Last visit was: Fri Nov 13, 2026 11:08 pm
It is currently Fri Nov 13, 2026 11:08 pm
 [ 135 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
 Octal computers 69+
I decided to try porting Dunfield's C compiler, for my cpu.
That's a good one to adapt. I got a copy of a derived C compiler source code after purchasing a book.
Which CPU was it for?
It was a 386 version that I tried adapting to the 68000.
I have the source code for the MMURTL OS that I have studied some.
The issue with a lot of OS is they are large, with a lot of pieces to them. I have been working on one myself from time to time that I have had limited success getting to work. The latest kernel is about 9kB, but does not do too much. I have gotten as far as getting simple task switching working. I had keyboard input and text output working and could abort programs with ctrl-C. But that was a while ago.
I keep switching processors so I do not have a stable environment to be able to get it working.
One can do a lot with a decent macro capability.
Speaking of running out names, I swear I am going to start just numbering them. CPU1, CPU2, ....
Mon Apr 14, 2025 4:55 am WWW
Other the word aliment needing to be on even addresses I don't see any problems so far.
If possible have your machine be able handle data not on word boundaries, that
is biggest issue other than endian when porting something.
Mon Apr 14, 2025 8:57 am
Decided to add flags, this gives me the CMP instruction.
Needed to use the last free pin, on the CPLD for the alu sign bit.
Total dedicated input used: 4/4 (100%)
Total I/O pins used 64/64 (100%)
Total Logic cells used 125/128 (97%)
Total Flip-Flop used 43/128 (33%)
Total Foldback logic used 5/128 (3%)
Total Nodes+FB/MCells 131/128 (102%)
Total input pins 32
Total output pins 36
I hope I have no errors in the control sections
as I have no room left in the CPLD.
REGISTERS ABCD update the flags. INDEX REGISTERS WXYS can be tested
for zero/non zero but does not change flags. Shifting always sets the flags.
Op 4 (with carry bit) sets the ZF true if alu eq to zero and the ZF is true.
This I hope will make 36 bit long data TESTING practical.
LEA X' ? #
OP A X'+
OPC B X'+
Flags are updated for long data.
Hardware mods are in, I just need to burn the new control CPLD.
Wed Apr 16, 2025 6:33 am
Had to rethink how I checked the conditional logic for testing. Changed the compare logic to a true compare
and I need to revise conditional testing in what little software I have. The order code is mostly finished.
Thu Apr 17, 2025 8:34 am
Gone back a revision, so I can have a more PDP 11 like decoding, with a indirect mode.
Lots of changes needed in the software, so it will be a good day before I can test the new code.
... Later in the day
Only a partial success. I only have space for register auto indirect with the microcode I have.
Standard instructions are working, but I have not tested auto indirect yet.
Sun Apr 20, 2025 8:20 pm
Had the wrong version being edited, and only partial microcode had been added.
I have the microde in, but now I ran out of day to test the new stuff.
All my opcode holes have been filled, so I suspect other than a few tweaks I want to try
I am done. This clam is happy, but hungry.
Footnote: the clam is now fat. The tweaks had too may mods so the software crashed.
129 out 128 macrocells used.
Tue Apr 22, 2025 2:26 am
My home brew computer seems to be working but my windows 10 computer is acting up, it is in check disk start up loop. I just can't have a 2 computer household.
I was hoping to have a jump or branch for conditional logic,but that did not workout.
All other features I wanted for 18 bit data is in,but no microcode room for long instructions.
About 1/2 a PDP 11 or 1/4 a PDP K.
https://gunkies.org/wiki/PDP-K
PS: Both the PDP 11, PDP K look overly complex.
Wed Apr 23, 2025 3:45 am
I thought of alternate way to do branches, but it has a bug in the code.
I need more testing, but my pc is down.
Wed Apr 23, 2025 8:57 pm
Trust windows. Ya.
Drive E failed and but it just wanted to check C:
Found more bugs. No bug free code here, they have to pay!
Most of my time was figuring how to do a 74XX181 version vs the CPLD one.
The only really rare part is 74ls399 2/1 storage register,
Changed a register swap for a negate. The control section will use PAL's
and EEROMS. April 74 is the projected release date.
Sat Apr 26, 2025 10:26 pm
Need to change a counter from down to up.
Timing looks just possible for TTL with the slow ram/rom of the time.
74 and 74S gives me OK timing for back then,
For today I need to use 74LS and 74F parts with 7.38 MHz clock, divided by 6.
Since I don't have TTL dual port memory, I have to write the IX register to the I/O
bus and read it back in, for AC = AC op IX. This removes any option for LEA or Register swap.
Simple decoding removed a few other instructions.
Microcode is rather generic in decoding, so it is complete regardless of the alu logic used
so the only thing needing to be burned is the 2 256x8 control proms if I build a TTL version.
Sun Apr 27, 2025 4:32 pm
The current ALU board.
CONTROL 1508
  18 bit small computer
  This is a generic micocode source a 18 bit computer with
  byte addressible memory.
  This part is microcode assembler (micode.exe)
@  // enter CPLD logic compiler
  byte addressible memory. This part contains the pal logic
  and the rom lookup tables. A 74181 cpu card would use a 32x8
  prom to convert for the correct bit patterns.
