Last visit was: Thu Jun 18, 2026 2:41 pm
It is currently Thu Jun 18, 2026 2:41 pm
 [ 104 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
 LALU Computer: Lookup Arithmetic Logic Unit
Can't fathom how you work some of those instructions without read accessible pointers, maybe the new stacks.
Anyways, your A*B table. Does that function return the H or L byte of the answer? And why not offer both?
A+A or B+B can also perform left logical shift, so not like you have no table to spare for the other byte...
Mon Sep 19, 2022 7:18 pm
The ALU function for the Multiply in LALU is absolutely ghastly. The lookup table reports the 8 bit result of a multiplication of A and B so long as it does not overflow. If the operation does overflow it reports back hexadecimal FF. ( 8*8=64 OK, 17*17=FF for overflow). I'm interested in any ideas to improve that function, or ideas to replace the function entirely with something more useful.
Also, here is kind of an odd thing. Since the ALU can generate the various flags as listed, I could program the lookup controller to make any instruction conditional on the flags. For example I have an instruction MAB (Move A to B). The controller could be programmed to make MAB execution conditional on the flags... for example, MAB only If A>B.
Here's another thing: I have space in the controller for 3 more instructions. (Hex D, E and F). I'd be interested to know if anyone has ideas for additional useful instructions.
Michael
Mon Sep 19, 2022 9:23 pm WWW
What I suggest are fixed point output bytes "HL.XYZ"
Each output byte gets a separate lookup table in LALU.
Go deep or shallow as you find table space to spare.
Right now we are just talking about multiply.
Nothing messy when you simply offer the high byte instead of an error.
MPH(A*B)=H_.___ Multiply
MPL(A*B)=_L.___
DVL(A/B)=_L.___ Divide
DVX(A/B)=__.X__
DVY(A/B)=__._Y_
DVZ(A/B)=__.__Z
MDL(A/B)=_L.___ Modulo or Division's Remainder
CSX(AB)=__.X__ Cosine of a 16bit quadrant
CSY(AB)=__._Y_
CSZ(AB)=__.__Z
QRL(AB)=_L.___ Square root
QRX(AB)=__.X__
QRY(AB)=__._Y_
QRZ(AB)=__.__Z
None of these desperately need to throw flags, so the full width of every byte is available.
Divide By Zero or COS(0)=1 could flag, but worthwhile or just making things complicated?
Rarely used ALU functions may not merit a unique instruction, but instead access as memory.
-edit- What about COS(AB+1)? One extra angle lets us hit 45degrees and all halvings exactly.
COS(0)=1 should "off the table" anyway, as a CSL table wastes 64KBytes just to store one bit.
Better off with a slightly smaller quadrant, integer divisible to all the most common angles?
I had such a number writ down but lost. A gazillion old notes like this to consolidate...
Was: 2*2*2*2*2*3*3*5*5*7 = 50,400 (+1 for zero). Or 90 degrees subdivided by 560.
Tue Sep 20, 2022 2:02 am
Michael
Decimal add with carry and Decimal subtract with carry D & E
They work with the ASCII characters 0..9. You then can have a 4 digit calculator.
(F has to halt and catch on fire)
Tue Sep 20, 2022 2:49 am
I don't offer BCD arithmetic tables, but three conversion tables under
"Single Argument Functions", where all or part of B further specifies
a sub-function.
BCD to ABS _L.___ Coded Decimal to Absolute
ABS to CDL _L.___ Absolute to Coded Decimal Low (00~99)
ABS to CDH H_.___ Absolute to Coded Decimal High (Hundreds)
ABS being my "absolute" or unsigned plain positive binary data type.
I also have conversion tables to/from ascii and seven segment...
Perhaps relevant to the purpose of a calculator.
As for binary addition:
ADD(A+B+0) Addressed when the input flag is false
ADD(A+B+1) Addressed when the input flag is true
Neither of these give simultaneous output of any flag.
