Last visit was: Fri Apr 10, 2026 9:14 am
It is currently Fri Apr 10, 2026 9:14 am
WYSIWISC: What You See Is What It Should Compute
Alikberov
Joined: Sat Feb 13, 2021 12:22 pm Posts: 21 Location: https://en.wikipedia.org/wiki/Tashkent
oldben wrote: At the moment, I encountered a rather strange situation. snip BC B8 90 90 45 6E EOR B8,9#D4+5,C6 ???[/code]Lines with "???" indicate a new problem: We have double pointer - delegated and immediate. Previously, the combo «MOV 9#D4+5,B8» could simply mean «LEA D9,[IP+2]» + «MOV [eval("D4+5")],D8H» (CISC: "redefine delegate" + "move"). But now, as I strive for very strict command decoding (less CISC-commands), I see this as a new problem. Would a double pointer imply *(arg1 + scaled arg2 ...) ? LEA is a needed instruction for most modern computing. > P.S.: Anyway, in options "CISC vs RISC" I wish looking for RISC. I am with unimpressed load/store architecture. I very unimpressed with the x86. I like the early machines as they had ample word size for floating point 36+ bits, and a simple addressing modes ( often only 1). Accessing external memory is slow, and think that the early designs had the best solution for that problem. Hm... With complex prefix we can have any vector with scales: Code: Prefixes Vector Description 12 #D1+2 "#D1" is base - not index in later! 34 #D1+D3+24 [D1+(D3)+24] 15 #D1+2D3+245 [D1+(2*(D3))+245] - "D1" is shifter 67 #D1+2D3+D6+2457 [D1+(2*(D3)+D6)+2457] 68 #D1+4D3+3D6+24578 [D1+(2*(2*(D3)+D6)+D6)+24578] - "D6" is repeated in nest!
Thus we can encode any vector: Code: 12 23 24 65 27 89 10 is means vector Code: #D1+14D2+4D6+2D8+2345790 → [D1+14*D2+4*D6+2*D8+2345790] - `12` → `#D1+2`
- `23` → `#D1+D2+23`
- `24` → `#D1+3D2+234` (`#D1+2D2+D2+234`)
- `65` → `#D1+3D2+D6+2345`
- `27` → `#D1+7D2+2D6+23457` (`#D1+6D2+4D6+D2+23457`)
- `89` → `#D1+7D2+2D6+D8+234579`
- `10` → `#D1+14D2+4D6+2D8+2345790`
My Verilog-model and i8080-parser can decode this prefixes. Attachment: i8080-wysiwisc-vector_decoder.png Attachment: WYSIWISC-DECODE_VECTOR.ASM.zip You can run online: - Just unpack binary
Attachment: WISC-LEA.RKR.zip - Press
button - Type codes «12 23 24 65 27 89 10 00» using numbers and space-bar, then press Enter
______________________________Well. Lets recall basic principles for encoding ALU-commands in "strict mode". In "flat-RISC" interpretation of byte-code we have few "trash commands": Code: Prohibited operation Notice MOV A0,A0 MOV PSW,PSW - is nonsense MOV A0,D MOV PSW-byte,D-word - is incompatable MOV D,A0 MOV D-word,PSW-byte - is incompatable --- ADD A0,R ALU PSW,R - is forbidden ADD R,A0 ALU R,PSW - is forbidden
If we start clean up it cases with restrictions, we get "smart-CISC commands": Code: MOV A0,D INF PSW,D - try input (is port exist? CF="1" if it exist) MOV D,A0 INF D,PSW - try output (is port exist? CF="1" if it exist) --- ADD A0,R INC CF,R - conditional increment (if CF="1") ADD R,A0 INC R - unconditional increment