  CPU model
     18          9          1
    |           :           | 0 A GP A/Z
    |           :           | 1 B GP B/B
    |           :           | 2 C GP C/C
    |           :           | 3 D GP D/D
    |           :           | 4 W IX #/W
    |           :           | 5 X IX
    |           :           | 6 Y IX
    |           :           | 7 S IX
    |                       | 4' PROGRAM COUNTER
     1
    | | SF  SIGN FLAG  SET IF MINUS / A,B,C,D
    +-+                OR SHIFT FLAGS
    | | ZF  ZERO FLAG  SET IF ZERO / A,B,C,D
    +-+                 OR SHIFT FLAGS
    | | CF  CARRY FLAG  SET IF CARRY  / A,B,C,D
    +-+                 SET ON SHIFT OUTPUT
                        OR SHIFT FLAGS
    ALU FUNCTIONS        AC   IX   IX[  SHIFT
    #   OPCODE  FUNC
    0   ST      STORE    A    A    Z    0
    1   ADD/ADC ADD      B    B    B    0
    2   SUB/SBC SUBTRACT C    C    C    C /SRF
    3   CMP/CPC COMPARE  D    D    D    S
    4   AND     AND      W    #/W  W    0
    5   OR      OR       X    X    X    0
    6   XOR     XOR      Y    Y    Y    C /SLF
    7   LD      LOAD     S    S    S    S
     876 543 210 987 654 321
    |1UO|OOO:AAA|32B|XXX:+##| AUTO
    |1UO|OOO:AAA|32B|XXX:100| INDEXED
    |0UO|OOO:AAA|###|###:###| BYTE #/NOP
           ST    OP
     0     NEG   REG B=0
     0     CTL   SCC B=1
     1     SWP   SFT 0..7
     2     JSR   JCC+ B is branch flag
     3     JSR   JCC
     4     R+    R+
     5     X+#   X+#
     6     R+    R+
     7     X+#   X+#
     40    NOP/QUICK
     50    CTL/SCC
// PROPERTY Atmel {pin_keep = off };
   PROPERTY Atmel {soft_buffer = on};
// QUICK
NAME CTL.PLD ;
PARTNO ;
DATE  2025-04-29 ;
REVISION ;
DESIGNER ;
COMPANY ;
ASSEMBLY ;
LOCATION  ;
DEVICE F1508PLCC84 ;
PINNODE     = [OP4..1,PSW,SYNC,BUSY,BOUNCE,RS,PAN1,PAN2,OK,GO];
PINNODE     = [LCTR,CC,CF,WCY,SFT,SF,ZF,TS,BRA,WF2,WF1];
PINNODE     = [SX,LD,TWO,WRD,OP,RA,RX,BYY];
PINNODE     = [Y,AUX,EF,ZLD,RK,TP,EFC,TSW,BY,WR,RD];
PINNODE     = [CTR3..1,CTL,TST,STOP,IQ,IRQ,NO,TRAP,DSP,ODD];
PINNODE     = [IR18..2,TIR,TIN,TMAR,PCL];
PIN 2       = ACK;  // PHASE 2 CLOCK (AP IN)
PIN 4       = K1;   // DATA MULX
PIN 5       = K2;   // DATA MULX
PIN 70      = K3;   // DATA MULX
            000 ZERO IN
            001 BYTE IN
            010 SEX  IN  BITS 3..1 SIGNED NUMBER
            011 TWO  IN
            101 WORD IN
PIN 8       = CP;   // PHASE 1 CLOCK OUT
PIN 9       = SHO;  // SHIFT OUT -L
PIN 25      = IRQI; // IRQ IN ACTIVE HIGH FROM 74LS14
PIN 1       = CLR;  // RESET ACTIVE HIGH FROM 74LS14
PIN 11      = SH1;  // RAM REG   00 LOAD 01 LOAD UNSIGNED
PIN 12      = SH2;  //           1X SHIFT
// PIN 10   = JAM;  // RESERVED
PIN 63      = C18;  // CARRY FROM ALU
PIN 6       = APP;   // ADDRESS CLOCK
PIN 67      = ALU3; // ALU FUNC
PIN 65      = ALU2; // ALU FUNC
PIN 64      = ALU1; // ALU FUNC
00- ADD 01- SUB
100 AND 101 OR
110 XOR 111 LOAD
PIN 27      = SWR1; // BOT   ALD  -L
PIN 28      = SWR2; // BOT+1 EXAM -L
PIN 29      = SWR3; // TOP-1 DEP  -L
PIN 30      = SWR4; // TOP   R/S  -L
PIN 31      = SWR5; // PC/AC
// UN A SIGNED NODES
PIN         = AD0; // AD7..AD0 MICRO CODE ROM ADDRESS
PIN         = AD1;
PIN         = AD2;
PIN         = AD3;
PIN         = AD4;
PIN         = AD5;
PIN         = AD6;
PIN         = AD7;
PIN         = RUN; // TRUE IF RUNING FALSE FRONT PANEL MODE
PIN         = IR;  // TRUE IF INSTRUCTION FETCH
PIN 22      = BI3; // DATA BUS INPUT 18..2 ACTIVE LOW
PIN 21      = BI2;
PIN 33      = BI18;
PIN 34      = BI17;
PIN 35      = BI16;
PIN 36      = BI15;
PIN 37      = BI14;
PIN 39      = BI13;
PIN 40      = BI12;
PIN 41      = BI11;
PIN 44      = BI10;
PIN 45      = BI9;
PIN 46      = BI8;
PIN 48      = BI7;
PIN 49      = BI6;
PIN 50      = BI5;
PIN 51      = BI4;
PIN 57      = YY;  // Y MULX FOR MAR,JAM 0 SUM 1 RAM REG
PIN 54      = MR;  // MEMORY REQUEST
PIN 55      = MW;  // MEM WRITE
PIN 56      = MB;  // MEM BYTE
PIN 52      = DK;   // DCLOCK ACTIVE HIGH READ PANEL SWITCH
                    // DISPLAY MAR
