 [ 6 posts ]
 Gate Singular - build a computer from NAND logic gates only
Hi all. We're the team behind Gate Singular a logic gate simulator game.
We wanted a logic sim we could play with friends and build anything in, from a single latch up to a whole computer. The games we tried weren't realistic enough or fast enough for what we had in mind, so we wrote our own.
In this game, NAND is the only logic gate. NOT, XOR, latches, adders, RAM and the CPU are all build directly from NANDs. The simulator has no gate delay, so whole circuit settles within half of the clock, (including even complext feedback loops).
The biggest thing we've built in it so far is a 16-bit computer.
Specs:
- 16-bit CPU with 24-bit instructions (8-bit opcode + 16-bit data)
- 24-bit instructions: a 3-bit field picks the sources and the destination (A, B, an immediate, memory at an address, or memory pointed to by A or B), a 5-bit field picks the operation, and the last 16 bits are the operand. Implemented 30 instructions (206 including the variants of where operands come from and where the result goes).
- 1 KB of RAM and 24 KB of ROM in a shared address space, 2 registers, a 16-level stack, an 8-entry keyboard event queue, and a 64x64 screen with write-only VRAM
- Every instruction, including multiplication and division, runs in one clock
- Everything is made from 909191 NANDs. On top of that there are only buttons/toggles/LEDs and clock sources for temporal completeness. Nothing else is used.
- One instruction is executed per clock. Instruction in read while the clock is low, and executed when it goes high
- Program ROM: rows of switches, filled with binary code using hex editor
It runs OS that lives in the 24 KB ROM. It has a file system (in RAM), a text editor, memory management, an assembler to build new programs, and an OS API that those programs can use: text printing, memory allocation, file system access, keyboard input, etc. Commands include ls, ed, cat, rm, asm, run and others. Below is Hello World after it's been written in ed and assembled into executable:
Happy to answer anything about the CPU, the simulator, anything. If you want to try the simulator yourselves, the game is here: https://store.steampowered.com/app/5402 ... ce=anycpu1
Sun Nov 08, 2026 2:22 pm
Division in a single clock? That's extraordinary!
Sun Nov 08, 2026 8:22 pm
We basically unwrapped a loop in the algorithm, and made 16 cascades of subtractions/shifts/etc stacked sequentially on top of each other.
Since the game guarantee all gate logic to settle within one clock level (even in case of feedback loops), there is no problem with gate HW physical delay here. In reality that would mean slow enough CLK to ensure all gates to settle.
Mon Nov 09, 2026 1:03 am
Thanks - that makes sense - in this world rather in the physical world! Normally that would be far too expensive in clock speed and chip area.
Mon Nov 09, 2026 7:44 am
Real gate delays I think are needed as possible upgrade as a 1 unit delay as fan in and logic routing times.
1 unit for the logic for every 5 inputs, and 1 unit for every 3 gates between outputs and inputs.
logic delays are needed to model flip flops correctly at a gate level or porting from the virtual to the physical.
Fri Nov 20, 2026 1:25 am
Good point, delays indeed matter for timing and porting to physical hardware. For logic itself, Gate Singular models flip-flops correctly without them: every tick, the whole circuit settles to a stable state, feedback included, so latches and master-slave flip-flops behave as they should logically. It was a deliberate choice to let player create and debug players logic, rather than work on timing races, and no NAND gets a hidden 1-tick delay, which would effectively give every gate its own little built-in flip-flop.
Sun Nov 22, 2026 5:48 am
 [ 6 posts ]