Fortunately we don't always care to update flags.
Even convenient to avoid mandatory overwrite.
Flag outputs (when we do care) will require a separate lookup.
Conversely, a branch suffers no requirement to ever see the main result.
FLG(A,B,0) Addressed when the input flag is false
FLG(A,B,1) Addressed when the input flag is true
Each bit of flag and it's "flag when flagged" evil twin represent a function.
Obviously A+B's carry, A-B and B-A's borrow and zero.
One flag pair further break down per the single argument sub-functions.
Complicated and messy to describe in detail. Some other time, not tonight...
I have an old neglected blog at Hackaday. Don't take my plans there as fully baked.
The organization of MMruzek's LALU reserved no empty space for new functions.
To complicate addition, his Carry manifests as LSB. If just one A vs B table could
be freed, single argument conversions occupy only 1/256th of that same space.
For example: Rotations operating only on A don't need to occupy a full A vs B table.
New functions (like BCD conversion) may now squeeze in edgewise, selected by B.
Even without new functions, some workaround for BCD Addition w Carry might be
microcoded.
Suffice to say I have way more ALU function tables than one should assign opcodes.
I don't have any opcodes or instructions yet, only an absurd excess of ALU functions.
Unfortunately too many moons thinking only how ALU tables might be optimized.
Almost totally neglected how burn the tables or make a workable CPU of the thing.
Thinking too hard now about all those neglected aspects.
Tue Sep 20, 2022 6:58 am
Here is a photo of the stack cards for LALU. There is a Data stack, Keyboard stack and Return stack. The Data stack is used for computations. The Keyboard stack holds the character string sent to the language interpreter. The Return stack is used for holding addresses for return jumps and nesting. Presently the stacks are 256 bytes deep, because an 8 bit counter is used.
The instructions sent to the stacks are microcoded, which is why there is a 4-16 decoder on each board. The same microcode also controls the LCD Display card, and the Keyboard I/O card.
There is a good book about Stack Computers by Koopman available on the web. Here is a link to it:
http://users.ece.cmu.edu/~koopman/stack ... index.html
I am now in the process of writing an interpretive language for the computer using the assembly language previously described. I am trying to make the language easy to use like Basic, but powerful like Forth. More on that later!
Sun Oct 09, 2022 1:11 pm WWW
Hi, It has been about a month since my last update on the LALU Computer. Previously, I published a listing of the Assembly Language for LALU. Since then I have written a higher level language for the computer called 'LANG'. My goal is to develop the language to the point of doing some performance benchmarking, notably running a program to calculate prime numbers.
LANG is an interpretive computer language with an emphasis on stack manipulation using Reverse Polish Notation math. The parser generally uses the 1st and/or 2nd ASCII character of an instruction to identify the operation to be performed. All numbers and variables are unsigned positive 16 bit integers. This required quite a bit of coding because the LALU computer is native 8 bit data manipulation.
LANG is extremely compact and terse. I've attempted to make the language slightly easier to read than FORTH, but somewhat less intuitive than BASIC. The language specification and an example program are attached. This project is obviously a work in progress, and I value any input or comments. Regards, Michael
Sat Nov 12, 2022 12:10 pm WWW
The LALU computer is now running the LANG language OK. I wrote a small program to identify the prime numbers up to 1000, loosely based on the benchmark given by Tom Fox in the June 1980 issue of Interface Age. I attached a screenshot of the original article. This benchmark is relatively simple, and is often run in the original language of BASIC. My goal was to get a rough idea of where I am in the design of LALU, which is an 8 bit machine running at 1 MHZ.
A program listing for the LANG version of the program is attached. It is to be noted that I am not printing out the array of numbers, as in the original program. (Printing out an array of 1000 numbers on the LCD display takes about 20 seconds.)
Running the program as shown, the time to complete using LANG is 360 seconds. By combining lines of the program I can get this down to 240 seconds. This is not an apples to apples comparison, but I at least find it encouraging.
