC0536 27 85 06 00 49 A0 00 00 ldi r5,#13<<32 FFFFFFFFFFFC053E 00 00 <etc…> I hope to eventually have the assembler support structured programming constructs too. The ‘if’, ‘ifdef’ and ‘ifndef’ statements are already supported. It took 10 hours to route the entire SoC, 17,000 routes failed. The device is just a little bit too full when I include the audio / video circuitry. So I’ll have to par the system down some.
| Sun Sep 23, 2018 5:52 am |
Here is a copy of the utilization report. I can trim the cpu size down some. Code: 1. Utilization by Hierarchy ---------------------------
+------------------------------------+------------------------------------+----------------+----------------+---------------+----------+---------------+-----------+-----------+--------------+ | Instance | Module | Total LUTs | Logic LUTs | LUTRAMs | SRLs | FFs | RAMB36 | RAMB18 | DSP48 Blocks | +------------------------------------+------------------------------------+----------------+----------------+---------------+----------+---------------+-----------+-----------+--------------+ | FT64v5SoC | (top) | 120081(89.21%) | 100547(74.70%) | 19528(42.27%) | 6(0.01%) | 27049(10.05%) | 28(7.67%) | 18(2.47%) | 21(2.84%) | | (FT64v5SoC) | (top) | 1(0.01%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 3(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | uavic1 | AVIC128 | 10791(8.02%) | 10788(8.01%) | 0(0.00%) | 3(0.01%) | 12221(4.54%) | 0(0.00%) | 1(0.14%) | 19(2.57%) | | (uavic1) | AVIC128 | 4788(3.56%) | 4785(3.55%) | 0(0.00%) | 3(0.01%) | 12143(4.51%) | 0(0.00%) | 1(0.14%) | 19(2.57%) | | ed10 | edge_det_58 | 2(0.01%) | 2(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ed2 | edge_det_59 | 3(0.01%) | 3(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ed5 | edge_det_60 | 1(0.01%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ed6 | edge_det_61 | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ed7 | edge_det_62 | 2(0.01%) | 2(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u1 | VGASyncGen | 5992(4.45%) | 5992(4.45%) | 0(0.00%) | 0(0.00%) | 71(0.03%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | (u1) | VGASyncGen | 47(0.03%) | 47(0.03%) | 0(0.00%) | 0(0.00%) | 5(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u1 | counter | 4788(3.56%) | 4788(3.56%) | 0(0.00%) | 0(0.00%) | 45(0.02%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u2 | counter_65 | 1157(0.86%) | 1157(0.86%) | 0(0.00%) | 0(0.00%) | 21(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u2 | AVIC128_VideoFifo | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u3 | edge_det_63 | 2(0.01%) | 2(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u4 | VIC128_ShadowRam | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u5 | VIC128_AudioFifo | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u6 | VIC128_AudioFifo | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u7 | VIC128_AudioFifo | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u8 | VIC128_AudioFifo | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ucf1 | AVIC128_CmdFifo | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ued20 | edge_det_64 | 1(0.01%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ubr1 | bootrom | 5(0.01%) | 5(0.01%) | 0(0.00%) | 0(0.00%) | 19(0.01%) | 16(4.38%) | 0(0.00%) | 0(0.00%) | | (ubr1) | bootrom | 4(0.01%) | 4(0.01%) | 0(0.00%) | 0(0.00%) | 18(0.01%) | 16(4.38%) | 0(0.00%) | 0(0.00%) | | u1 | edge_det_57 | 1(0.01%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ucg1 | NexysVideoClkgen | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ucpu1 | FT64_mpu | 108729(80.78%) | 89286(66.33%) | 19440(42.08%) | 3(0.01%) | 13513(5.02%) | 8(2.19%) | 15(2.05%) | 0(0.00%) | | ucpu1 | FT64 | 90062(66.91%) | 87027(64.66%) | 3032(6.56%) | 3(0.01%) | 12912(4.80%) | 8(2.19%) | 15(2.05%) | 0(0.00%) | | (ucpu1) | FT64 | 50870(37.79%) | 50870(37.79%) | 0(0.00%) | 0(0.00%) | 9371(3.48%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gAluInst.ualu1 | FT64_alu | 168(0.12%) | 168(0.12%) | 0(0.00%) | 0(0.00%) | 176(0.07%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | udiv1 | FT64_divider_41 | 15(0.01%) | 15(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umult1 | FT64_multiplier_42 | 11(0.01%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb0 | FT64_multiplier__parameterized2_43 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb1 | FT64_multiplier__parameterized2_44 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb2 | FT64_multiplier__parameterized2_45 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb3 | FT64_multiplier__parameterized2_46 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb4 | FT64_multiplier__parameterized2_47 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb5 | FT64_multiplier__parameterized2_48 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb6 | FT64_multiplier__parameterized2_49 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb7 | FT64_multiplier__parameterized2_50 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultc0 | FT64_multiplier__parameterized1_51 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultc1 | FT64_multiplier__parameterized1_52 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultc2 | FT64_multiplier__parameterized1_53 | 11(0.01%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultc3 | FT64_multiplier__parameterized1_54 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umulth0 | FT64_multiplier__parameterized0_55 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umulth1 | FT64_multiplier__parameterized0_56 | 11(0.01%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gDCacheInst.udc1 | FT64_dcache__xdcDup__1 | 13(0.01%) | 13(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 1(0.14%) | 0(0.00%) | | u1 | dcache_mem_40 | 1(0.01%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 1(0.14%) | 0(0.00%) | | u3 | FT64_dcache_tag__xdcDup__1 | 12(0.01%) | 12(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | (u3) | FT64_dcache_tag__xdcDup__1 | 12(0.01%) | 12(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u1 | FT64_dcache_tag2 | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u2 | FT64_dcache_tag2 | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gDecocderInst.genblk1[0].iq0 | decoder8 | 190(0.14%) | 190(0.14%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gDecocderInst.genblk1[1].iq0 | decoder8_6 | 183(0.14%) | 183(0.14%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gDecocderInst.genblk1[2].iq0 | decoder8_7 | 162(0.12%) | 162(0.12%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gDecocderInst.genblk1[3].iq0 | decoder8_8 | 183(0.14%) | 183(0.14%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gDecocderInst.genblk1[4].iq0 | decoder8_9 | 198(0.15%) | 198(0.15%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gDecocderInst.genblk1[5].iq0 | decoder8_10 | 194(0.14%) | 194(0.14%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gDecocderInst.genblk1[6].iq0 | decoder8_11 | 182(0.14%) | 182(0.14%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gDecocderInst.genblk1[7].iq0 | decoder8_12 | 206(0.15%) | 206(0.15%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gDecocderInst.genblk1[8].iq0 | decoder8_13 | 26(0.02%) | 26(0.02%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gDecocderInst.genblk1[9].iq0 | decoder8_14 | 26(0.02%) | 26(0.02%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gFPUInst.ufp1 | fpUnit | 30(0.02%) | 30(0.02%) | 0(0.00%) | 0(0.00%) | 31(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | fpr0 | fpRoundReg_35 | 2(0.01%) | 2(0.01%) | 0(0.00%) | 0(0.00%) | 8(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u11 | fpDiv_36 | 12(0.01%) | 12(0.01%) | 0(0.00%) | 0(0.00%) | 12(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u2 | fpdivr16_39 | 12(0.01%) | 12(0.01%) | 0(0.00%) | 0(0.00%) | 12(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u13 | fpSqrt_37 | 16(0.01%) | 16(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u2 | isqrt_38 | 16(0.01%) | 16(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gFPUInst.ufp1__0 | fpUnit_15 | 30(0.02%) | 30(0.02%) | 0(0.00%) | 0(0.00%) | 31(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | fpr0 | fpRoundReg | 2(0.01%) | 2(0.01%) | 0(0.00%) | 0(0.00%) | 8(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u11 | fpDiv | 12(0.01%) | 12(0.01%) | 0(0.00%) | 0(0.00%) | 12(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u2 | fpdivr16 | 12(0.01%) | 12(0.01%) | 0(0.00%) | 0(0.00%) | 12(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u13 | fpSqrt | 16(0.01%) | 