PIN 60      = MAR;  // LOAD MAR REG AND WR,BY FLAGS
PIN 61      = IN;   // LOAD INPUT
PIN 71      = CY0;  // CARRY OUT
PIN 79      = WE_;  // 219 WRITE STROBE
PIN 68      = NSGN; // SIGN BIT RAM -L
PIN 73      = BOUT; // DATA BUS OUTPUT ENABLE  WR&MR
PIN 74      = RG3;  // 219 RAM AD 3
PIN 75      = RG2;  // 219 RAM AD 2
PIN 76      = RG1;  // 219 RAM AD 1
PIN 77      = RG4;  // 219 RAM AD 4
PIN 58      = EQ;   // EQ FLAG IN
PIN 69      = NODD; // ODD BIT FROM RAM -L
PIN 81      = CI;   // 2X CLOCK
PIN 83      = CLK;  // PHASE 1 CLOCK (CP IN )
PIN 84      = NF;   // SIGN FLAG FROM SUM
 MICRO CODE STUFF
 ROM A OUTPUTS
 SH,NO,LD,RA,TWO,WRD,OP,WR
          "SX", 0X0000C  3 bit data sign extended
          "WRD",0X00004  word data
          "2"  ,0X00008  constant 2
          "OP", 0X00002  alu opcode
          "SUB",0X00002  subtract
          "WR", 0X00001  WR/rd bus flag
          "AC" ,0X00010  select ac
          "LD" ,0X00020  load operation
          "NO" ,0X00040  no load ram
 BY,RX,XIR,IN,RD,MAR,Y,AUX
          "BY", 0X08000  BY/wrd bus flag
          "Y",  0X00200  select sum/ram to mar
          "IR", 0X03000  fetch
          "IN" ,0X01000  input data
          "CTL",0X00100  control state AUX !RA !RX decode
          "TST",0X00100  test acc and jump if true to 4 AUX AX
          "DSP",0X00100  display mar and read swr AUX RX
           BRA           branch data AUX UNSIGNED
          "SFT",0X00100  shift a input
          "PC" ,0X00000  pc select
          "MAR",0X00400  load mar
          "IX" ,0X04000  rx index reg select
          "RD", 0X00800  memory request
          "SWR",0X04010  ac/pc switch display
IR          = TIR;  // intruction fetch
IN          = TIN;  // load b input reg
MAR         = TMAR; // load mar register
// alu operation
ST          = !IR15&!IR14&!IR13;
OP4         = IR16;
OP3         = IR15;
OP2         = IR14;
OP1         = IR13;
CPE         = OP&!OP3&OP2&OP1;
// front panel switches and irq
PSW.D       = SWR5;
PSW.CK      = CLK;
SYNC.D      = (!SWR1#!SWR2#!SWR3#!SWR4)&!CLR;
SYNC.CK     = CLK;
SYNC.CE     = IR;
SYNC.AR     = CLR;
BUSY.D      = SYNC&!CLR;
BUSY.CK     = CLK;
BUSY.CE     = IR;
BUSY.AR     = CLR;
BOUNCE.D    = BUSY;
BOUNCE.CK   = CLK;
BOUNCE.CE   = IR;
BOUNCE.AR   = CLR;
OK          = SYNC&BUSY&!BOUNCE;
RS.D        = !SWR4&OK;
RS.CK       = CLK;
RS.CE       = IR;
RS.AR       = CLR;
PAN1.D      = OK&(!SWR1#!SWR3)&!RUN;
PAN1.CK     = CLK;
PAN1.CE     = IR;
PAN1.AR     = CLR;
PAN2.D      = OK&(!SWR2#!SWR3)&!RUN;
PAN2.CK     = CLK;
PAN2.CE     = IR;
PAN2.AR     = CLR;
// false panel true running
RUN.D       = RUN & !STOP
            #!RUN & RS;
RUN.CK      = CLK;
RUN.CE      = IR;
RUN.AR      = CLR;
// INTERNAL TIMING AND FLIP FLOPS
// RAM STROBE
WE_.D       = !(!NO&!CPE&CP&APP);
WE_.CK      = CI;
//  INTERNAL CLOCK GEN 4 PHASE
//      START HIGH
CP.CK       = CI;
CP.AP       = CLR;
CP.D        = !APP;
// SET HIGH ON CLEAR
APP.CK      = CI;
APP.AR      = CLR;
APP.D       = CP&!CLR;
// FRONT PANEL  DK
DK          = DSP;
TP          = EF & !CTL & IQ & RUN & IR ;
BRA         = AUX & BYY;
/* MAIN IRQ ENABLE */
EF.D        = CTL & IR4 // nop nop di ei nop nop hlt-di
            #!CTL & RUN & EF & !TP;
EF.CK       = CLK;
EF.CE       = IR;
EF.AR       = CLR;
IRQ.D       = IRQI & RUN & !CTL ;
IRQ.CK      = CLK;
IRQ.CE      = IR;
IRQ.AR      = CLR;
IQ.D        = IRQ & RUN & !CTL;
IQ.CK       = CLK;
IQ.CE       = IR;
IQ.AR       = CLR;
// SELECT ALU REGISTER
RG1       = RA&!RX & IR10 & RUN
          # !RA& RX & IR4;
RG2       = RA&!RX & IR11 & RUN
          # !RA& RX & IR5;
RG3       =  RA&!RX & IR12 & RUN
          # !RA& RX & IR6
          # !RA&!RX // PC
          #  RA&RX&PSW;  // PC,AC
PCL     = !(IR6&!IR5&!IR4&!IR3);
// SELECT PC
RG4       = !RA&!RX // PC
          #  RA&RX&PSW  // PC,AC
          # !RA&RX&!(PCL#NO#IN); // IX IS PC
ZLD       = !RA&RX  &!IR6 & !IR5 & !IR4 & NO &!IN;
CTL       = AUX & !RA  & !RX & NO;
TST       = AUX & RA;
DSP.D     = AUX & RX;
DSP.CK      = ACK;
