| The next design - a octal 20 bit cpu http://anycpu.org/forum/viewtopic.php?f=23&t=1112 |
Page 1 of 2 |
| Author: | oldben [ Thu Apr 04, 2024 7:32 am ] |
| Post subject: | The next design - a octal 20 bit cpu |
Going back to more 1968 style computer. Word addressing. Accumulator design rather a register to register design. Subroutine calls on even bountry, and single word 19 bit addressing. This way I can use CALL theading for threaded code. 8 registers including the PC. More inspection of the new oder code, conficts with some other decoding,thus I am back to two word calls and the orignal order code. |
| Author: | oldben [ Thu Apr 11, 2024 6:09 am ] |
| Post subject: | Re: The next design - a octal 20 bit cpu |
Moving clock generation to the ALU card as well. The ALU gets to use the master clock first. Moving up to 1984, with a 1.5 uS memory cycle time -- ram . A 1977 version 1.8 uS core or ram. PS: Looking at the chips I have, I may tweek it for 150 ns ram, and add a wait state for IO. |
| Author: | oldben [ Sun Apr 28, 2024 5:42 am ] |
Gone back to a hex format. The schematics are roughed out, but no layout is done yet. This will be a emulated design with stubbed IO routines, for the next few months. Getting close to a "hello world" type test program. PS: Last minute addition - signed bytes (10 bits). |
| Author: | oldben [ Mon Apr 29, 2024 5:55 am ] |
Changed from Big Endian to Little Endian, so I can read and write disk blocks on the PC and port over to Compact Flash later. Disk IO would be a modified IBM patter drive from 203 tracks to 225 tracks. 4Kb per track like the PDP-8, 10 bit bytes, GCR. Some sort of strange fat system. Now I need a name for this beast, and time for software. |
| Author: | oldben [ Sat May 11, 2024 8:47 pm ] |
I have the emulator printing "Hello world". I got dosbox-x running and cross compiling small c version 1.2. I need to write a simple FAT file system ( 8 inch floppy 10 bits/byte GCR single sided) and the small C libs. System setup 462 Kb per floppy, two floppies per system. 48K ram + ROM BIOS + 2 serial at 1200 baud? about 1976. |
| Author: | oldben [ Sun May 19, 2024 10:32 pm ] |
| Post subject: | Re: The next design - a octal 20 bit cpu- NOT |
I have improved the design, since I could only find 18 bits, in the bit bucket. This is a serial design, 3 bit nibble. The only rare parts are a 13 mhz osc, CY7C122 (256 x 4 ) 25 ns ram and a 74H74. 2.5 uS memory cycle time. Operate 2.5 uS auto 5.0 uS index 7.5 uS The emulator will print "hello world", but more testing needs to be done. Ben. |
| Author: | 256 [ Fri May 24, 2024 2:05 pm ] |
oldben wrote: 3 bit nibble I've never heard of a n[yi]bble being anything other than 4 bits. |
| Author: | oldben [ Sat May 25, 2024 5:17 pm ] |
256 wrote: oldben wrote: 3 bit nibble I've never heard of a n[yi]bble being anything other than 4 bits. Next you will tell me a byte is 8 bits. Other notes. The design of the serial 18 bit cpu is on hold, just too slow, and floating point is still too small. The order code of my 20 cpu will be revised from what I learned on the 18 bit machine, with 31,1,8 float. Ben. PS: Evil laugh, bytes are now 10 bits, and nibbles half that. |
| Author: | BigEd [ Mon May 27, 2024 5:36 am ] |
(Welcome, 256! It does seem unconventional for a nibble not to be 4 bits, but as Ben notes, sometimes a byte isn't 8 bits, certainly on this forum where any CPU architecture decision is open for experimentation...) |
| Author: | oldben [ Wed May 29, 2024 12:46 am ] |