As the "ADD PSW,PSW" is forbidden, with prefixes we have unary operations: Code: ADD A0,#D1+2,A0 INC #D1+2 SUB A0,#D1+2,A0 DEC #D1+2 AND A0,#D1+2,A0 CLR #D1+2 OR A0,#D1+2,A0 SET #D1+2 EOR A0,#D1+2,A0 NOT #D1+2
Linear assembler can encode it all (over 28 cases). And Verilog-model can decode this (over 28 different instructions): Code: _IP_:M#[VV]IC M_V_AD_E_AD_F RC<>TR _ASM ..OPERANDS.. _REAL INSTRUCTION_ 0000: AA 0_0_x0_x_0x_0:A?!=0? CTX A,A 0001: A0 0_0_x0_x_00_0:A?!=AA REG A0 0002:03# A0 1_0_10_0_00_0:@0!=AA REG3 A0 0005: 0F 0_0_10_1_10_1:@0==@0 --- ??? ; MOV A0,A0 0006: 0E 0_0_10_1_10_0:@0==@0 --- ??? ; EOR A0,A0 0007: 0D 0_0_10_1_10_0:@0==@0 --- ??? ; DIS A0,A0 0008: 0C 0_0_10_1_10_0:@0==@0 --- ??? ; CON A0,A0 0009: 0B 0_0_10_1_10_0:@0==@0 --- ??? ; SUB A0,A0 000A: 0A 0_0_10_1_10_0:@0==@0 --- ??? ; ADD A0,A0 000B: 34 0F 0_1_10_1_10_1:@0==@0 MOV PSW,D3+4 ; MOV A0,D3+4,A0 000D: 34 0E 0_1_10_1_10_0:@0==@0 NOT D3+4 ; EOR A0,D3+4,A0 000F: AD 0_0_10_0_00_0:@0!=AA CTX A,D 0010: 5F 0_0_10_0_01_1:@0!=#5 INF D5 ; MOV A0,D5 0011: 5E 0_0_10_0_01_0:@0!=#5 NOT D5 ; EOR A0,D5 0012: 34 5F 0_1_10_0_01_1:@0!=#5 SWP D3+4,D5 ; MOV A0,D3+4,D5 0014: 34 5E 0_1_10_0_01_0:@0!=#5 EOR D3+4,D5 ; EOR A0,D3+4,D5 0016: AC 0_0_10_0_01_0:@0!=#a CTX A,C 0017: 5F 0_0_10_0_00_1:@0!=C5 MOV PSW,C5 ; MOV A0,C5 0018: 5E 0_0_10_0_00_0:@0!=C5 NOT C5 ; EOR A0,C5 0019: 34 5F 0_1_10_0_00_1:@0!=C5 SWP D3+4,C5 ; MOV A0,D3+4,C5 001B: 34 5E 0_1_10_0_00_0:@0!=C5 EOR D3+4,C5 ; EOR A0,D3+4,C5 001D: DA 0_0_10_0_00_0:@0!=CD CTX D,A 001E: D1 0_0_01_0_00_0:#x!=AD REG D1 001F: 0F 0_0_01_0_10_1:#1!=@0 OUF D1 ; MOV D1,A0 0020: 0E 0_0_01_0_10_0:#1!=@0 NOT D1,CF ; EOR D1,A0 0021: 34 0F 0_1_01_0_10_1:#1!=@0 MOV D1,D3+4 ; MOV D1,D3+4,A0 0023: 34 0E 0_1_01_0_10_0:#1!=@0 EOR D1,D3+4 ; EOR D1,D3+4,A0 0025: CA 0_0_01_0_00_0:#1!=AC CTX C,A 0026: C2 0_0_00_0_00_0:C?!=AC REG C2 0027: 0F 0_0_00_0_10_1:C2!=@0 MOV C2,PSW ; MOV C2,A0 0028: 0E 0_0_00_0_10_0:C2!=@0 NOT C2,CF ; EOR C2,A0 0029: 34 0F 0_1_00_0_10_1:C2!=@0 MOV C2,D3+4 ; MOV C2,D3+4,A0 002B: 34 0E 0_1_00_0_10_0:C2!=@0 EOR C2,D3+4 ; EOR C2,D3+4,A0 002D: DD 0_0_00_0_00_0:C2!=AD CTX D,D 002E: 1F 0_0_01_1_01_1:#1==#1 ??? D1 ; MOV D1,D1 002F: 1E 0_0_01_1_01_0:#1==#1 NEG D1 ; EOR D1,D1 0030: 1D 0_0_01_1_01_0:#1==#1 STD D1 ; DIS D1,D1 0031: 1C 0_0_01_1_01_0:#1==#1 CLN D1 ; CON D1,D1 0032: 1B 0_0_01_1_01_0:#1==#1 SUB D1 ; SUB D1,D1 0033: 1A 0_0_01_1_01_0:#1==#1 ADD D1 ; ADD D1,D1 0034:06#34 5F 1_1_01_0_01_1:#1!=#5 ORD6 D1,D3+4,D5 ; MOV D1,D3+4,D5 0038: 34 5E 0_1_01_0_01_0:#1!