DSP.AR      = CLR;
BOUT.D      = MW&!BOUT;
BOUT.CK     = ACK;
BOUT.AR     = CLR;
// MEMORY CONTROL
// GATE BUS BYTE REQUEST
MB.D        = BY&BYY;
MB.CK       = CLK;
MB.AR       = CLR;
// WR/rd BUS REQUEST
MW.D        = WR;
MW.CK       = CLK;
MW.AR       = CLR;
// MEMORY REQ STROBE
MR.D        = RD;
MR.CK       = ACK;
MR.AR       = CLR;
STOP        = CTL&IR6
            # RUN&RS
            # RUN&!SWR1&SYNC;
LCTR        =  TST &(CC$OP4); // NORMAL TESTS
YY          = !RX & Y  //  SELECT RAM FOR OUTPUT PC++,AC++
            #  RX & Y & !IR3; // RAM FOR OUTPUT R++
CY0         = OP4 & OP & !OP3 &  OP2  & CF
            # !OP4 &  OP & !OP3 & OP2   //  SUB OPS
            # OP  & !OP3 &!OP2 &!OP1 &!OP4
            # OP  & !OP3 &!OP2 &!OP1 &OP4 & CF;// SUBTRACT
WCY         =  OP & !OP3 & (OP2#OP1) & !IR12 // ABCD ONLY
            #  OP & !OP3 & !OP2 & !OP1&!IR12 & IR; // NEG
BYY         = RUN&(!IR18#IR7);
//HLT         = RUN&!IR18&ST&!CTR2&!CTR3&IR6;
//K2          = TWO&!HLT;
K1          = WRD;
K2          = TWO;
K3          = WRD&!TWO&!(BYY&OP);
// WORD K1' SGN IN K2'
ALU1        = LD # ZLD
            #  OP &OP1;
ALU2        = LD&!BRA # ZLD
            # OP & !OP3 &!OP2 &!OP1 // SUBTRACT
            # OP & OP2  ;
ALU3        = LD&!BRA #ZLD
            # OP&OP3;
SH1         = SFT & OP3 // DOWN SHIFT RIGHT
            # IR17&OP&BYY; // UNSIGNED BYTE
// SHIFT 0..7
SH2         = SFT ;
INC         = SFT & !(IR6&IR5&IR4);
SHO         = OP2&OP1&NSGN // SHIFT OUT SIGN
            # OP2&!OP1&CF;
TS.D        = NSGN;
TS.CK       = ACK;
//          TEMP SIGN FLAG RAM 18
ODD.D       = NODD;
ODD.CK      = ACK;
WF1         =  RA & IR & !IR12 // ALU OP
            #  SFT & !OP4      // SHIFT ANY REG
            #  SFT & OP4 & OP3;// OP FLAGS DOWN
             // MOST OTHER AC OPS
            // SWAP LEAVES FLAGS UNDEFINED
WF2         =  SFT & OP4 ;     // OP FLAGS
// 0 HOLD, 1 FLAGS, 2 FLAGS DOWN, FLAGS UP
CF.D        = SFT&TS&!OP3      // SHIFT UP, CF = SIGN
            # SFT&ODD&OP3&!OP4 // SHIFT DOWN, CF = ODD
            # SFT&ZF&OP3&OP4   // SHIFT DOWN, CF = ZF FLAGS
            #!SFT&!WCY&CF
            #!SFT&WCY&C18;
CF.CK       = CLK;
CC          = (
            //  REGULAR CC
              OP1&ZF&IR17
            # OP2&SF&IR17
            # OP1&EQ&!IR17
            # OP2&TS&!IR17
            # OP3&!CF
            # OP3&OP2
// 0 HOLD
// 1 SET
// 2 UP      SF <- ZF <- CF <- RAM18
// 3 DOWN    CF -> SF -> ZF -> CF
SF.D        = NF &  WF1 & !WF2 // SUM18
            # SF & !WF1 & !WF2
            # ZF & !WF1 &  WF2
            # CF &  WF1 &  WF2;
// ALU SIGN
ZF.D        = EQ &   WF1 & !WF2 & !OP4 // NORMAL
            # EQ &   WF1 & !WF2 & OP4 & ZF // OP WITH CARRY - LONG
            # ZF &  !WF1 & !WF2
            # CF &  !WF1 &  WF2  // UP
            # SF &   WF1 &  WF2; // DOWN
// ALU ZERO FLAG
SF.CK      = CLK;
ZF.CK      = CLK;
$REPEAT N   = [2,3,7..18]
IR{N}.CK    = CLK;
IR{N}.CE    = IR;
$REPEND
IR4.CK      = CLK;
IR5.CK      = CLK;
IR6.CK      = CLK;
IR4.CE      = IR # INC;
IR5.CE      = IR # INC;
IR6.CE      = IR # INC;
IR4.D       = !BI4& !INC # !IR4&INC;
IR5.D       = !BI5& !INC # (IR5$IR4)&INC;
IR6.D       = !BI6& !INC # (IR6$(IR5&IR4))&INC;
$REPEAT N   = [2,3,7..12]
IR{N}.D     = !BI{N};
$REPEND
$REPEAT N   = [13..18]
IR{N}.D     = !BI{N}&!TP;
$REPEND
$REPEAT N   = [3..1]
CTR{N}.CK   = CLK;
CTR{N}.AR   = CLR;
AD{N-1}     = CT{N};
$REPEND
// 0..3 NORMAL PANEL
// 4..7 START  PANEL
CT1         = CTR1;
CT2         = CTR2;
CT3         = CTR3;
CTR1.D      = !LCTR & !IR & !CT1 & !INC
            # CT1 & INC;
CTR2.D      = !LCTR & !IR & (CT2$CT1) &!INC
            # CT2 & INC
            # TP;
CTR3.D      = !IR & (CT3$(CT1&CT2))
            # LCTR;
AD3         = !RUN & PAN1
            #  RUN & IR3&!IR2&IR18
            #  RUN & IR18&!IR9&!IR8&IR7; // SCC
AD4         = !RUN & PAN2
            #  RUN & IR8& IR18;
AD5         =  RUN & IR9
            #  RUN & !IR18
AD6         = !IR15&!IR14&!IR13;
// STORE
AD7         = !RUN
            # !IR18
