Last visit was: Wed Oct 07, 2026 10:39 am
It is currently Wed Oct 07, 2026 10:39 am
 [ 18 posts ]  Go to page Previous  1, 2
 TTL 8-bit/24-bit modified 6809/6309 Instruction Set Computer
Interrupts are checked on instruction fetch. The currently executing instruction adds to the latency, so it could be 40 cycles + interrupt handler cycles.
I'm thinking more efficient address generation is worth the cost. Hopefully there will be enough spare microcode control lines to include an address adder.
Thu Apr 24, 2025 1:06 am
n this case each byte would take a couple of cycles to calculate the address and one cycle to read/write memory. So it could take almost 40 cycles to move all eight registers. I think this will add too much interrupt latency. So I'm going to use individual push/pop instructions for every register.
How fast is the clock? If it is fast enough having greater latency may not be an issue. For instance, at 10 MHz the instruction can take 10x as many clocks and still have the same latency as at 1 MHz.
Thu Apr 24, 2025 1:51 am WWW
Clock will probably be around 4Mhz. So around 10us latency. Going with individual push/pop instructions will be slower but will decrease interrupt jitter.
I've been thinking about ditching interrupts, as polling probably makes more sense for a peripheral processor.
Fri Apr 25, 2025 3:11 am
Users browsing this forum: CCBot, Firefox-135-bots, Version17-old-iOS and 53 guests