=#5 EOR D1,D3+4,D5 ; EOR D1,D3+4,D5 003A: 34 1F 0_1_01_1_01_1:#1==#1 LEA D1,D3+4 ; MOV D1,D3+4,D1 003C: 34 1E 0_1_01_1_01_0:#1==#1 RRC D1,D3+4,D1 ; EOR D1,D3+4,D1 003E: 34 1D 0_1_01_1_01_0:#1==#1 SAL D1,D3+4,D1 ; DIS D1,D3+4,D1 0040: 34 1C 0_1_01_1_01_0:#1==#1 SAR D1,D3+4,D1 ; CON D1,D3+4,D1 0042: 34 1B 0_1_01_1_01_0:#1==#1 SUB D1,D3+4,D1 ; SUB D1,D3+4,D1 0044: 34 1A 0_1_01_1_01_0:#1==#1 MUL D1,D3+4,D1 ; ADD D1,D3+4,D1 0046: DB 0_0_01_0_01_0:#1!=#d CTX D,B 0047: 5F 0_0_01_0_00_1:#1!=B5 OUT D1,B5 ; MOV D1,B5 0048: 5E 0_0_01_0_00_0:#1!=B5 EOR D1,B5 ; EOR D1,B5 0049: 34 5F 0_1_01_0_00_1:#1!=B5 LEX D1,D3+4,B5 ; MOV D1,D3+4,B5 004B: 34 5E 0_1_01_0_00_0:#1!=B5 EOR D1,D3+4,B5 ; EOR D1,D3+4,B5 004D: CD 0_0_01_0_00_0:#1!=BC CTX C,D 004E: 5F 0_0_00_0_01_1:C2!=#5 MOV C2,D5 ; MOV C2,D5 004F: 5E 0_0_00_0_01_0:C2!=#5 EOR C2,D5 ; EOR C2,D5 0050: 34 5F 0_1_00_0_01_1:C2!=#5 ??? C2,D3+4,D5 ; MOV C2,D3+4,D5 0052: 34 5E 0_1_00_0_01_0:C2!=#5 EOR C2,D3+4,D5 ; EOR C2,D3+4,D5 0054: CC 0_0_00_0_01_0:C2!=#c CTX C,C 0055: 2F 0_0_00_1_00_1:C2==C2 MOV C2,C2 ; MOV C2,C2 0056: 2E 0_0_00_1_00_0:C2==C2 NEG C2,C2 ; EOR C2,C2 0057: 2D 0_0_00_1_00_0:C2==C2 STD C2,C2 ; DIS C2,C2 0058: 2C 0_0_00_1_00_0:C2==C2 CLN C2,C2 ; CON C2,C2 0059: 2B 0_0_00_1_00_0:C2==C2 SUB C2,C2 ; SUB C2,C2 005A: 2A 0_0_00_1_00_0:C2==C2 ADD C2,C2 ; ADD C2,C2 005B: 34 2F 0_1_00_1_00_1:C2==C2 LEX C2,D3+4,C2 ; MOV C2,D3+4,C2 005D: 34 2E 0_1_00_1_00_0:C2==C2 RRC C2,D3+4,C2 ; EOR C2,D3+4,C2 005F: 34 2D 0_1_00_1_00_0:C2==C2 SAL C2,D3+4,C2 ; DIS C2,D3+4,C2 0061: 34 2C 0_1_00_1_00_0:C2==C2 SAR C2,D3+4,C2 ; CON C2,D3+4,C2 0063: 34 2B 0_1_00_1_00_0:C2==C2 SUB C2,D3+4,C2 ; SUB C2,D3+4,C2 0065: 34 2A 0_1_00_1_00_0:C2==C2 MUL C2,D3+4,C2 ; ADD C2,D3+4,C2 0067: 34 5F 0_1_00_0_00_1:C2!=C5 ORD C2,D3+4,C5 ; MOV C2,D3+4,C5 0069: 34 5E 0_1_00_0_00_0:C2!=C5 EOR C2,D3+4,C5 ; EOR C2,D3+4,C5 006B: DB 0_0_00_0_00_0:C2!=CD CTX D,B 006C: B7 0_0_01_0_00_1:#1!=BB MOV D1,B7 006D: C7 0_0_01_0_00_1:#1!=BC MOV D1,C7 006E: CF 0_0_01_0_00_1:#1!=BC NOT CF ; CMC / Carry Flip 006F: CE 0_0_01_0_00_0:#1!=BC ERA CF ; CLC / Carry Erase 0070: 34 CF 0_1_01_0_00_1:#1!=BC JCF D3+4 ; JC D3+4 0072: 34 CE 0_1_01_0_00_0:#1!=BC JCE D3+4 ; JNC D3+4 Let me remind You that the goal is not to do something similar to CISC or RISC, but to end up with intuitively understandable code with context and subtext, where "strictness" simply eliminates ambiguity, but at the same time, as a side effect, provides convenient features. As neural bot concludes in the end, such an approach is not just "a certain architecture", but "a whole philosophy"! P.S.: Poetical speaking, I am "feeling out" not just a "computational stone", but already something like a "philosopher's stone of computation"
| Sun Mar 16, 2025 10:00 pm |
Alikberov
I looking back many times for complex prefixes mode and trying touch optimal path of conception developing. - Like "Virtual Java Machine": I think about "Virtual WYSIWISC-Machine" for i8080, z80, i8086.
