Thank you, Ed. I wasn't able to follow the instructions from the website because I don't understand the syntax of the command but I figured out how the keyboard worked.
I used the GUI to connect to Wifi once I understood how the keyboard worked. It is unlike a phone keyboard that holds the letter capital until you press a key and then it goes to lowercase. This keyboard is like a manual keyboard where you have to hold the shift down while you type a capital letter. All wep passwords have letters and numbers where the letters have to be all capital.. I wasn't able to see my typing because Chip does not display the password and there is no "unhide" option for the text so I was typing blind and wasn't able to see what I was doing.
I installed Vice and rebooted.
I entered some of the commands again and then I got a Commodore 64 image on the screen.
After rebooting, all I have to do is type x64 to run the Commodore 64.
I'm not use to Vice and this is slow going. We're running a larger screen image on a smaller screen so I'm not sure where I can go from here.
This is a bad picture and I'll try to get a better one in better lighting but I'm not sure if I will get the contrast.
