DIP-8: 8-bit TTL computer http://anycpu.org/forum/viewtopic.php?f=23&t=978 |
Page 2 of 2 |
Author: | dip16 [ Thu Jan 19, 2023 12:50 pm ] |
Post subject: | Re: DIP-8: 8-bit TTL computer |
Yes, I agree - and I forgot that in C, "char" on its own can be signed or unsigned. If I pass -unsigned-char to vbcc, then char is unsigned by default, as it should be, and my string code isn't trying to sign-extend all the time. |
Author: | robinsonb5 [ Thu Jan 19, 2023 1:05 pm ] |
dip16 wrote: (As well as making comparisons signed, I realised that "sig" could more generally act as a "signal" to modify the behaviour of other instructions - but I've not found another use for it yet.) One thing I used my "sgn" modifier for is making my right-shift instruction copy the msb instead of shifting in zeroes - avoiding the need for both "lsr" and "asr" instructions - maybe something worth applying to your "ror" instruction? Also the sig modifier might be useful for "sub" as well as "cmp" - assuming sub modifies the flags? |
Author: | oldben [ Thu Jan 19, 2023 4:14 pm ] |
robinsonb5 wrote: dip16 wrote: (As well as making comparisons signed, I realised that "sig" could more generally act as a "signal" to modify the behaviour of other instructions - but I've not found another use for it yet.) One thing I used my "sgn" modifier for is making my right-shift instruction copy the msb instead of shifting in zeroes - avoiding the need for both "lsr" and "asr" instructions - maybe something worth applying to your "ror" instruction? Also the sig modifier might be useful for "sub" as well as "cmp" - assuming sub modifies the flags? I still use 1960's computing ideas, no flags just Link/Carry bit. Branches test a register for a + - or zero. I have no CMP instruction, but have adx,sbx ( add index , subtract index ) that does not affect the carry bit. I my case adding a real flag register, and a CMP is more pain than it is worth. |
Page 2 of 2 | All times are UTC |
