AnyCPU
http://anycpu.org/forum/
CS01
http://anycpu.org/forum/viewtopic.php?f=23&t=615
Page 2 of 8
Author:  robfinch [ Fri Jul 12, 2019 3:08 am ]
Post subject:  Re: CS01
After modifying the soc to use the amba bus, I decided to shelve it and stick with the WISHBONE bus.
Author:  robfinch [ Sat Jul 13, 2019 4:42 am ]
Thinking that maybe the uart woes are due to the baud generator which used a harmonic synthesizer, the baud generation was switched to use a clock divider. The baud reference clock is 200MHz so some of the higher baud rates are off by a few percent. It also isn’t practical to go beyond 921600 in an FPGA. Having changed the uart to support this I found out it didn’t make a difference. The baud rate was still off by a factor of about 8. Well, I finally checked the input clock to the FPGA and found that the input to the clock generator was set to 100MHz when it should have been 12 MHz. The whole system was running 8.33x too slow. It seems to work now. 6551 compatible uart.
Author:  BigEd [ Sat Jul 13, 2019 8:35 am ]
Hurrah!
Is the conclusion that WISHBONE is the simplest and best choice for educational use? Good to know.
Author:  robfinch [ Sun Jul 14, 2019 3:42 am ]
I’m not sure that it would be any better than the AXI bus, but it has fewer signals to it. I coded an AXI version of the soc and there seemed to be about 3x the code for bus interfacing, which maybe isn’t the best if one is trying to read through and understand things. In truth the AXI bus didn’t seem that hard to understand. It might be approachable by looking at one bus at a time because they all operate similarly. Some of the state might seem confusing to someone new though. Having separate read and write address busses with their own valid and ready signals is interesting. The bus is organized to support pipelined burst accesses. But what’s a pipeline again? What’s a burst access?
If building a system with a gui tool it may not matter how complex the bus really is, if it’s abstracted well. But when one starts to look at details…. And try and convince an interested student not to look at details…
WISHBONE has its own set of complexities. It too can support burst accesses. It was designed to be a “free” bus, no license required. It can be simplified to “send out an address and data and wait for an ack back”.
I liked the MOS 65xx/68xx bus for simplicity. “Send out address and data” assume it works. A simple synchronous bus is maybe the easiest to understand.
Author:  BigEd [ Sun Jul 14, 2019 6:53 am ]
Thanks - good points all! I had a quick look at AMBA and AXI and I begin to see what you mean! Good to see that they are open standards though. Very many years ago we used a valid-hold interface, which seems to be logically the same as AXI's valid-ready, but with a bit of additional cognitive load (hold being not-ready) that turns out to be unnecessary. This was at Inmos, and AFAIR the idea came from a chap who came from Anamartic. I wonder if there's a direct inheritance along the line.
Author:  robfinch [ Tue Jul 16, 2019 5:09 am ]
I wonder if the additional cognitive load was due to patents and copyrights. Can a bus be patented / copyrighted? There are only so many sensible ways to implement one.
Spent some time updating the bc6522 code written originally in 2004 to a via6522. Extended the core to operate with 32-bits. The core was desired for gpio interfacing to leds and buttons for CS01. via6522 has an extra timer associated with it (3 timers total) and 32-bit I/O ports.
I downloaded LLVM with the idea of using it as a toolset to compile and assemble riscv programs. I got the most recent release but I don’t see any riscv tools. It'll take me a while to wade through.
Author:  robfinch [ Wed Jul 17, 2019 3:47 am ]
Got floating-point test vectors from https://www.research.ibm.com/haifa/proj ... eeets.html
I ran a conversion on the test vectors to a format usable by the test benches.
After running the test vectors for the fused-multiply add I have some doubts. Many of the results are the same, but many are not.
Example:
r-----res----=-----a----*-----b-----+----c-----
0_151dbe9d_6d000000_804aa000_151dbe9d (converted from IBM)
0_ad954000_6d000000_804aa000_151dbe9d (results from test bench)
I hand calculated the above using a calculator and it looks like the results from the test bench are correct, but the result in the converted file isn’t. I’m guessing it’s a glitch in the file conversion.
Example 2:
0_98000080_cf800000_80000800_81000000   <= test vector
0_0a7ffc00_cf800000_80000800_81000000   <= test bench
The test bench result appears to be correct when hand calculated.
Example 3:
-Inf * -Nan
0_ff800000_ffffff00_ff800000   <= test vector
0_7fffff00_ffffff00_ff800000   <= test bench
Test bench returns +Nan, test vector shows -Inf.
