Last visit was: Thu Jun 18, 2026 2:12 pm
It is currently Thu Jun 18, 2026 2:12 pm
DockLazy
For examples of DOS. Unix version 6 and in particular the book "A Commentary on the Sixth Edition UNIX Operating System by John Lions" is probably the best resource I've found for an early 70's OS.
Apart from that, C/PM has it's BIOS writing guide and the source itself is available but not very readable.
| Sat Feb 03, 2024 9:18 pm |
DockLazy wrote: For examples of DOS. Unix version 6 and in particular the book "A Commentary on the Sixth Edition UNIX Operating System by John Lions" is probably the best resource I've found for an early 70's OS.
Apart from that, C/PM has it's BIOS writing guide and the source itself is available but not very readable. Both systems have flaws. CP/M was designed for a 256 kb floppy and Unix 3 was designed for multi user with disk swapping. DEC RT 11 (PDP 11) is more what I am looking for, but all have a tiny program/data space of 64kb. (32K words). George III for the ICL 1900 really is good example of 60's operating system, as it had cards,paper tape,mag tape,and removable hard disks and printers and video and hardcopy terminals that is of historical interest. I suspect it all ran in 32K words with swapping. The evil mind thinks of running ICL emulator and porting BCPL to the EVIL computer. I fixed a few more bugs, today but still have problems.
| Sat Feb 03, 2024 10:43 pm |
Well new MAX 232's are exploding left and right. I hand to use a junk box find, that works. My skip opcode seemed flakey, so I replaced my HCT/ALS chips with 74LS parts that I found looking for max 3232 chip, for less noise. Now my quick and dirty boot loader, works with out flying into LA-LA land. I need to now add another 32K RAM card so I have 32K for user space,and 32K O/S space + 16K rom. Ben.
| Fri Feb 09, 2024 5:54 am |
DockLazy
HCT are pretty bad for noise. They have low voltage swing of TTL but with high impedance CMOS inputs, makes for the worst of both worlds.
| Fri Feb 09, 2024 6:27 am |
Just in time, a better mother board. 2 oz copper and better switches. I would love it to be base 8, but only Sexadecimal fits the PCB, for a 24 bit binary CPU. "Alpine Computer 1"
| Sat Feb 10, 2024 9:51 pm |
Code: 00000 00000 / HELLO WORLD PROGRAM 00000 / ALPINE 1 00000 GETC SET $FF8009 00000 PUTC SET $FF800A 00000 CRLF SET $FF800B 00000 00000 RIM 00300 ORG $300 00300 1C030A LD X # STR 00301 C8800B JSR A # CRLF 00302 LOOP 00302 130000 LD A X 0 00303 2C0001 ADD X #1 00304 710005 SNE A 00305 780308 JMP A # EXIT 00306 C8800A JSR A # PUTC 00307 780302 JMP A # LOOP 00308 EXIT 00308 C8800B JSR A # CRLF 00309 000002 HLT A 0030A 0030A 000048 0030B STR DW 'H 0030B 000065 0030C DW 'e 0030C 00006C 0030D DW 'l 0030D 00006C 0030E DW 'l 0030E 00006F 0030F DW 'o 0030F 00002C 00310 DW 44 / , 00310 000020 00311 DW 32 / SPACE 00311 000057 00312 DW 'W 00312 00006F 00313 DW 'o 00313 000072 00314 DW 'r 00314 00006C 00315 DW 'l 00315 000064 00316 DW 'd 00316 000021 00317 DW '! 00317 000000 00318 DW 0 00318 00000 END
1st mile stone, working ABS loader. (Bootstrap)
| Sun Feb 11, 2024 11:15 pm |
Well done!
| Mon Feb 12, 2024 9:06 am |
Now for the bug fix PCB's. More caps and better layout. 4 bit alu, using PAL's.
| Mon Feb 12, 2024 6:48 pm |
and A revamped memory/Io card. IDE interface is 12 bits wide now. Acia has its own clock.
| Tue Feb 13, 2024 2:54 am |
Fixed a few bugs, in the cross assembler with emited code.
| Fri Feb 16, 2024 7:03 am |
While waiting for the new PCBs I am drafting out a new control section using TTL logic and 28C16s as prom replaments. Some decoding changed to permit better use of TTL logic. I saved 1 logic gate. Some parts had to be changed to 74Fxx to meet timing, as the 28C16s are 70 ns slower than bipolar proms. 3 1024x8 proms are used in the design now, and lots 74ls153s and 74ls161s and 74163s (No PALs here). Revised timing is .9 uS clock cycle, or 1.8 uS for a memory read. Writes add 1 cycle more. I hope to have the PCB's in by the weekend.
| Thu Feb 22, 2024 6:15 am |
Now waiting for some last minute parts. I have a few ideas for a 20/10 bit cpu? 8 1/4 " x 5 1/4 inches for the alu card.
| Mon Feb 26, 2024 4:25 pm |
Had a logic issue with the front panel switches on the new mother board. Now working on the compact flash software.
| Fri Mar 08, 2024 8:03 am |
The compact flash seems to work. I have a paper tape bootstrap and now a disk bootstrap. I read 1K blocks, of 12 bits, but pack that into 512 words. I read block 0 at 0x000300 and jump to it for my disk boot. Right now I am using a fake IBM 2315 disk cartridge - 3 sectors of 512 (24 bit) words per track using some sort of GCR ,3072 12 bit words. A PDP-8 gets 4096 12 bit words. The orginal IBM format is 2560 8 bit words. I am about the same state system wise I was in May 2023 using a FPGA, but here I have better chance upgrading my I/O and memory. 24 bits is just ample to fit the order code, with 4 registers and two addessing modes and to have more than a 32K (word) address space. I may use FAT style disk layout if I use the disk cartridge as floppy style system. IBM 1130 style computer for now. Ben.
| Sat Mar 09, 2024 9:48 am |
Bad news, I am stuck with 256 word sectors for the compact flash. Good news, I have another 32K words of ram.
| Sun Mar 10, 2024 7:45 am |
Users browsing this forum: CCBot, YandexBot and 1 guest |
