Last visit was: Mon Sep 07, 2026 12:24 am
It is currently Mon Sep 07, 2026 12:24 am
 [ 135 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
 Octal computers 69+
Added a few more features for a stack (algol) architecture.
LDP push AC and loadAC. A microcode hack that sets a psh flag,pushes ac,then clears flag for a normal load.
STI store indirect.SWT swap top of stack is planned.
Fri Jun 20, 2025 6:39 am
Added two indexing operations, ATX (Add 2 * index),AFX (Add 4 * index) to simply array indexing.
I needed to make a hardware mod for this. Now PIP-69, as it has instruction set for what a one pass Algol Compiler
might need. Lea and Display operations are too complex to include.
Tue Jun 24, 2025 10:18 am
Replaced STI with NOP, and SWT with SWP.
Renamed PIP69 to PIP73.
Fri Jun 27, 2025 7:08 pm
STI=?
When I see STI I think set interrupt mask, or store immediate. One can get by without a set/clear interrupt if it can be done in the interrupt controller.
SWT=?
SWP=?
And what are the PIP's?
I think the routing junctions in the FPGA are called PIP's.
Wed Jul 02, 2025 2:42 am WWW
STI - Store indirect. ((R+)) = AC
PIP programed information processor, almost like PDP...
Made the interrupt enable a counter, 0,1,2 if EI increment counter, DI decrement counter.
Irq's are enabled if the counter is 2. This way I can have atomic instructions one level deep.
Wed Jul 02, 2025 6:44 am
Slide deck here explains a lot of FPGA implementation and terminology
https://magic3007.github.io/data/talks/ ... slides.pdf
(maybe a bit specific to Xilinx)
Wed Jul 02, 2025 6:48 am
Got the new alu card pcb in with all the pcb patches fixed, and it does not read or write memory.
I plan to remove all the wire patches off the working ALU pcb, and revise the order code removing the need for pcb patches.
Tue Jul 08, 2025 11:17 am
I got a strange bug, reading a 8 on a octal display.
Time to call it a day for debugging.
Wed Jul 09, 2025 7:01 am
Wow! What a coincidence. I got an 8 bug too. Displaying on the screen, supposed to be the core number.
Anybody else get an '8' bug?
Is the decimal point lit up too? (If there is one).
Wed Jul 09, 2025 10:09 am WWW
core 0 then core 4 then core 0 ...
only on power off.
Wed Jul 09, 2025 5:14 pm
only on power off.
Fixed my bug, output driver not driving output.
Changed to a different pin on the CPLD.
Now just why is my power off led not lighting?
Thu Jul 10, 2025 12:26 pm
Decided to rebuild the alu board with new caps (50% larger)
Only 1 wire mod to the PCB. (old pcb version)
PCB china $20 1x
small parts $75 digikey
atf1508as $25 china 2 month delivery
74ls219 $25 china 1 month delivery
right angle header $5 (1 on hand)
total $150 not counting shipping
Thu Jul 10, 2025 11:29 pm
Added back some more features, mostly just see it it would fit in the CPLD,
ATX Add 2 x index reg.
SWP ac with (R). Almost all my opcode space is filled.
Come 3 am I will have more ideas to try.
Sat Jul 12, 2025 3:46 am
SWP (swap) fits in the CPLD but it has a timing issue and it crashes after a few moments.
After about 110 or macrocells the system is unstable,
(Need to add ' Windows Crashed,sending error log file to APPLE' )
Replaced SWP with HLT, and now you can continue after a HLT.
108 macro cells.
 JULY 2025
    ALU FUNCTIONS        AC   IX  CC   SHIFT
    #   OPCODE  FUNC
    0   ST      STORE    A    A  0     0
    1   ADD/ADC ADD      B    B  z     0
    2   SUB/SBC SUB A-B  C    C  s     C /SRF
    3   CAD/CAC SUB B-A  D    D  s+z   S
    4   AND/ATX AND      W    #/W ~c   0
    5   OR      OR       X    X  ~c+z  0
    6   XOR     XOR      Y    Y  true  C /SLF
    7   LD      LOAD     S    S  true  S
     876 543 210 987 654 321
    |1YO|OOO:AAA|32I|XXX:+##| AUTO/INDEXED
    |0YO|OOO:AAA|###|###:###| BYTE/CTL
    |1-O|OOO:AAA|001|###:...| SHIFT 0..7 is limit
    +-----------------------+ counter incriments
    760 000 rom
    776 000 bootstrap
    777 xxx io
           ST      OP
     0     HLT     REG/SCC
     1     NOP     SFT #
     2     JSR     JCC+
     3     JSR     JCC
     4     R+      R+
     5     X+#     X+#
     6     R+      R+
     7     X+#     X+#
     TRAP DI,push PC,PC = 2
 APRIL 2024
     6  5   4   3   2   1
  |BYO:OOO:321|AAA|XXX:+##| NORMAL
   7   4+                   ROM
   7   7                    IO
        OP         SH   op    store
     0    ST   SUB     NOP   SFT  1x
     1    ADD  ADD  Z SCC   SCC
     2    SUB  SUB  C R+    R+
     3    CAD  SBR  S X+#   X+#
     4    LD   OR      JSV+  CTL
     5    OR   OR  Z LEA   #.
     6    AND  AND  C JCC+  JCC+
     7    XOR  XOR  S  -     REG%
Alu card.
Sun Jul 13, 2025 2:21 am
Forgot about increment, decrement memory so I added that in.
Having some build issues, so I am running my test program.
Have 97203 ROOT BEER Bottles ... May take a while.
16 bitters 9,999 bottles only.
Tue Jul 15, 2025 6:35 am
Users browsing this forum: CCBot, chrome-136-bots, Chrome-14x-bots and 9 guests