Code: draft #1 The ben 20 is a medium speed digital computer using LS TTL parts with a a word width of 20 bits and a byte with of 10 bits. 9 digit binary floating point.4K dynamic ram or 1.8 uS core memory provide the base 48Kb of memory with 32kb ram and ROM/CORE for bootstrap and other operating system routines. Emulation of the CPU, will use later PAL and bitslice parts. Cpu model: The cpu has a Carry flag and 4 general purpose registers A,B,C,D and 3 index registers S X Y and instruction pointer Z (zero). Index registers do not affect the carry. Adressing modes are register indirect: +r -r r% r+ r- indexed: r n immediate: # n opcode postfix . byte % register Instruction format: modes: 0 nop and shift nop 5 4 3 2 1 +----+----+----+----+----+ |0000| AAA| 0 | : | +----+----+----+----+----+ shift ac 5 4 3 2 1 +----+----+----+----+----+ |SSSS| AAA| 0 | : | NORMAL +----+----+----+----+----+ 1 set condition if ac condtion is true set ac to constant else set false (0) 5 4 3 2 1 +----+----+----+----+----+ |NCCC| AAA| 1 | :+###| +----+----+----+----+----+ 2 memory ref reg indirect (EFA)= AAA (STORE) AAA = AAA OP (EFA) 5 4 3 2 1 +----+----+----+----+----+ |COOO|PAAA| 2 |BXXX:+###| +----+----+----+----+----+ P PRE ADDITION B BYTE 3 memory ref INDEXED (EFA)= AAA (STORE) AAA = AAA OP (EFA) 5 4 3 2 1 +----+----+----+----+----+ |COOO| AAA| 3 |BXXX| | +----+----+----+----+----+ |####|####|####|####|####| +----+----+----+----+----+ 4 jump to subroutine memory ref BYTE imediate JSR register indirect T = (efa) (--S)= Z,Z=T 5 4 3 2 1 +----+----+----+----+----+ |0000|PAAA| 4 | XXX|+###| +----+----+----+----+----+ P PRE ADDITION memory ref BYTE imediate AAA = AAA OP # 5 4 3 2 1 +----+----+----+----+----+ |COOO| AAA| 4 |+###|####| +----+----+----+----+----+ 5 lea and control lea 5 4 3 2 1 +----+----+----+----+----+ |0000| AAA| 5 | XXX| | +----+----+----+----+----+ |####|####|####|####|####| +----+----+----+----+----+ control 5 4 3 2 1 +----+----+----+----+----+ |ffff| | 5 | | | +----+----+----+----+----+ 5 4 3 2 1 +----+----+----+----+----+ |0001| | 5 | | | HALT +----+----+----+----+----+ 6 jump on condition register indirect 5 4 3 2 1 +----+----+----+----+----+ |NCCC|PAAA| 6 | XXX|+###| +----+----+----+----+----+ 7 jump and register operate jmp indexed 5 4 3 2 1 +----+----+----+----+----+ |0000| AAA| 7 | XXX| | +----+----+----+----+----+ |####|####|####|####|####| +----+----+----+----+----+ reg operate AAA = AAA OP XXX 5 4 3 2 1 +----+----+----+----+----+ |COOO| AAA| 7 | XXX| | +----+----+----+----+----+ OPCODE TABLES: REGISTER AAA XXX 0 A A 1 B B 2 C C 3 D D 4 S S 5 X X 6 Y Y 7 Z(PC) Z(ZERO) OR # MEMORY REF OOO OP 0 ST (EFA) = AAA 1 ADD/C AAA = AAA + (EFA) + ?0,C 2 SUB/C AAA = AAA + ~(EFA) + ?1,C 3 CAD/C AAA = ~AAA + (EFA) + ?1,C 4 LD AAA = (EFA) 5 OR AAA = AAA | (EFA) 6 AND AAA = AAA & (EFA) 7 XOR AAA = AAA ^ (EFA) SHIFT LATER LOGIC CC LATER |
| Author: | oldben [ Wed Jun 05, 2024 5:12 am ] |
I have made a minor change in the order code, moving the B flag around. I have the 8080 2.1 version of the Small C Compiler generating code to self compile. Not running yet, but compiles to $09C00 Bytes. No library functions included yet. Base memory 64kb. |
| Author: | oldben [ Sat Jun 08, 2024 1:43 am ] |
More bug fixes. Hello world compiles and prints. |
| Author: | robfinch [ Sat Jun 08, 2024 8:44 am ] |
How far is it off using an 80x86 compiler? If it had the four segment registers it might be easier to program. Seg. registers are fairly resource frugal. |
| Author: | oldben [ Sat Jun 08, 2024 3:37 pm ] |
The whole point of 20 bits, is no segments. I am sticking to 8080 code model for small c, because the code is a mess for the x86. I need to check now for alignment issues, as my cpu needs word aligned data, the 8080 does not. I also need to turn off constant folding. |
| Author: | oldben [ Thu Jun 13, 2024 2:39 am ] |
Revised the order code to make better use of the 2901 bit slice and have 13 registers and S,Z and Pc registers. 1.8 us Core memory Cycle time. The 8080 version self compiles now to "Me Too 75" order codes. Partial conditional support with side effects and sign extend for long data. AC(LOW) := AC(LOW) or AC(HIGH) is the side effect after a JUMP on condition. SET on condition only affects AC(LOW). |
| Page 1 of 2 | All times are UTC |