            #RUN&IR18&!IR9&!IR8&IR7; // SCC
/ START OF MICRO CODE
    #000        / REG%   REGISTER OP'S
    PC          MAR WR  / OUTPUT IX FOR WRITE
    IX          WR IN   / READ IN
    PC 2 Y      MAR
    AC OP WRD   IR  RD
    #010        / SHIFT 0..7
                / SHIFT 1..8 TIMES
                / IR6..4 IS INCRIMENTED N-1 TIMES
    AC          MAR     / LOAD A
    AC SFT              / SHIFT A
    PC 2  Y     MAR
    PC          IR RD
    #020    /   JCC
    IX  SX  Y   MAR
    AC  TST     RD IN
    PC  2 Y     MAR
    AC          IR RD
    #024   /  MET CC
    SWR         MAR
    DSP
    PC LD WRD AUX  MAR
    PC 2        IR RD
    #030   /  JMP INDEXED
    PC 2 Y      MAR
    AC          IN
    IX NO WRD   MAR
    AC          RD IN
    PC LD WRD   MAR
    PC 2        IR RD
    #040   /   R+
    IX SX Y     MAR   BY
    AC          RD IN BY
    PC 2 Y      MAR
    AC WRD OP   IR RD
    #050    /   MEM X
    PC 2 Y      MAR
    AC          RD IN
    IX NO WRD   MAR   BY
    AC          RD IN BY
    PC 2 Y      MAR
    AC OP WRD   IR RD
    #060   /   R+
    IX SX Y     MAR
    AC          RD IN
    PC NO LD WRD MAR  BY
    AC          RD IN BY
    PC 2 Y      MAR
    AC OP WRD   IR RD
    #070    /   NOP
    PC 2 Y      MAR
    AC          RD IN
    IX NO WRD   MAR
    AC          RD IN
    PC NO LD WRD MAR  BY
    AC          RD IN BY
    PC 2 Y      MAR
    AC OP WRD   IR RD
/   STORE OPS
    #100 / NEG
    PC          MAR WR  / OUPUT IX FOR WRITE
    AC LD       WR IN   / READ IN , CLEAR IX
    PC 2 Y      MAR
    AC OP WRD   IR  RD  / AC = 0 - AC
    #110 / SWP
    IX          MAR
    AC          RD IN
    IX          WR
    AC          RD WR
    PC 2 Y      MAR
    AC LD WRD   IR RD
    #120  / JSR -S X+
    IX SX Y     MAR
    AC          RD IN
    AC 2 SUB    MAR  WR
    PC          RD   WR
    PC LD WRD AUX  MAR
    PC  2       IR RD
    #130  /JSR INDEXED
    PC 2 Y      MAR
    AC          RD IN
    IX NO WRD   MAR
    AC          RD IN
    AC 2 SUB    MAR  WR
    PC          RD   WR
    PC LD WRD   MAR
    PC 2        IR RD
    #140   /    ST R+
    IX SX Y     MAR WR BY
    AC          RD  WR BY
    PC 2 Y      MAR
    AC          IR RD
    #150    /   MEM X
    PC 2 Y      MAR
    AC          RD IN
    IX NO WRD   MAR WR BY
    AC          RD WR BY
    PC 2 Y      MAR
    AC          IR RD
    #160   /  ST R+
    IX SX Y     MAR
    AC          RD IN
    PC NO LD WRD MAR WR BY
    AC          RD  WR BY
    PC 2 Y      MAR
    AC          IR RD
    #170    /   MEM X
    PC 2 Y      MAR
    AC          RD IN
    IX NO WRD   MAR
    AC          RD
    PC LD NO WRD MAR WR BY
    AC          RD WR BY
    PC 2 Y      MAR
    AC          IR RD
/   EXTENDED OPS
    #240        /QUICK
    PC 2 Y      MAR
    AC OP WRD     IR RD
    #250    /  SCC
    AC  TST     MAR
    PC  2 Y     MAR
    AC  LD      IR RD
    #254   /  MET CC
    PC  2 Y     MAR
    AC LD SX    IR RD
    #340       / NOP
    PC 2  Y      MAR
                 IR  RD
/   TRAP
/   PC->0 PC=2
    PC SUB 2
    PC LD NO    MAR WR
    PC          RD  WR
    PC 2 LD     MAR
    PC 2        RD IR
    #350       / CTL
    PC 2  Y      MAR
    CTL  NO      IR  RD
    // PANEL OPS
    #200   / IDLE
    SWR         MAR
    DSP         IN  // DATA IN HERE
    AC
    PC          IR IN  // TOGGLE IN OFF
    #210   / LOAD ADR
    PC          LD WRD
    AC          LD WRD
    PC
    PC          IR
    #220   / READ MEM -> AC
    PC 2 Y      MAR
    AC          RD IN
    AC LD  WRD
    AC          IR
    #230   / WRITE MEM -> AC
    AC WRD    LD
    PC 2 Y    MAR WR
    AC        RD  WR
    PC        IR
    #300   / IDLE
    SWR         MAR
    AC
    #310   / LOAD ADR
    PC          LD WRD
    AC          LD WRD
    PC
    PC          IR
    #320   / READ MEM -> AC
    PC 2 Y      MAR
    AC          RD IN
    AC LD  WRD
    AC          IR
    #330   / WRITE MEM -> AC
    AC WRD    LD
    PC 2 Y    MAR WR
    AC        RD  WR
    PC        IR