Example 4:
-denormal * +Inf
0_7f800000_80000100_7f800000   <= test vector indicates +Inf
0_ff800000_80000100_7f800000   <= test bench indicates -Inf
I expected there would be some cases which were different, but the files are substantially different.
Author:  robfinch [ Sat Jul 20, 2019 3:43 am ]
Started working on a small monitor program for CS01. I looked on the web for such a thing and couldn’t find anything. All it has to be able to do is typical monitor commands, dump memory, dump registers, execute code, enter in memory bytes that sort of thing. All I could find were attempts to get LINUX and similar things running on RISCV. It also needs to be written in assembler code as the compiler isn't working yet.
Author:  BigEd [ Sat Jul 20, 2019 6:25 am ]
Might be worth a look at the monitor program used in the OPC series, written by Dave (hoglet) as a somewhat extended loose port of Bruce Clark's c'mon:
https://github.com/revaldinho/opc/blob/ ... /monitor.s
http://biged.github.io/6502-website-arc ... m/cmon.htm
Author:  robfinch [ Sun Jul 21, 2019 4:25 am ]
I was able to get a simple dump memory command to work after fixing a bug in the shift instructions.
The shift instructions weren’t picking up the constant shift amount from the instruction register; they were pulling the value from the previous value of the immediate field. This bug manifested itself as improperly output hex bytes.
A bunch more CSR's were added and now the core is up to about 6,600 LUTs. It still fits easily into the smallest Artix-7 A7-15.
The uart6551 core is being used to communicate with a terminal program on the PC. The uart's fifo receive function seems a bit flaky but transmit works okay. For some reason there are extra characters on the receive. So I modified the uart core and allow the fifo's to be disabled. It seems to work better without fifos.
I had a quick look at the code and it looks like I'd be doing a lot to port to the code to riscv. I have several monitors for various processors I was just looking for something canned already.
Author:  BigEd [ Sun Jul 21, 2019 12:39 pm ]
It may be that the OPC monitor isn't a great starting point, but note that OPC7 is a clean regular 32 bit machine, so it might not be so hard. There's a BCPL port too, so that might be applicable.
viewtopic.php?t=480
Author:  robfinch [ Sun Jan 26, 2020 3:49 am ]
Spent about an hour trying to figure out why floating-point addition wasn’t working. 10.0 + 10.0 was returning an answer of 10.0. Well then I finally realized the one register loaded with a constant 10.0 was f0 the register that always reads as +0.0. I must be getting older.
Much of the core seems to be working, it is able at least to dump memory and communicate through a serial port. The core is running @50MHz with lots of clocks per instruction.
File comment: Float10+10
Author:  robfinch [ Mon Jan 27, 2020 4:29 am ]
Porting TinyBasic to the system. Not quite working yet, but got to the startup banner. It displays zero bytes free though as there is something wrong in the print number routine, most likely a divider op that isn’t working.
Added a small system memory management unit (SSMMU). It has both segmentation and paging. Segmentation is via 16 segment registers selected with the high order 4-bits of an address like the PowerPC 32-bit machine. After a linear address is generated from segmentation a page map table is used lookup pages mapped into the address space. The system seems to work! Running the system without initializing the mmu resulted in the user address space being limited to 2kB. The size of a page. If not initialized all the pages are mapped to page zero. There’s only 512kB ram in the system. So it’s mapped using 256, 2kB pages. Since only 256 entries per address space are required, the entries are mapped into 64 consecutive CSR’s. The system allows for 16 different maps to be in use at the same time. It takes just one 4kB block ram to implement a mapping table so it’s pretty frugal.
Author:  robfinch [ Tue Jan 28, 2020 4:34 am ]
Spent most of the time today debugging Tiny Basic. It’s working much better now, able to run a small program to display Hello World! I’d like to get a program loader working, but that’s maybe venturing too far into the OS domain. There’s segment registers and page mapping available and no OS. I wonder if there’s a small OS that could be ported. It would have to fit into something like 16kB.
File comment: TinyBasic screenshot
Changed the use of CSR’s for mapping and segmentation registers to access via custom instructions. CSR’s aren’t really meant to support arrays of data for things like memory maps. The issue was the need to access the CSR indirectly via another register. This kind of access is not supported in RISCV. It’s the kind of thing better suited to custom instructions.
Ran into issues of core size in the small Artix7-15t FPGA.
Author:  BigEd [ Tue Jan 28, 2020 10:18 am ]
I'd be interested to hear a bit more about the porting of TinyBasic - there were several implementations, so where did you start and where did you finish??
Page 2 of 8 All times are UTC
http://www.phpbb.com/