Another factor is that I am using 6 microsteps per instruction on the ring counter, but my instructions only use 4 of the microsteps, so there is some opportunity to speed things up there as well.
Sun Dec 04, 2022 3:39 pm WWW
(Interesting little benchmark - posted about it here.)
Mon Dec 05, 2022 5:26 pm
I got curious as to how well my 40MHz rf68000 would perform on this test.
122 seconds running TinyBasic. I had to modify the program to something equivalent I think because TinyBasic did not like the early exits from the FOR loop. Also, TinyBasic only supports integers so the remainder had to be computed. TinyBasic does not tokenize so it has to parse everything, and it is calling a subroutine.
NEW
130 PRINT "Starting."
140 FOR N = 1 TO 1000
150 GOSUB 300
240 NEXT N
250 PRINT "Finished."
260 END
300 FOR K = 2 TO 500
310 M=N/K
312 J=N-M*K
320 IF K=N GOTO 380
330 IF M=0 RETURN
340 IF M=1 GOTO 370
350 IF J>0 GOTO 370
360 IF J=0 RETURN
370 NEXT K
380 PRINT N
390 RETURN
RUN
<CON
Tue Dec 06, 2022 2:22 pm WWW
Count me out, as I don't have BASIC on my machine.Benchmarks really don't count unless normalized for the same memory speeds in my view. I do have a compiled language, but not C for my machine. I still run at 1980 speeds 1.5 Mhz.
Tue Dec 06, 2022 7:23 pm
Ooh, that's funny, I like it !
I've just run it with my port of the Palo-Alto Tiny Basic on BB-88, my 8088 (actually V20) breadboard computer.
I had to use the remainder method provided above, but PATB does support early exits from FOR loops, so no need to use a subroutine in my case.
The benchmark ran in 630 seconds. That's not too bad!
Then, just to get an idea, I booted up in MS-DOS and ran the original benchmark in QBasic: 547 seconds. Oh well...
https://www.alrj.org/pages/Astorisc.html
Wed Dec 07, 2022 10:57 am WWW
Contest!
630 secs for a breadboard computer is pretty decent.
The rf68k is only about as good on the benchmark as the 6MHz HEX29 2900 mainly because of the memory access. Rf68k uses about five or six cycles per memory access, lots of wait states. So, <8 MHz memory. So, it sorta makes sense its about the same time. No cache on this machine. Thankfully it is local RAM being used. Global RAM access is like 20+ cycles.
BTW the LALU 360 secs. For a 1 MHz machine is awesome! I have been following the LALU with interest.
Wed Dec 07, 2022 1:53 pm WWW
Those comparison tests on the machines are interesting, and thanks for the link to your post about the benchmark. What is the clock speed on the 8088 breadboard, and could you post a photo of your setup(s)?
I've trimmed the code in assembly language routines for LANG, and eliminated a time delay loop I had inserted for the LCD display (duh!), so things are really humming along now. I'm kind of at a loss for how to make things faster in software. Right now the largest delay is caused by the Go To statements. Those require loading the Keyboard Stack with the relevant line of text for parsing. My parser is super-simple, it literally uses the first ASCII character of an instruction as a memory pointer to jump to the ROM code location. (Delimiters are blank spaces.) Also, of course a bunch of time is wasted doing 16 bits on an 8 bit machine.
Here are a few photos of the complete LALU computer. I think you might find the keyboard kind of comical. I took a Dell PS/2 keyboard and use it with a translator PIC previously described. What's funny is I used a black sharpie to blank any key that is not translated by the PIC and slapped a "LALU" tag over the Dell.
Wed Dec 07, 2022 9:43 pm WWW
Splendid! Thanks for the photos.
Wed Dec 07, 2022 9:46 pm
Users browsing this forum: Baidu [Spider], CCBot, chrome-131-bots and 1 guest
