mercury0x000d
I'll have to add some buses then! The next revision should be a little cleaner.
Wed Jul 30, 2014 4:02 am |
mercury0x000d
Dr Jefyll wrote: Doh! -- sorry. The concern I raised about putting the DUART on D15-D8 was unfounded. What you've done is perfectly OK. (On some processors it would mean the DUART data would appear in D15-D8 of the register, and that would be a nuisance coding-wise.) On the bright side, checking this issue gave me a chance to drag out my decades-old Motorola Microprocessors Data Manual. I'm always glad to have an excuse to go thumbing through that venerable tome. When I thought it through in my head it seemed like it would be okay, but I wasn't sure. I know you guys have a lot more experience at this stuff than I! By the way... anything in there of particular interest on the '060?
Wed Jul 30, 2014 4:04 am |
mercury0x000d
I know the purpose of VCC/VDD/VEE/VSS (meaning I read the appropriate Wikipedia article lol) but I don't know what significance the difference is to Eagle. For example, I want DTACK grounded in the dev board, so I connected it to the ground symbol only to have Eagle complain. I tried connecting it to a common pin along with other things which need grounded. More complaints. Only when I tied DTACK to VSS did I hear no protesting from the software. Does it matter? Can't I just tie everything to GND and override the errors and warnings? Or is there some significance I'm missing here?
Wed Jul 30, 2014 4:08 am |
barrym95838
mercury0x000d wrote: ... I want DTACK grounded in the dev board ... Sorry for drifting a bit here, but have you checked out this eccentric news letter? http://www.easy68k.com/paulrsm/dg/I read somewhere that Hal is no longer with us, but his voice still comes through loud and clear in these great articles, at least for me. Mike
Wed Jul 30, 2014 5:03 am |
mercury0x000d
barrym95838 wrote: mercury0x000d wrote: ... I want DTACK grounded in the dev board ... Sorry for drifting a bit here, but have you checked out this eccentric news letter? http://www.easy68k.com/paulrsm/dg/I read somewhere that Hal is no longer with us, but his voice still comes through loud and clear in these great articles, at least for me. Mike No need for an apology! I have read through those, and indeed they're full of the author's unique perspective on things. I think he and I would have gotten along well.
Wed Jul 30, 2014 5:48 am |
mercury0x000d
Just to show I haven't been being lazy...
Tue Aug 05, 2014 4:02 am |
mercury0x000d
I'm a bit confused on how I should tie the PS/2 ports into the DUART. Has anyone done this before? Soon as this part gets wrapped up, I'm just about ready to start designing the board.
Sun Aug 17, 2014 1:23 am |
I think there's some subtlety needed for PS/2. Some references http://www.computer-engineering.org/ps2protocol/http://www.pyroelectro.com/tutorials/ps ... heory.htmlNote that there's a clock, so a UART might not be what you need. Looks like most solutions use bit-banging - either using the main processor or a subsidiary embedded processor like an AVR. http://codeandlife.com/2013/06/28/minim ... ttiny2313/Cheers Ed
Sun Aug 17, 2014 9:39 am |
mercury0x000d
Okay, that makes sense. I wasn't sure if it could be interfaced directly to the DUART or no. Do you think it could be bit-banged using the auxiliary I/O pins of the DUART? Speaking of which, is there a chip in existence which takes, say, an address in and provides an array of bit outputs? Kinda like an addressable shift register.
Mon Aug 18, 2014 1:58 pm |
Mon Aug 18, 2014 2:07 pm |
mercury0x000d
Actually, I don't think the DUART I/O pins will work because the PS/2 communication is bidirectional and the DUART has separate input and output pins. The Adafruit module is nice, but I'd prefer not to rely on third-party assembled parts although it sure would make things simpler. Ugh, decisions...
What do you think about using a BASIC Stamp as an assistant I/O processor?
Mon Aug 18, 2014 3:09 pm |
stefanberndtsson
mercury0x000d wrote: Actually, I don't think the DUART I/O pins will work because the PS/2 communication is bidirectional and the DUART has separate input and output pins. The Adafruit module is nice, but I'd prefer not to rely on third-party assembled parts although it sure would make things simpler. Ugh, decisions...
What do you think about using a BASIC Stamp as an assistant I/O processor? I'd go for an AVR or a PIC, or even an Arduino (for example a pro mini). My guess is that you'll get far better timing control with one of those compared to a BASIC Stamp.
Mon Aug 18, 2014 3:14 pm |
mercury0x000d wrote: Actually, I don't think the DUART I/O pins will work because the PS/2 communication is bidirectional and the DUART has separate input and output pins. According to a quick look at the DUART data sheet at http://www.jameco.com/Jameco/Products/P ... 464958.pdf, its general-purpose outputs can be configured as open-drain; so then you would pair it with an input, ie, have both an input pin and an output pin on the same line. The open-drain output can pull the line down at any time, but the input can read the line at any time too. Quote: What do you think about using a BASIC Stamp as an assistant I/O processor? Echoing Ed's comment, microcontrollers can support functions like that where you don't need tight control of the timing, but I think the BASIC Stamp will be much too slow. You'll probably want one of the uC's he mentions, programmed in assembly or at least compiled from a higher-level language that gets turned into assembly.
Mon Aug 18, 2014 7:05 pm |
mercury0x000d
Thanks, guys. Great info as always What you pointed out on the 68681 never occurred to me! That would make for a quite easy to implement this function, but I think to save processing time and gain experience I'll just start experimenting with AVRs now. I know I'll need one for the 68060 board anyway, so why not? I found something called Great Cow BASIC which compiles QBASIC-like syntax down into AVR assembly, which will fit in nicely with the project's newbie-friendliness
Tue Aug 19, 2014 1:36 am |
Dr Jefyll
mercury0x000d wrote: Speaking of which, is there a chip in existence which takes, say, an address in and provides an array of bit outputs? Kinda like an addressable shift register. 74xx259 has eight individually-addressable bits. http://www.nxp.com/documents/data_sheet/74HC_HCT259.pdf-- Jeff
Wed Aug 20, 2014 2:35 am |
Users browsing this forum: SemrushBot and 7 guests |