                     S A  S   G A     V A C  C G   R W V R R R
                     H D  H C N P K K C C LN L N C U E C G G G
                     1 1  O P D P 2 1 C K RF K D I N _ C 4 1 2
                   / 11   9   7   5   3   1  83  81  79  77  75 \
                  /    10   8   6   4   2  84  82  80  78  76    \
             SH2 | 12                    (*)                   74 | RG3
             VCC | 13                                          73 | BOUT
             AD7 | 14                                          72 | GND
             AD2 | 15                                          71 | CY0
             AD3 | 16                                          70 | K3
             AD5 | 17                                          69 | NODD
             AD0 | 18                                          68 | NSGN
             GND | 19                                          67 | ALU3
                 | 20                                          66 | VCC
             BI2 | 21                                          65 | ALU2
             BI3 | 22                 ATF1508                  64 | ALU1
             AD4 | 23               84-Lead PLCC               63 | C18
             AD6 | 24                                          62 | IR
            IRQI | 25                                          61 | IN
             VCC | 26                                          60 | MAR
            SWR1 | 27                                          59 | GND
            SWR2 | 28                                          58 | EQ
            SWR3 | 29                                          57 | YY
            SWR4 | 30                                          56 | MB
            SWR5 | 31                                          55 | MW
             GND | 32                                          54 | MR
                  \     34  36  38  40  42  44  46  48  50  52   /
                   \  33  35  37  39  41  43  45  47  49  51  53/
                      B B B B B V B B B G V B B B G B B B B D V
                      I I I I I C I I I N C I I I N I I I I K C
                      1 1 1 1 1 C 1 1 1 D C 1 9 8 D 7 6 5 4   C
                      8 7 6 5 4   3 2 1     0
/ ALL DONE
High 1508
// APRIL 28 2025
// 74F218 RAM SH1 UNSIGNED BYTES NO JAM
// PROPERTY Atmel {pin_keep=off};
// QUICK
NAME            KAH;
PARTNO          CPLD;
REVISION        01;
DATE            april 28 2025;
DESIGNER        ;
COMPANY         ;
LOCATION        NONE;
ASSEMBLY        NONE;
DEVICE          F1508PLCC84;
/* ACTIVE LOW BUS */
PINNODE     = [FADD,FXOR,FAND,NTB,TFR];
PINNODE     = [TI9..0,TM9..1,GP9..1];
PINNODE     = [PP9..1,DI9..1,CC1..8];
PINNODE     = [REG1..9,PRO];
PIN 2       = ACK;
PIN 4       = RG4;
PIN 5       = RG5;
PIN 6       = RG6;
PIN 8       = SUM7;
PIN 9       = SUM8;
PIN 10      = SUM9;
PIN 11      = RG7;
PIN 12      = RG8;
PIN 14      = RG9;
PIN 15      = RG10;
PIN 70      = RG0;
PIN 17      = CC9;
PIN 30      = EQ;
PIN 20      = ALU3;
PIN 21      = ALU2;
PIN 22      = ALU1;
PIN 18      = K3;
PIN 69      = CC0;
PIN 27      = LMAR;
PIN 28      = SH2;
PIN 29      = SH1;
PIN 25      = LDI;
//PIN 1       = JAM;
PIN 31      = Y;
PIN 33      = BI9;
PIN 34      = MAR9;
PIN 35      = BI8;
PIN 36      = MAR8;
PIN 37      = BI7;
PIN 39      = MAR7;
PIN 40      = BI6;
PIN 41      = MAR6;
PIN 44      = BI5;
PIN 45      = MAR5;
PIN 46      = BI4;
PIN 48      = MAR4;
PIN 49      = BI3;
PIN 50      = MAR3;
PIN 51      = BI2;
PIN 52      = MAR2;
PIN 54      = BI1;
PIN 55      = MAR1;
PIN 62      = SX;
PIN 68      = EQI;
PIN 71      = SUM1;
PIN 73      = SUM2;
PIN 74      = SUM3;
PIN 75      = RG1;
PIN 76      = RG2;
PIN 77      = RG3;
PIN 79      = SUM4;
PIN 80      = SUM5;
PIN 81      = SUM6;
PIN 83      = CLK;
PIN 84      = BOUT;
TFR         = ALU3&ALU2&ALU1;
FADD        = !ALU3;
FAND        = ALU3&!ALU2;
FXOR        = !(ALU3&!ALU2&!ALU1);
NTB         = !ALU3&ALU2;
/* ACTIVE LOW INPUT */
$REPEAT N   = [1..9]
REG{N}.D    = RG{N}&!SH2  // NORMAL RAM
