Last visit was: Sun Nov 15, 2026 6:02 am
It is currently Sun Nov 15, 2026 6:02 am
robfinch wrote: Quote: I wish I could have a 7 track drive. What about those old eight-track tape players? Could one be adapted? I thought about that in the 80's when I had z80 computer, but the computer died due to a power supply failure, before I could find a drive. The main reason I am emulating tape, is that is I don't need a file directory like disk but have a simple stream of text data ended by a EOF. A tape mark indicates a file name, and the next file block #.
| Mon May 19, 2025 7:47 pm |
I am trying a version with, fictional dual 8" floppies. 80 track, GCR 6 sectors of 768 9 bit bytes. This works out to 360Kb per disc, with a 480 byte fat table. PS. I just realized that memory is in words, not bytes so I need to have 32kb blocks with 4k dram and 12+ slots on the mother board, ~ 1975. This lets me have 64Kb memory program and 24K +rom for the OS and buffers,
| Fri May 23, 2025 4:37 am |
Quote: I am trying a version with, fictional dual 8" floppies. 80 track, GCR 6 sectors of 768 9 bit bytes. This works out to 360Kb per disc, with a 480 byte fat table. Is that the same number of sectors per track? Or does it vary based on distance from the centre? IIRC Commodore disk drives varied, increasing the sectors per track further out. But that was '80s. Does mean the read amplifiers need to be more flexible. Quote: I just realized that memory is in words, not bytes so I need to have 32kb blocks with 4k dram and 12+ slots on the mother board, ~ 1975. This lets me have 64Kb memory program and 24K +rom for the OS and buffers,
Is this for something similar to an S100 type bus? 12 slots seems like a decent sized computer. Mini? computer.
| Sat May 24, 2025 8:18 am |
robfinch wrote: Quote: I am trying a version with, fictional dual 8" floppies. 80 track, GCR 6 sectors of 768 9 bit bytes. This works out to 360Kb per disc, with a 480 byte fat table. Is that the same number of sectors per track? Or does it vary based on distance from the centre? IIRC Commodore disk drives varied, increasing the sectors per track further out. But that was '80s. Does mean the read amplifiers need to be more flexible. Quote: I just realized that memory is in words, not bytes so I need to have 32kb blocks with 4k dram and 12+ slots on the mother board, ~ 1975. This lets me have 64Kb memory program and 24K +rom for the OS and buffers,
Is this for something similar to an S100 type bus? 12 slots seems like a decent sized computer. Mini? computer. My block device reads 512 8 bit bytes, or 256 16 bit words. I use 9 bits of the 16 bit word for one byte of data, thus 1 sector is 256 9 bit bytes. Using 256 9 bit sectors,I play to see what fits on 8 bit media. I use block numbers rather than head/track/sectors so IO is abstract rather real devices. For a small computer, you had DECTAPE,8 " floppies or a IBM 2315 disk cartridge. The only file system I can use is FAT style file system for the simple reason I have a Algorithm for it, and I can write it assembler so I can boot strap the system. This I need to play with numbers in how to fit it all. Since I am emulating a retro design, I want to keep the technology in the 70's ballpark, thus 12+slots and 20 amp power supply. I would like to use CP/M but I don't know how the internal stuff works.
| Sat May 24, 2025 6:26 pm |
Roughed in the code the code for a FAT file system. Arggg code bloat make that, a FIT file system. I now use 4K? of ROM and 24 Kb of ram, mostly the fat table and block buffers.. Reading about the early Algol compilers and every thing used Mag Tape, and the machines ran off drums, I may develop another language rather than small-c, that takes up too much space.
| Tue May 27, 2025 5:38 pm |
After reading a bunch of PDP-8 programs, I decided to add a increment/decrement instruction and remove the indirect instructions and rearrange microcode decoding. Jump always jumps regardless of the sense bit. I am writing a very tiny subset of C, as a two pass compiler,Pass one will do simple string processing and pass 2 the real compiler. I hope to be-able to generate ROM able code so I can write a file system. Doing it in assembly is taking too long to revise,
| Sun Jun 01, 2025 4:37 pm |
Quote: After reading a bunch of PDP-8 programs, I decided to add a increment/decrement instruction and remove the indirect instructions and rearrange microcode decoding. Jump always jumps Is your CPU similar enough to the PDP8 to make porting programs easy? I am thinking about small file systems too. But written in 68k assembler, or possibly C. 'C' code takes two or three times as much space though.
| Mon Jun 02, 2025 4:16 am |
robfinch wrote: Quote: After reading a bunch of PDP-8 programs, I decided to add a increment/decrement instruction and remove the indirect instructions and rearrange microcode decoding. Jump always jumps Is your CPU similar enough to the PDP8 to make porting programs easy? I am thinking about small file systems too. But written in 68k assembler, or possibly C. 'C' code takes two or three times as much space though. My cpu is more modern,I have a SUBTRACT instruction. I have byte addressable memory, but all the PDP's other than the 11 are word addressable machines, thus I can't even emulate one. The problem is still the chicken and the egg one, every thing needs a full blown C compiler, to write A C compiler and or a OS. Ben. As side note I got the first pass of my compiler working,the easy part, ask for files to compile and generate a output file.
| Mon Jun 02, 2025 10:34 pm |
Cleaned up the IRQ service and fixed halt. Replaced LEA with SWP a (x). This gives me a atomic instruction for later use.
| Sun Jun 08, 2025 4:59 am |
oldben wrote: Cleaned up the IRQ service and fixed halt. Replaced LEA with SWP a (x). This gives me a atomic instruction for later use. Somehow a bug with subroutine calls crept in. Rolled back the extended op codes to NOP's and simple IRQ, Cannot resume after halt.Slowly updating the bios for file IO.
| Thu Jun 12, 2025 5:32 pm |
More revising of the microcode for size. The build now seems stable. Running a test program over night here. N bottles of beer...
| Mon Jun 16, 2025 4:49 am |
This version looks stable, for 74181 order code. Now trying a version with a 2901 order code. Note a real 2901 can't be used for 18 bits, This adds 3 more chips per 4 bit data path, 13 chips total? Found the bug, a bad memory buffer sometimes not outputting valid data.
| Tue Jun 17, 2025 2:20 pm |
May have timing issues with 68B50 ACIA, I have to recheck schematics and programmable logic timing, Changed from a 5 mhz clock, to 4.9152 Mhz for better serial timing.
| Thu Jun 19, 2025 5:50 am |
Quote: May have timing issues with 68B50 ACIA, I have to recheck schematics and programmable logic timing, Changed from a 5 mhz clock, to 4.9152 Mhz for better serial timing The 68B50 is a 2 MHz bus device. Looking at a old spec, it says the max data clock rate is 1.5 MHz. Are you driving the 4.9152 MHz clock directly into the 68B50?
| Thu Jun 19, 2025 5:00 pm |
The 4.9 mhz clock is divided by 4, to get the E clock for the 6850, for a 6800 style bus. I had a timing issue somewhere and the 6850 stops working (5 mhz clock - 1.25 mhz bus).
| Thu Jun 19, 2025 7:48 pm |
Users browsing this forum: CCBot, ExaSearchBot, Firefox-147-bots, SemrushBot, Version18-old-iOS and 30 guests |
