Porting the C64 compiler to target OPC5 (or OPC6) http://anycpu.org/forum/viewtopic.php?f=3&t=427 |
Page 3 of 6 |
Author: | BigEd [ Sat Aug 12, 2017 7:55 am ] |
Post subject: | Re: Porting the C64 compiler to target OPC5 (or OPC6) |
Dave's current programs start with this: Code: void init() { asm { ORG 0x100 mov r15, r0, _main }; } Perhaps that could be implicit, and it would then jump over all the storage locations for free? |
Author: | hoglet [ Sat Aug 12, 2017 10:00 am ] |
Hi Rob, A few incompatibilities with gcc have crept back in. Here's a pull request to fix them: https://github.com/robfinch/Cores/pull/2 I'm still getting incorrect code generation in at least one case: 14. Incorrect code generation with a * 2 - 1 Code: int bug14() { int a = 123; int b = a * 2 - 1; return b; } Code: _bug14: push r13,r14 push r12,r14 mov r12,r14 dec r14,2 mov r5,r0,123 sto r5,r12,-1 ld r7,r12,-1 mov r6,r7 add r6,r6 sub r5,r6,1 # this is incorrect; should be sub r6, r0, 1; mov r5, r6 sto r5,r12,-2 ld r5,r12,-2 mov r1,r5 mov r14,r12 pop r12,r14 pop r13,r14 mov r15,r13 Dave |
Author: | hoglet [ Sat Aug 12, 2017 10:11 am ] |
I'm still seeing core dumps; here's a minimal test case. 15. Core dump with expression a + a - 1 Code: int bug15() { int a = 123; int b = a + a - 1; return b; } Code: dmb@quadhog:~/atom/opc/examples/pi-spigot-c$ ./c64 bug15.c Segmentation fault (core dumped) dmb@quadhog:~/atom/opc/examples/pi-spigot-c$ gdb ./c64 core Core was generated by `./c64 bug15.c'. Program terminated with signal SIGSEGV, Segmentation fault. #0 0x0804e0b2 in GenerateBinary (node=0x96781fc, flags=1, size=1, op=0) at CodeGenerator.cpp:947 947 ap3->isAddress = ap1->isAddress | ap2->isAddress; (gdb) bt #0 0x0804e0b2 in GenerateBinary (node=0x96781fc, flags=1, size=1, op=0) at CodeGenerator.cpp:947 #1 0x080518df in GenerateExpression (node=0x96781fc, flags=1, size=1) at CodeGenerator.cpp:2154 #2 0x0804dda0 in GenerateBinary (node=0x9678254, flags=1039, size=1, op=3) at CodeGenerator.cpp:905 #3 0x08051905 in GenerateExpression (node=0x9678254, flags=1039, size=1) at CodeGenerator.cpp:2155 #4 0x0805081d in GenerateAssign (node=0x96782ac, flags=1039, size=1) at CodeGenerator.cpp:1737 #5 0x08051ce9 in GenerateExpression (node=0x96782ac, flags=1039, size=1) at CodeGenerator.cpp:2196 #6 0x08056fb8 in Statement::GenerateCompound (this=0x9677fe4) at GenerateStatement.cpp:671 #7 0x080570b4 in Statement::Generate (this=0x9677fe4) at GenerateStatement.cpp:713 #8 0x0805ee4d in GenerateFunction (sym=0x809b350 <compiler+42160>) at OPC6.cpp:560 #9 0x080719a4 in ParseFunctionBody (sp=0x809b350 <compiler+42160>) at ParseFunction.cpp:468 #10 0x0807137a in ParseFunction (sp=0x809b350 <compiler+42160>) at ParseFunction.cpp:336 #11 0x08067585 in Declaration::declare (parent=0x0, table=0x808f180 <gsyms>, al=2, ilc=0, ztype=28) at ParseDeclarations.cpp:1385 #12 0x08067b40 in GlobalDeclaration::Parse (this=0x9677a44) at ParseDeclarations.cpp:1527 #13 0x08052eb5 in Compiler::compile (this=0x8090ea0 <compiler>) at Compiler.cpp:104 #14 0x0804b6ea in main (argc=1, argv=0xbfabce48) at Cmain.cpp:82 (gdb) p ap1 $1 = (AMODE *) 0x96787a4 (gdb) p ap2 $2 = (AMODE *) 0x0 (gdb) p ap3 $3 = (AMODE *) 0x967878c (gdb) quit Dave |
Author: | robfinch [ Sat Aug 12, 2017 11:43 am ] |
Re: bug 15 There are space characters in the file with the most significant bit set making it a negative character. Apparently the isdigit() routine doesn't like that. I could strip the high bit off of characters as they come in. But are they part of a MBCS or wide characters and should be kept ? Is 'C' coded coded in just stand ascii 7 bit characters or are other characters allowed ? Eg. comments. Interestingly, the MS isdigit() routine gets called instead of the isdigit() routine coded in the program. As it is in the program it doesn't care and would've worked. I'm guessing roughly the same isdigit() routine is used in gcc. What to do about character over $7F ? |