            # (RG{N-1})& SH2&!SH1 // SHIFT UP LEFT
            # (RG{N+1})& SH2& SH1; // SHIFT DOWN RIGHT
REG{N}.CK   = ACK;
MAR{N}.D    = Y&REG{N}#!Y&SUM{N};
MAR{N}.CK   = CLK;
MAR{N}.CE   = LMAR;
// INPUT REG BUS,SUM,MAR
TI{N}.D     = !BI{N}.IO;
TI{N}.CK    = CLK;
TI{N}.CE    = LDI;
BI{N}       = !REG{N};
BI{N}.OE    = BOUT;
$REPEND
/* ADDER */
/* 00 ADD 01 XOR 10 AND 11 OR */
$REPEAT N   = [1..9]
PP{N}       = (REG{N}$DI{N})&FXOR
        # (GP{N})& FAND;
GP{N}     = REG{N}&DI{N};
SUM{N}     = (((CC{N-1}&FADD)$PP{N})&!TFR
            # DI{N}&TFR);
$REPEND
$REPEAT N   = [1..9]
DI{N}       =  ((TI{N} & K3# SX & !K3 & !SH1)$NTB) ;
$REPEND
$REPEAT N   = [1,4,7]
CC{N}     = CC{N-1} & PP{N} # GP{N};
CC{N+1}     = (CC{N-1} & PP{N} # GP{N})&PP{N+1}#GP{N+1};
CC{N+2}     = ((CC{N-1} & PP{N} # GP{N})&PP{N+1}#GP{N+1})&PP{N+2}#GP{N+2};
$REPEND
EQ          = !SUM1&!SUM2&!SUM3&!SUM4&!SUM5&!SUM6&!SUM7&!SUM8&!SUM9&EQI;
                       S  S S              B     S S S
                     R U  U U G R R R V A  O C G U U U V R R R
                     G M  M M N G G G C C  U L N M M M C G G G
                     7 9  8 7 D 6 5 4 C K  T K D 6 5 4 C 3 2 1
             RG8 | 12                    (*)                   74 | SUM3
             VCC | 13                                          73 | SUM2
             RG9 | 14                                          72 | GND
            RG10 | 15                                          71 | SUM1
                 | 16                                          70 | RG0
             CC9 | 17                                          69 | CC0
              K3 | 18                                          68 | EQI
             GND | 19                                          67 |
            ALU3 | 20                                          66 | VCC
            ALU2 | 21                                          65 |
            ALU1 | 22                 ATF1508                  64 |
                 | 24                                          62 | SX
             LDI | 25                                          61 |
             VCC | 26                                          60 |
            LMAR | 27                                          59 | GND
             SH2 | 28                                          58 |
             SH1 | 29                                          57 |
              EQ | 30                                          56 |
               Y | 31                                          55 | MAR1
             GND | 32                                          54 | BI1
                      B M B M B V M B M G V B M B G M B M B M V
                      I A I A I C A I A N C I A I N A I A I A C
                      9 R 8 R 7 C R 6 R D C 5 R 4 D R 3 R 2 R C
                        9   8     7   6       5     4   3   2
LOW 1508
// LOW CPLD APRIL 28,2024
// 74F218 74181 encoding
// QUICK
NAME            KAL;
PARTNO          CPLD;
REVISION        01;
DATE            APRIL 28 2025;
DESIGNER        ;
COMPANY         ;
LOCATION        NONE;
ASSEMBLY        NONE;
DEVICE          F1508PLCC84;
PINNODE     = [FADD,FXOR,FAND,NTB,TFR,PAS,KK];
PINNODE     = [TI9..1,TM9..1,GP9..1];
PINNODE     = [REG1..9];
PIN 58      = BUF; // CLOCK BUFFER 2 gate delays
PIN 2       = ACK;
PIN 4       = RG4;
PIN 5       = RG5;
PIN 6       = RG6;
PIN 8       = SUM7;
PIN 9       = SUM8;
PIN 10      = SUM9;
PIN 11      = RG7;
PIN 12      = RG8;
PIN 14      = RG9;
PIN 15      = RG10;
PIN 16      = RG0;
PIN 17      = CC9;
PIN 18      = EQ;
PIN 20      = ALU3;
PIN 21      = ALU2;
PIN 22      = ALU1;
PIN 23      = SX;
PIN 24      = CC0;
PIN 27      = LMAR;
PIN 28      = SH2;
PIN 29      = SH1;
PIN 25      = LDI;
//PIN 1       = JAM;
PIN 30      = Y;
PIN 31      = CCLK;
PIN 33      = BI9;
PIN 34      = MAR9;
PIN 35      = BI8;
PIN 36      = MAR8;
PIN 37      = BI7;
PIN 39      = MAR7;
PIN 40      = BI6;
PIN 41      = MAR6;
PIN 44      = BI5;
PIN 45      = MAR5;
PIN 46      = BI4;
PIN 48      = MAR4;
PIN 49      = BI3;
PIN 50      = MAR3;