- With "clean bottom": I looking for "underwater stones" and try exclude many of lot.
Virtual WYSIWISC-MachineLike Fortran, Pascal or C, concept of WYSIWISC is looking good as P-Code, if looking "deeply". If Basic in regular dialects based on tokens model with no hardware realize, in case with WYSIWISC we haves: - The chance for hardware TTL IC building (first model of 2019 - draft in Logisim)
- The chance Verilog-modeling for FPGA (I run my first prototype in Quartus before "my PC crashed & BSODed" in 2021)
- The chance for architecture scaling (from 30 APRs A0-A9/B0-B9/C0-C9 to billions - A1234567890 e.t.c.)
In current time I watching problem in combo «Delegate»+«Vector» over few instructions: - «Delegate»+«Vector»+«HLT» → «Redefine Delegate» - good solution
- «Delegate»+«HLT» → «Debug Delegate» - good solution
- «Delegate»+«ALU operation» → «ALU operation with delegated vector» - good solution
- «Delegate»+«Vector»+«ALU operation» → strange combination - problem/!\
- «Delegate»+«Vector»+«REG operation» → strange combination - problem/!\
- «Delegate»+«Vector»+«Branch operation» → strange combination - problem/!\
- «Delegate»+«Vector»+«INT operation» → strange combination - problem/!\
If imaging variant, where «ALU with Delegated Vector» is an external operation, like x86-Esc for FPU and other, we can finding good place for architecture scaling! But I can't understand how it must working even on JavaScript-emulator! P.S.: This architecture just looking as "wrong way", if You can't or don't want see "beautiful philosophy of concept". But in other aspect - it looking like "fairy architecture", and it just fascinating!
| Mon Mar 17, 2025 10:00 pm |
Alikberov
Eureka! - «Delegate»+«Vector»+«ALU operation» → analogue of «ALU Target,Segment:[Vector],Source»
- «Delegate»+«Vector»+«REG operation» → analogue of «MOV Segment:[Vector],Source»
Normally, we have the AEN signal (Address Enable), but in the new case, we may also have DEN (Device Enable) too. A simple system can ignore this, but in a complex system, it can form an extended address - A16-A31 (in an 8-bits architecture). Then we have also - «Delegate»+«Vector»+«Branch operation» → branch if Delegated Segment is responsive
- «Delegate»+«Vector»+«INT operation» → interrupt if Delegated Segment sent a request
It''s very elegant solve!
| Mon Mar 24, 2025 2:00 pm |
Alikberov
Early I developed Verilog-model of "vector calculator" - one of difficult parts of CPU. In present time I developed the draft in the Logisim: Animation of work: This draft is useless for CPU-Core - for visual testing only! It's just beautiful! Emulator on i8080:
| Thu Mar 27, 2025 6:00 pm |
Alikberov
The basic principles of operation of the prefix stream parsing node can be understood from Online Delegate Calculator. the circuit generates ROTATE and SHIFT signals respectively with lines is_rotate and is_shift of the algorithm. With this code: Attachment: DELEGATE.RKR.zip You can also check the work in the online emulator i8080. (Keys 0-9 and SPACE BAR for clear) The closest reverse analog of my circuit is the DM2504 or MM54C905. - C - Clock input (posedge - positive edge)
- S - Mode selector (active level - low)
- EN - Enable operation (active level - low)
- EB - Enable base latch (active level - low)
- IC - Instruction Code: Bits 4…7 - input
- B0…B3 - Base (base register index output)
- EB - Enable Base (enable base register index latch)
- ROTATE - Output signal for index entry scrolling («index <<= 1») - index repeat
- SHIFT - Output signal for index entry expansion («index += register») - enable entry
P.S.: VIDEO
| Sat Apr 05, 2025 4:00 pm |
Users browsing this forum: Bytespider, CCBot and 1 guest |
