Last visit was: Wed Oct 07, 2026 10:22 am
It is currently Wed Oct 07, 2026 10:22 am
How about Moon-nux for the Owl 75, with free computer time 2:30 to 6:30 am... Note No PIZZA or COLA after 3:00 AM.
The real news is I filled up the order code, to get 4 extra scratch registers, or base registers like a frame or i/o pointers. They don't do to much, but they were a easy upgrade. This is about as far as I can go with my design and not need hardware changes. Ben PS. Updated the hardware for BCC/BSR but not the software.
| Sun Mar 23, 2025 12:20 am |
DockLazy
oldben wrote: My biggest problem is rollbacks is I don't have version control software. If a design idea fails or I make a bad mistake like updating the or deleting the wrong version it hard to get back from a save a few generations before. Was that foo98 or foobar23? The other catch is need my software at some point to be self hosting, and Small C from Dr Dobbs is the only portable compiler that I could find that has a simple code generator and still only needs 16 addressing.
I have the chicken and the egg problem, I need a OS to port a compiler, but I need the Compiler now to write the OS. I was wishing many many moons ago, to get something like Minux ported but it uses X86 memory management rendering it non portable for a non intel cpu. A fat indexed style of file I/O is my best option something like here: File Integrity in a Disc-Based Multi-Access System see Operating Systems Techniques, C. A. R. Hoare and R. H. Perrott, Eds., Academic Press, New York, 1972, 227–248. Minix seems like quite a heavy OS for a retro 16-bit computer. I recall Bill Buzbee spent quite a bit of effort getting it to run on Magic-1. It wouldn't take much to make that compiler run bare metal. It kind of depends what you are using for storage though. For solid state storage it's super easy. When I was bootstrapping a z80 my file allocation table was pencil and paper. On power up the CPU is halted and a hex based keypad programmer / bus monitor was used to program a JMP <to some address in ROM> instruction into RAM. No USART or keyboard, output was to one of those little Hitachi LCDs. The rest of the BIOS will be routines for terminal IO.
| Sun Mar 23, 2025 8:09 am |
Minux was a mini-unix, so it is kinda bigger than other os's. I also was looking at ELKS as well. This was from a time when K&R was the C standard, so porting seemed reasonable,and still 16 bit code. Floppy disks was still the norm so developing software was left to some big machine with large drives and fast printers. Sadly by the time Open Source came around you needed 24 bit addressing for any kind of code, and that is too big for what I consider a Small text based computer.
My bios will also have floating point in rom, but I need to get a basic shell written. Most of the stuff is now tweaking the system to see what works best. IRQ service needs to be revised and other logic needs to be cleaned up. By then I will have version 1 implemented, with the newer ideas left version 2 and perhaps a simple mmu.
| Sun Mar 23, 2025 11:20 am |
DockLazy
Ouch, ELKS requires 512k. All the modern minimal Unix OSs seem to require quite a bit of RAM, even FUZIX was something like 128k.
Would Unix V6 be an option? 1975, open source and 16-bit. It did use an MMU. But porting the kernel is much easier because of the J. Lions book "A commentary on the sixth edition Unix operating system".
| Mon Mar 24, 2025 3:34 am |
DockLazy wrote: Ouch, ELKS requires 512k. All the modern minimal Unix OSs seem to require quite a bit of RAM, even FUZIX was something like 128k.
Would Unix V6 be an option? 1975, open source and 16-bit. It did use an MMU. But porting the kernel is much easier because of the J. Lions book "A commentary on the sixth edition Unix operating system". They all use virtual memory, and swap to disk. Disk is slow because of all the swapping, so they make a ram disk from what little memory they have. Since this is time sharing, you need to have the fastest machine,memory and high RPM disks, To pay for all this, you needed to share the costs, thus more users. But with more users you need more virtual memory so you add a token 8Kb more RAM and the computer gets bigger and slower and slower over time. Had UNIX been really a been a un-multiplexed operating system, I might give it more thought. I went to 18 bits, so could have ample addressing space of 64kb or more for a single process, and several addressing modes for bytes and words in a single instruction word. Indexing or word immediate requires a second word of course. AT&T do have a UNIX with no MMU, but I can't remember what was called. I think FUZIX is based on that. Small C is the best I can do for now, with the file system in ROM. Going is slow because I keep changing things around, The file system is slow to write because it is in assembler.
| Mon Mar 24, 2025 8:34 am |
File systems are roughed out, and most of the code is in rom. I have hooks for subdirectories, but for now it is a single root directory of 64 files. A 8.2 file name is used, and a time stamp is planned for when I get RTC. Time is just AM,PM and a date 1970+,day,month. I get about 1.5 Mb per disk, not great but better than 8 inch floppies. Fixed a logic bug with the shift encoding.