Author: | robfinch [ Sat Aug 12, 2017 12:50 pm ] |
Re: org$100 Quote: Perhaps that could be implicit, and it would then jump over all the storage locations for free? The compiler could spit out an "org $100" at the start of code if that would help. But how smart is the assembler ? Can it rearrange where the variables are or does it care ? The compiler could spit out an "org $4000" at the beginning to locate the vars at $4000. But if it's org'd at $4000 can the assembler handle the code being org'd to $100 afterwards ? eg. org $4000 vars org $100 code |
Author: | hoglet [ Sat Aug 12, 2017 12:56 pm ] |
robfinch wrote: Re: bug 15 There are space characters in the file with the most significant bit set making it a negative character. Apparently the isdigit() routine doesn't like that. I could strip the high bit off of characters as they come in. But are they part of a MBCS or wide characters and should be kept ? Is 'C' coded coded in just stand ascii 7 bit characters or are other characters allowed ? Eg. comments. Interestingly, the MS isdigit() routine gets called instead of the isdigit() routine coded in the program. As it is in the program it doesn't care and would've worked. I'm guessing roughly the same isdigit() routine is used in gcc. What to do about character over $7F ? There are no unusual characters in the file: Code: od -Ax -tx1 bug15.c 000000 69 6e 74 20 62 75 67 31 35 28 29 20 7b 0a 20 20 000010 20 69 6e 74 20 61 20 3d 20 31 32 33 3b 0a 20 20 000020 20 69 6e 74 20 62 20 3d 20 61 20 2b 20 61 20 20 000030 2d 20 31 3b 0a 20 20 20 72 65 74 75 72 6e 20 62 000040 3b 0a 7d 0a 000044 The file is attached: Attachment: Can you not reproduce this? (i.e. are you suggesting it is a Linux only bug?) Dave |
Author: | hoglet [ Sat Aug 12, 2017 1:28 pm ] |
I've updated to the latest compiler version that fixed bug14. I'm getting a new issue now... 16. Incorrect store address of array write I'm having an issue with the code generated from this fragment: Code: for (i = len; i > 0; i--) { x = 10 * pi[i]+ q * i; pi[i] = x % (2 * i - 1); q = x / (2 * i - 1); } Code: 018e pi_25: 018e 2a03 cmp r3,r0 018f d00f 01ca mi.mov r15,r0,pi_26 0191 2a03 cmp r3,r0 0192 500f 01ca z.mov r15,r0,pi_26 0194 28e5 push r5,r14 0195 10c5 fea8 mov r5,r12,-344 0197 0037 mov r7,r3 0198 0457 add r7,r5 0199 0777 ld r7,r7 019a 1005 000a mov r5,r0,10 019c 0071 mov r1,r7 019d 0052 mov r2,r5 019e 190d 0334 jsr r13,r0,__mul 01a0 0016 mov r6,r1 01a1 17c5 fff9 ld r5,r12,-7 01a3 0051 mov r1,r5 01a4 0032 mov r2,r3 01a5 190d 0334 jsr r13,r0,__mul 01a7 0017 mov r7,r1 01a8 0065 mov r5,r6 01a9 0475 add r5,r7 01aa 0054 mov r4,r5 01ab 29e5 pop r5,r14 01ac 10c6 fea8 mov r6,r12,-344 01ae 0035 mov r5,r3 01af 0465 add r5,r6 # r5 contains address of pi[i] 01b0 28e5 push r5,r14 # save r5 01b1 0035 mov r5,r3 # r5 now a working register 01b2 0455 add r5,r5 01b3 0057 mov r7,r5 01b4 1a07 0001 sub r7,r0,1 01b6 0041 mov r1,r4 01b7 0072 mov r2,r7 01b8 190d 0338 jsr r13,r0,__mod 01ba 0651 sto r1,r5 # result stored back to garbage address 01bb 29e5 pop r5,r14 # pop address of pi[i] back off the stace 01bc 0037 mov r7,r3 01bd 0477 add r7,r7 01be 0076 mov r6,r7 01bf 1a06 0001 sub r6,r0,1 01c1 0041 mov r1,r4 01c2 0062 mov r2,r6 01c3 190d 0336 jsr r13,r0,__div 01c5 16c1 fff9 sto r1,r12,-7 01c7 0e13 dec r3,1 01c8 100f 018e mov r15,r0,pi_25 It seems like the instructions at 1ba and 1bb are the wrong way around. Edit: manually swapping them and the program runs successfully. Dave |
Author: | Revaldinho [ Sat Aug 12, 2017 1:43 pm ] |