16(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u2 | isqrt | 16(0.01%) | 16(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gICacheInst.uic1 | FT64_L1_icache | 1984(1.47%) | 507(0.38%) | 1476(3.19%) | 1(0.01%) | 83(0.03%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | (gICacheInst.uic1) | FT64_L1_icache | 16(0.01%) | 16(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | tags.u1 | FT64_L1_icache_mem_32 | 759(0.56%) | 471(0.35%) | 288(0.62%) | 0(0.00%) | 64(0.02%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | tags.u3 | FT64_L1_icache_cmptag4way_33 | 1209(0.90%) | 20(0.01%) | 1188(2.57%) | 1(0.01%) | 19(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | (tags.u3) | FT64_L1_icache_cmptag4way_33 | 1194(0.89%) | 6(0.01%) | 1188(2.57%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u1 | lfsr_34 | 15(0.01%) | 14(0.01%) | 0(0.00%) | 1(0.01%) | 19(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | gIDUInst.uid2 | FT64_idecoder | 454(0.34%) | 454(0.34%) | 0(0.00%) | 0(0.00%) | 46(0.02%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ualu0 | FT64_alu__parameterized0 | 173(0.13%) | 173(0.13%) | 0(0.00%) | 0(0.00%) | 176(0.07%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | udiv1 | FT64_divider | 16(0.01%) | 16(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umult1 | FT64_multiplier | 11(0.01%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb0 | FT64_multiplier__parameterized2 | 11(0.01%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb1 | FT64_multiplier__parameterized2_21 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb2 | FT64_multiplier__parameterized2_22 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb3 | FT64_multiplier__parameterized2_23 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb4 | FT64_multiplier__parameterized2_24 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb5 | FT64_multiplier__parameterized2_25 | 11(0.01%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb6 | FT64_multiplier__parameterized2_26 | 11(0.01%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultb7 | FT64_multiplier__parameterized2_27 | 11(0.01%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultc0 | FT64_multiplier__parameterized1 | 11(0.01%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultc1 | FT64_multiplier__parameterized1_28 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultc2 | FT64_multiplier__parameterized1_29 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umultc3 | FT64_multiplier__parameterized1_30 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umulth0 | FT64_multiplier__parameterized0 | 10(0.01%) | 10(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umulth1 | FT64_multiplier__parameterized0_31 | 11(0.01%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ubp1 | FT64_BranchPredictor | 573(0.43%) | 493(0.37%) | 80(0.17%) | 0(0.00%) | 242(0.09%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ubtb1 | FT64_BTB | 508(0.38%) | 508(0.38%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 8(2.19%) | 0(0.00%) | 0(0.00%) | | udc0 | FT64_dcache | 12(0.01%) | 12(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 1(0.14%) | 0(0.00%) | | u1 | dcache_mem | 1(0.01%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 1(0.14%) | 0(0.00%) | | u3 | FT64_dcache_tag | 11(0.01%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | (u3) | FT64_dcache_tag | 11(0.01%) | 11(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u1 | FT64_dcache_tag2 | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u2 | FT64_dcache_tag2 | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ufb1 | FT64_fetchbuf | 28013(20.81%) | 28013(20.81%) | 0(0.00%) | 0(0.00%) | 1571(0.58%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | (ufb1) | FT64_fetchbuf | 26215(19.48%) | 26215(19.48%) | 0(0.00%) | 0(0.00%) | 392(0.15%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ursb1 | FT64_RSB | 1470(1.09%) | 1470(1.09%) | 0(0.00%) | 0(0.00%) | 615(0.23%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ursb2 | FT64_RSB_20 | 328(0.24%) | 328(0.24%) | 0(0.00%) | 0(0.00%) | 564(0.21%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | uic0 | FT64_L1_icache_16 | 3999(2.97%) | 2522(1.87%) | 1476(3.19%) | 1(0.01%) | 379(0.14%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | (uic0) | FT64_L1_icache_16 | 16(0.01%) | 16(0.01%) | 0(0.00%) | 0(0.00%) | 291(0.11%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | tags.u1 | FT64_L1_icache_mem | 2777(2.06%) | 2489(1.85%) | 288(0.62%) | 0(0.00%) | 64(0.02%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | tags.u3 | FT64_L1_icache_cmptag4way | 1206(0.90%) | 17(0.01%) | 1188(2.57%) | 1(0.01%) | 24(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | (tags.u3) | FT64_L1_icache_cmptag4way | 1191(0.88%) | 3(0.01%) | 1188(2.57%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u1 | lfsr_19 | 15(0.01%) | 14(0.01%) | 0(0.00%) | 1(0.01%) | 24(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | uic2 | FT64_L2_icache | 1257(0.93%) | 1256(0.93%) | 0(0.00%) | 1(0.01%) | 717(0.27%) | 0(0.00%) | 13(1.78%) | 0(0.00%) | | (uic2) | FT64_L2_icache | 131(0.10%) | 131(0.10%) | 0(0.00%) | 0(0.00%) | 136(0.05%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | tags.u2 | FT64_L2_icache_cmptag4way | 803(0.60%) | 802(0.60%) | 0(0.00%) | 1(0.01%) | 67(0.02%) | 0(0.00%) | 4(0.55%) | 0(0.00%) | | (tags.u2) | FT64_L2_icache_cmptag4way | 796(0.59%) | 796(0.59%) | 0(0.00%) | 0(0.00%) | 43(0.02%) | 0(0.00%) | 4(0.55%) | 0(0.00%) | | u1 | lfsr | 7(0.01%) | 6(0.01%) | 0(0.00%) | 1(0.01%) | 24(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u1 | FT64_L2_icache_mem | 320(0.24%) | 320(0.24%) | 0(0.00%) | 0(0.00%) | 513(0.19%) | 0(0.00%) | 9(1.23%) | 0(0.00%) | | u3 | edge_det_18 | 3(0.01%) | 3(0.01%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | uid1 | FT64_idecoder_17 | 226(0.17%) | 226(0.17%) | 0(0.00%) | 0(0.00%) | 46(0.02%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | urf1 | FT64_regfile2w6r_oc | 162(0.12%) | 162(0.12%) | 0(0.00%) | 0(0.00%) | 41(0.02%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | (urf1) | FT64_regfile2w6r_oc | 162(0.12%) | 162(0.12%) | 0(0.00%) | 0(0.00%) | 41(0.02%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | urf10 | FT64_regfileRam | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | urf11 | FT64_regfileRam | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | urf12 | FT64_regfileRam | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | urf13 | FT64_regfileRam | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | urf14 | FT64_regfileRam | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | urf15 | FT64_regfileRam | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ustmp1 | FT64_stomp | 40(0.03%) | 40(0.03%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ucrd1 | CardMemory | 17788(13.22%) | 1404(1.04%) | 16384(35.46%) | 0(0.00%) | 237(0.09%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | ummu1 | FT64_mmu | 474(0.35%) | 474(0.35%) | 0(0.00%) | 0(0.00%) | 104(0.04%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | (ummu1) | FT64_mmu | 474(0.35%) | 474(0.35%) | 0(0.00%) | 0(0.00%) | 104(0.04%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | u1 | FT64_MMURam1 | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | upic1 | FT64_pic | 80(0.06%) | 56(0.04%) | 24(0.05%) | 0(0.00%) | 108(0.04%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | upit1 | FT64_pit | 325(0.24%) | 325(0.24%) | 0(0.00%) | 0(0.00%) | 152(0.06%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | umc1 | mpmc6 | 434(0.32%) | 346(0.26%) | 88(0.19%) | 0(0.00%) | 1059(0.39%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | (umc1) | mpmc6 | 434(0.32%) | 346(0.26%) | 88(0.19%) | 0(0.00%) | 1059(0.39%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | uddr3 | mig_7series_1 | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | uprg1 | random | 21(0.02%) | 21(0.02%) | 0(0.00%) | 0(0.00%) | 100(0.04%) | 2(0.55%) | 0(0.00%) | 2(0.27%) | | (uprg1) | random | 2(0.01%) | 2(0.01%) | 0(0.00%) | 0(0.00%) | 100(0.04%) | 0(0.00%) | 0(0.00%) | 2(0.27%) | | u1 | rand_ram | 4(0.01%) | 4(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 1(0.27%) | 0(0.00%) | 0(0.00%) | | u2 | rand_ram_5 | 15(0.01%) | 15(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 1(0.27%) | 0(0.00%) | 0(0.00%) | | ur2d1 | rgb2dvi | 97(0.07%) | 97(0.07%) | 0(0.00%) | 0(0.00%) | 104(0.04%) | 0(0.00%) | 2(0.27%) | 0(0.00%) | | ClockSerializer | OutputSERDES | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | DataEncoders[0].DataEncoder | TMDS_Encoder | 36(0.03%) | 