PIN 51      = BI2;
PIN 52      = MAR2;
PIN 54      = BI1;
PIN 55      = MAR1;
PIN 71      = SUM1;
PIN 73      = SUM2;
PIN 74      = SUM3;
PIN 75      = RG1;
PIN 76      = RG2;
PIN 77      = RG3;
PIN 79      = SUM4;
PIN 80      = SUM5;
PIN 81      = SUM6;
PIN 83      = CLK;
PIN 84      = BOUT;
PIN [69,70] = [K2,K1];
FADD        = !ALU3;
FAND        = ALU3&!ALU2;
NTB         = !ALU3&ALU2;
$REPEAT N   = [1..9]
REG{N}.CK   = ACK;
MAR{N}.CK   = CLK;
MAR{N}.CE   = LMAR;
TI{N}.CK    = CLK;
TI{N}.CE    = LDI;
BI{N}       = !REG{N};
BI{N}.OE    = BOUT;
$REPEND
/* ADDER */
$REPEAT N   = [1..9]
          # (GP{N})& FAND;
            # DI{N}&TFR);
$REPEND
// LOW
//          K1 !K2   PASS WORD
//          K1  K2   PASS SX (3 bits)
//         !K1 !K2   0
//         !K1  K2   2
PAS         = K1&!K2; // WORD PASS
DI1           = ((K1& TI1)$NTB);  // PASS INPUT
DI2           = ((!K1 & K2  //  CONSTANT 0 or 2
            # K1& TI2)$NTB);  // PASS INPUT
DI3         = ((K1& TI3)$NTB);  // PASS INPUT
KK          = K1 & TI3;  // SIGN EXTEND
$REPEAT N   = [4..9]
DI{N}       =  ((TI{N} & PAS # KK &!PAS)$NTB);
$REPEND
$REPEAT N   = [1,4,7]
$REPEND
EQ          = !SUM1&!SUM2&!SUM3&!SUM4&!SUM5&!SUM6&!SUM7&!SUM8&!SUM9;
SX          = TI9 & PAS # KK &!PAS;  // BIT #9 OR BIT #3
BUF         = !CLK; // DELAY x 1
CCLK        = !BUF.IO; // BUFFERED CLOCK OUT DELAY X 2
                       S  S S              B     S S S
             VCC | 13                                          73 | SUM2
             RG9 | 14                                          72 | GND
            RG10 | 15                                          71 | SUM1
             RG0 | 16                                          70 | K1
             CC9 | 17                                          69 | K2
              EQ | 18                                          68 |
             GND | 19                                          67 |
            ALU3 | 20                                          66 | VCC
            ALU2 | 21                                          65 |
              SX | 23               84-Lead PLCC               63 |
             CC0 | 24                                          62 |
             LDI | 25                                          61 |
             VCC | 26                                          60 |
            LMAR | 27                                          59 | GND
             SH2 | 28                                          58 | BUF
             SH1 | 29                                          57 |
               Y | 30                                          56 |
            CCLK | 31                                          55 | MAR1
             GND | 32                                          54 | BI1
                        9   8     7   6       5     4   3   2
schematic
PS i have few spare PCB's around, it you want to build one.
Wed Apr 30, 2025 5:56 pm
Busy with domestic stuff this week, so I have not time to revise the BIOS,
Programs now start at 0x01000 (4096). This lets me have some 512 byte buffers for files.
I/o is small magnetic tape, like DEC tape ~ 250Kb, 1 file per tape at the moment, or virtual unit record
equipment.
PS, 7 bit ascii text files. High bit is tape mark of some kind.
Sat May 17, 2025 5:38 pm
Oh, have you managed to construct and connect some kind of tape drive?
Sun May 18, 2025 6:21 am
I wish I could have a 7 track drive.
I can many kinds of emulated devices(reader/punch,tape) on the micro-SD card, as the block I/O works now.
The interface is really simple as I don't need any kind of directory. Once this is tested and working
I will have a X-modem program written to transfer data.to and from the pc.
I can add later a directory file system, with up to 31 files.
Sun May 18, 2025 7:42 am
What about those old eight-track tape players? Could one be adapted?
Mon May 19, 2025 4:45 am WWW
Users browsing this forum: Amazonbot, CCBot, Chrome-12x-bots, chrome-9x-bots, trendictionbot, Version17-old-iOS and 24 guests