| Wed Apr 02, 2025 6:09 am |
Revised and simplified the order code,now that I have the general encoding done. Needed to wire in the last *two* inputs to the Control CPLD frpm the bus. Now I have most of the features I wanted - now on version --- owl 1973. Most of the problems were updating the CPLD's from the wrong subdirectory, and not having the serial cable connected after changing the cards. The major change was encoding of register and index modes, and now having set of 15 GP registers plus the PC. Now that it all saved to the bit bucket, I am calling it a night.
| Mon Apr 07, 2025 5:58 am |
Joined: Sat Feb 02, 2013 9:40 am Posts: 2520 Location: Canada
Quote: The major change was encoding of register and index modes, and now having set of 15 GP registers plus the PC. 15 is a lot for 1973. 74'189 chips? I am beginning to appreciate that only a few registers can get a lot done if coding in assembler.
| Mon Apr 07, 2025 1:23 pm |
The original concept was 3 bit alu slice with 74x181 and 2 74x170 4x4 ram and other hardware on a pcb, with the fact that TTL logic was so cheap (compared to memory) you could waste a few chips. 6 -3 bit slices would make a 18 bit alu. You had 4 registers A,B,X,S and PC. Two addressing modes, # and indexed, a 6800 style cpu. This was before the cheap PCB's , so I decided to use a FPGA card to emulate the design. The FPGA card never compiled the logic correctly, so would have timing issues between code changes. It may work, it ,may not work. Some time later I decided to use SMALL C as the compiler, and that required a design change for a real stack pointer. Now with cheap PCB's, I dropped all the FPGA stuff. and moved to the more stable CPLD's. Here I am using 74X219's a non inverting 16x4 ram. The same concept of a 3 bit slice, still works with a 16x4 ram. Since this a microcoded design, the exact details are not needed for the 1973 microcode other than a 256 x 16 rom is needed. PROM's and PLA's came out in 1973. PS: I forgot I am using a more modern ALU, I need to change things for a 74181.
| Mon Apr 07, 2025 8:14 pm |
DockLazy
I'm guessing those 64-bit SRAM chips were cheaper than the equivalent TTL because they all switched to using it for their register files around that point.
| Tue Apr 08, 2025 4:36 am |
Oddly INTEL made the first 16x4 ram at about $100 each in the late 60's. TI had a 16x1 ram in the early 70's, used in the PDP-11. Around 1972 most MSI chips became common, but many suppliers had their in house, ram chips at that time. Signetics 25120 is a typical example. The NOVA computers used a TI 74172 8x2 dual port ram $40? each. Before the 1970's scratch pad core was used instead. The late 60's gave low cost (< $10 each) SSI gates but even then it was about 2 chips per bit. 1969 to 1973 really marked the growth of micro chip logic.
| Tue Apr 08, 2025 6:50 am |
Cp/m is up and running. Control Program for Mini-computers. Since most of the file calls are in rom, the shell is really small and stupid. Changes drive A or B Runs a *.SV file Now I can start getting small C working and then port the assembler.
| Thu Apr 10, 2025 7:42 pm |
Quote: Cp/m is up and running. Congrats! I thought CP/M was written in assembler for the 8080/Z80, did you port the whole thing?
| Fri Apr 11, 2025 2:14 am |
CP/M is control programs for microprocessors.(8 /16 bits) mine is Cp/m control programs for minicomputers.(9/18 bits) All the good names have been taken years ago. I want to add sub directories later so I have to use a FAT type of OS. DOS would be a option, but there is no source and it all x86 segmented. The same goes for Minix. Flex (68xx) is long gone with no source code. StarDos had source, but it all gone as well. All the small computers in the 70's other than the PDP11 or TI-990 are too limited in the instruction set and addressing modes to have well developed software and programing languages, but even then a MMU is required. There is nothing I can steal in software for me to use that generates good code. Having said that, my order code seems stable, and I can port the design for 20 bit cpu, and have good chance of it working. This will give me a bigger address space to handle bloated code sizes. Then I will have Cp/M Control programs for MainFrames. (10/20 bits) Ben.
| Fri Apr 11, 2025 3:53 am |
I decided to try porting Dunfield's C compiler, for my cpu. Stupid C standard, wants both signed and unsigned bytes. I had a spare bit around, so I am using that as a unsigned flag bit. Took all my versions from this month and backing it up to the CD rom. Ran out names , so the directory is T18 - transistor 18. Ben. PS Since I am starting from the 6809 model, I plan to add the 6809 indirection [x] as a assembler macro, using a scratch register for indirection.
| Sat Apr 12, 2025 11:44 pm |
Users browsing this forum: CCBot, Firefox-13x-bots, Firefox-151-bots and 61 guests |
