Last visit was: Wed Aug 26, 2026 12:17 pm
It is currently Wed Aug 26, 2026 12:17 pm
 [ 6 posts ]
 Is It Me Or The Simulator
I am using this 6800/6811 simulator, a nd i try to change the character on the display to 'A'.
MAIN     LDAA     #$65
         STAA     $FB00
         .END
It does not do anything, is the problem in my code, or does the simulator not right
intel 4004 countdown
:05000000DAF81C01000C
:00000001FF
Thu Oct 31, 2013 12:03 pm
You might need to give a little more info. Which simulator? What it it simulating? Storing a number to $FB00 by itself is rather meaningless without this info, but if you tell what you're simulating, someone who's familiar with it might recognize it and be able to help. Are you sure you're just supposed to store it there, not run the subroutine at $FB00?
Thu Oct 31, 2013 5:53 pm WWW
James_Parsons:
I agree with Garth that you need to provide more information before you can expect an answer to your post. Like Garth, I have no idea which simulator you are using, what assembler syntax that simulator accepts, or even if the simulator emulates a UART and console, and the address to which you write the contents is the transmit register of that emulated UART.
On an unrelated topic, I followed the link you provided to your web site. If you don't mind, I'm going to comment on one of them.
START    LDAA  #0A
LOOP     DECA
         CMPA  #00
         BEQ   DONE
         BNE   LOOP
DONE     RTS
In your count down example, I believe that you have correctly implemented the subprogram. That is, you load accumulator A with 10 (LDAA #0A), and the loop decrements that accumulator by 1 in each pass through the loop, and exits when the value in the accumulator reaches a value of zero.
However, you are not making effective use of the processor. First, if you'll refer to the MC6800 Programmer's Reference Manual, the decrement accumulator A instruction (DECA) modifies the processor arithmetic status flags. It modifies the N (negative), the V (oVerflow), and the Z (Zero) flags. It does not modify the C (Carry) flag. What this means for your program is that the Compare Accumulator A with immediate value 0 (CMPA #0) instruction is not required. Second, you really only need one of the two conditional branch instructions, the second one - BNE LOOP.
Thus, you can simplify and improve your subprogram in the following manner:
START    LDAA  #0A
LOOP     DECA
         BNE   LOOP
DONE     RTS
Fri Nov 01, 2013 1:28 am
Sorry :( i thought I posted a link, but I guess not. Anyway the problem was the simulator, It worked on an older version, but with a different charset
:00000001FF
Fri Nov 01, 2013 12:04 pm
MAIN     LDAA     #$65
         STAA     $FB00
         .END
I always thought that $65 was a lower-case 'e', not a capital 'A', but my experience is mostly ASCII.
Mike
Tue Dec 31, 2013 2:38 am
That'll be it: #$65 is #101 which is 'e' whereas #$41 is #65 is 'A'
The emulator might be this one: http://www.hvrsoftware.com/6800emu.htm which is for Windows but runs OK on Linux using WINE.
Tue Dec 31, 2013 9:47 am
 [ 6 posts ]
Users browsing this forum: chrome-10x-bots, claudebot and 7 guests
