Last visit was: Fri Nov 13, 2026 11:36 pm
It is currently Fri Nov 13, 2026 11:36 pm
DockLazy
Welcome! Sounds like a fun project.
| Thu Mar 27, 2025 2:24 am |
A IBM 360 clone sounds like more fun, than RISC. Spend time to consider about hardware debugging, a front panel,and bus layouts, since you are building a computer system. Manchester Baby is good example of a simple computer, to test out the system. Later the real computer can be built.
| Sat May 10, 2025 11:01 pm |
gfoot
Hi I'm George, and I already know quite a few of you from other forums like 6502.org. I've joined here as I'm finding myself more and more interested in CPU design, and have recently gone down a rabbit hole designing my own ISA for a practically-useful design which I hope to be able to build one day.
Professionally I've always been a software engineer, though these days I don't do the actual engineering any more. Outside of professional work I grew up learning computing on the BBC Micro, including some 6502 assembly language, before moving to PCs programming in C and x86 assembler, getting involved with the DJGPP and Allegro projects, and moving most of my home computing to Linux.
However about five years ago I developed an interest in how computers actually work, being especially interested in some aspects of the BBC Micro which I grew up using but not understanding at that level, and it was an eye-opener how simple these things actually are compared to the complex black boxes I'd assumed them to be. I watched a lot of Ben Eater's SAP-1 videos, made some 6502-based computers based on Grant Searle's simple design, and started digging a lot more deeply into display circuits, all this mostly on solderless breadboards but sometimes making PCBs. I've made YouTube videos documenting some of those projects too.
These were mostly based on the 6502, though I also picked up an ARM2 processor and made most of a computer using that. Those 32-bit buses though... lots of wires! I hope to get back to that one at some point but I am easily distracted, and not ashamed to let things lie abandoned for a while sometimes. There's only so much time in the day alongside work and hobbies need to be fun diversions, not a burden or obligation.
I recently took a long break from all of this, and one distraction in that period was trying to improve at chess. This year I started playing in some tournaments and got some official ratings, and I'm happy with those even if they're at the low end of the scale! Realistically it is hard to improve significantly as an adult but I've enjoyed the process and will try to keep it going on the back burner at least.
Over the past month or two my computer hardware interests have reasserted themselves, and among them is this CPU design which I've suddenly taken a lot further than I had expected to - it went from designing a simple ISA based on my hardware ideas, to making it be a 16-bit subset of RV32, to writing microcode to check that it can be implemented with a simple enough core design; and then I wanted to check that it was actually useful to program with this ISA (since I'm not familiar with RISCV at all), so I wrote an assembler and simulator for it, and now I've ended up also writing a lot of standard library code for it too, like I/O, string handling, malloc/free, mostly following the standard C APIs for those. I'm constantly surprised by how easy it is to work with, in spite of the limitations required to fit everything in 16-bit instructions.
So it's one of those projects that somehow seems to develop itself, and I'm surprised by how much momentum it's had. It's got to a point where I wanted to look more widely at other people's projects, and see what the "done thing" is, and if I'm making glaring mistakes - so I thought I'd join up here and have a look around!
If anybody is interested in more details on the CPU project let me know and maybe I can post more information, I haven't really thought through how to communicate any of it yet though and none of the code is in github yet.
| Sat Oct 04, 2025 3:14 pm |
Welcome George, good to see you here! And thanks for the bit of personal history. It is quiet here, but we do still see a number of regular visitors, and quite a few interested in esoteric or homebuilt CPUs. Edit: would certainly like to see any and all details of your thoughts so far. Probably best in Projectsor perhaps General DiscussionsEdit: I see a few like-minded threads also in CPU/MCU choices and designs
| Sun Oct 05, 2025 11:38 am |
gfoot
Thanks Ed. I have put where I am so far into a github repository at least! https://github.com/gfoot/gf-rv16 I will try to post more coherent details soon though!
| Fri Oct 10, 2025 1:54 am |
marc
Hello CPU fans! My name is Marc Abel, and I design open-source CPUs, controllers, and computers that use only static RAM and fast 7400 logic (more specifically SN74AUC—) as logic elements. The upshot is that these machines don't have any microprocessors, FPGAs, PLDs, ASICs, or even DRAM unless someone intentionally attaches peripherals that contain them. The benefit is that these machines function transparently, are fully inspectable at the logic gate level after assembly/delivery/use, don't hide exploitable defects easily, and don't accept exploitable defects via the VLSI supply chain easily. Target users include privacy seekers, critical infrastructure, and education. I hope you don't mind an "outsider" on this forum in the context that I don't do this as a hobby. I am a sincere proponent of transparently functioning computers for contemporary and future use. I've done this full-time for some years, and I run a U.S.-based nonprofit organization named The Dauug House that might provide me a stipend at some point for this work. I'm located in Bellbrook, Ohio. This thread being specifically for introductions, I should QSY further technical material to another category. But I might cross a number of topics, so if you have an idea where such would fit, I'd appreciate a PM. Thanks to everyone for reading! Marc
| Sat Apr 04, 2026 1:53 pm |
Welcome! Which subforum you use isn't critical: I'd suggest General Discussions unless something else really appeals to you. Moving a topic is very easy as a mod action, so that's another reason why it's not critical.
(Rethreading replies from one topic to another is not so easy...)
| Sat Apr 04, 2026 2:49 pm |
Martin_H
Hi, I'm Martin Heermance. I'm a retired software engineer by training, but I've been a homebrew electronics enthusiast since my teens. I recognize a few names here from the 6502 Forum where I'm a regular and received a lot of helpful advice over the years.
My interest in joining this forum is that for years I've been contemplating building a CPU from TTL ICs.
| Wed Jul 22, 2026 6:23 pm |
Welcome! Good to have you here.
| Wed Jul 22, 2026 8:05 pm |
Gio
Hey. Name's Gio.
I found my way here after telling the AI I wanted to talk to a human (about custom CPUs).
Anyway, I'm pretty new to the subjects of digital logic and microprocessor design, having just started this February: been reading Mano for the basics, the manuals for several early microprocessors (6502, z80, 6800, RCA 1802, Signetics 2650) for inspiration, and experimenting with digital simulations for practice.
Current project is a 6-bit processor; current stage is writing out the ISA. Or, to be more accurate, rewriting for the 4th or 5th time. After the ISA is done, I'm going to be building it in simulation, defining it in VHDL, then (hopefully) getting it running in an FPGA. An emulator should be in there somewhere, too.
Other than that, I've found I enjoy collecting custom ISAs and various CPU manuals in the 4-to-16-bit range.
| Fri Aug 14, 2026 11:52 pm |
Welcome! We're all humans here, so you're in the right place.
Writing an emulator does seem to be a good middle ground between designing the ISA and designing a hardware implementation.
It'll be interesting to know where you've got to, and how you've got there, so please feel free to start a thread.
| Sat Aug 15, 2026 5:47 am |
Users browsing this forum: claudebot, Firefox-135-bots and 5 guests |