36(0.03%) | 0(0.00%) | 0(0.00%) | 38(0.01%) | 0(0.00%) | 1(0.14%) | 0(0.00%) | | DataEncoders[0].DataSerializer | OutputSERDES_0 | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | DataEncoders[1].DataEncoder | TMDS_Encoder_1 | 30(0.02%) | 30(0.02%) | 0(0.00%) | 0(0.00%) | 32(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | DataEncoders[1].DataSerializer | OutputSERDES_2 | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | DataEncoders[2].DataEncoder | TMDS_Encoder_3 | 31(0.02%) | 31(0.02%) | 0(0.00%) | 0(0.00%) | 32(0.01%) | 0(0.00%) | 1(0.14%) | 0(0.00%) | | DataEncoders[2].DataSerializer | OutputSERDES_4 | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | LockLostReset | ResetBridge | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 2(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | SyncAsyncx | SyncAsync | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 2(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | | uscr1 | scratchmem | 3(0.01%) | 3(0.01%) | 0(0.00%) | 0(0.00%) | 30(0.01%) | 2(0.55%) | 0(0.00%) | 0(0.00%) | | (uscr1) | scratchmem | 3(0.01%) | 3(0.01%) | 0(0.00%) | 0(0.00%) | 29(0.01%) | 2(0.55%) | 0(0.00%) | 0(0.00%) | | u1 | edge_det | 0(0.00%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | 1(0.01%) | 0(0.00%) | 0(0.00%) | 0(0.00%) | +------------------------------------+------------------------------------+----------------+----------------+---------------+----------+---------------+-----------+-----------+--------------+
| Sun Sep 23, 2018 5:56 am |
Results. What do you think about the results for the various modules. I use these reports to give me a sense of where to optimize, and where I've left off some connections. Parsing the tools' warnings can be mind numbing and extremely error prone.
| Sun Sep 23, 2018 3:18 pm |
The breakdown doesn’t show all the modules, perhaps there is an additional option to set. 1) The fetch buffers are quite a bit larger (27000 LUTs) than I would’ve thought. They occupy about 1/3 of the cpu. I’m guessing it’s the 4x decoding of flow control instructions. It could also be the compressed instruction expanders. Results for those two modules are not shown on the report. There needs to be a decode for each fetch buffer to get single cycle performance on branches. Given the fact that the design doesn’t meet timing, it may be better to rethink the design. Branching could be put off a couple of cycles until after the regular decode, that would eliminate the 4x decode. That would cause branches to be multi-cycle. But hopefully the fmax could be driven up. 2) The Card memory which is present to accelerate garbage collection could be eliminated. It’s 17,000 LUTs. It was made of LUTs to get single cycle performance. I suppose it could be switched to block-ram with it’s two cycle latency. 3) The L1-icache memory (made of LUT’s) could maybe be larger, it’s only 3% (2kB) of the design. A lot of performance might be gained from a larger L1-icache. 4) The ALU isn’t nearly as big as I thought it would be -> could make all the ALU’s the same (BIG) and increase the number of them. 5) The fpu isn’t taking hardly anything, either the stat’s wrong or it was configured without an fpu. 6) There’s a lot LUT rams in the mpu and there shouldn’t be.
I’m not too thrilled about decoding on the fetch buffers. I’ve been wondering if it’s possible to add another layer of registers between the fetch and queue stages to help with the fmax. Right now, a lot of work is being done on the (unregistered) output of the fetch stage (register decode / fetch, and instruction dependency logic). I like the idea of moving logic to the other side of the queue because then it can be pipelined. But I don't know how it would be done.
Experimenting with dynamic compressed instructions. They seem to work. It takes only a single opcode to allow the top 256 instructions to be encoded into a single 16-bit instruction parcel. Having an additional lookup table in the fetch path probably isn’t a good idea for performance. The dynamic compressed instructions are a second set of compressed instructions. The first set is a fixed set of compressed instructions.
| Mon Sep 24, 2018 3:28 am |
Users browsing this forum: alibaba-cloud, chrome-131-bots, chrome-133-bots, claudebot, Firefox-147-bots and 25 guests |