Quote: The compiler could spit out an "org $100" at the start of code if that would help. But how smart is the assembler ? Can it rearrange where the variables are or does it care ? The compiler could spit out an "org $4000" at the beginning to locate the vars at $4000. But if it's org'd at $4000 can the assembler handle the code being org'd to $100 afterwards ? eg. org $4000 vars org $100 Rob, yes the assembler will deal with this. You can have multiple ORG statements and they can be out of order. (Python syntax for hex is 0x1234 rather than $1234) R |
Author: | hoglet [ Sat Aug 12, 2017 1:49 pm ] |
Hi Rob, Another compiler issue, this time with using longs. I've reduced it to a simple test case that fails. 17. GenerateTempRegPop():register still in use Code: void bug17() { long a, b; a = 1; b = (a*10)/3; } Code: ./c64 bug17.c GenerateTempRegPop():register still in use Dave |
Author: | robfinch [ Sat Aug 12, 2017 2:53 pm ] |
Re: unusual characters I cut and paste the sample from the forum. So there may have been extra garbage added. In any case I was able to reproduce the bug with the bug15 file. Dave, I just wanted to say I appreciate all the testing you're doing. |
Author: | hoglet [ Sat Aug 12, 2017 4:23 pm ] | ||
Post subject: | Re: Porting the C64 compiler to target OPC5 (or OPC6) | ||
robfinch wrote: Dave, I just wanted to say I appreciate all the testing you're doing. And we very much appreciate the efforts you are putting into an OPC6 C Compiler. It's also been a great opportunity to use the debugger in the PiTubeDirect OPC6 Co Processor in anger. This actually makes finding issues pretty painless. It supports break points / watch points on code execution, memory reads and memory writes. You can single step, dump registers, disassemble., dump memory. etc. Memory watch points, for example, have been invaluable in tracking stuff writing to the wrong address. Dave
Author: | BigEd [ Sat Aug 12, 2017 4:28 pm ] |
(Dave, it would be handy, I think, if you could share a couple of screenshots of the debugger in action? The forum copes poorly with very large embedded images, but if you just attach them it will make a thumbnail) |
Author: | hoglet [ Sat Aug 12, 2017 4:58 pm ] |
BigEd wrote: (Dave, it would be handy, I think, if you could share a couple of screenshots of the debugger in action? The forum copes poorly with very large embedded images, but if you just attach them it will make a thumbnail) The process is as follows.... 1. Run the compiler and assembler, which produces srecords Attachment: opc6debug0.png [ 218.56 KiB | Viewed 8107 times ] 2. Switch to a serial console into the BBC Micro (9600 baud) and use the srec command to upload the srecords (just cut and paste!) Attachment: opc6debug1.png [ 161.66 KiB | Viewed 8107 times ] 3. Switch to a second serial console into the PiTubeDirect debugger (115,200 baud), and do some debugging! Attachment: opc6debug2.png [ 151.37 KiB | Viewed 8107 times ] the memory watchpoint firing above is a sign the the code as corrupted itself. The offending instruction was at 0x01ba. Attachment: opc6debug3.png [ 118.7 KiB | Viewed 8107 times ] the assembler listing comes in handy as well. Code: 018e pi_25: 018e 2a03 cmp r3,r0 018f d00f 01ca mi.mov r15,r0,pi_26 0191 2a03 cmp r3,r0 0192 500f 01ca z.mov r15,r0,pi_26 0194 28e5 push r5,r14 0195 10c5 fea8 mov r5,r12,-344 0197 0037 mov r7,r3 0198 0457 add r7,r5 0199 0777 ld r7,r7 019a 1005 000a mov r5,r0,10 019c 0071 mov r1,r7 019d 0052 mov r2,r5 019e 190d 0334 jsr r13,r0,__mul 01a0 0016 mov r6,r1 01a1 17c5 fff9 ld r5,r12,-7 01a3 0051 mov r1,r5 01a4 0032 mov r2,r3 01a5 190d 0334 jsr r13,r0,__mul 01a7 0017 mov r7,r1 01a8 0065 mov r5,r6 01a9 0475 add r5,r7 01aa 0054 mov r4,r5 01ab 29e5 pop r5,r14 01ac 10c6 fea8 mov r6,r12,-344 01ae 0035 mov r5,r3 01af 0465 add r5,r6 01b0 28e5 push r5,r14 01b1 0035 mov r5,r3 01b2 0455 add r5,r5 01b3 0057 mov r7,r5 01b4 1a07 0001 sub r7,r0,1 01b6 0041 mov r1,r4 01b7 0072 mov r2,r7 01b8 190d 0338 jsr r13,r0,__mod 01ba 0651 sto r1,r5 01bb 29e5 pop r5,r14 This is the full command set of the debugger: Attachment: opc6debug4.png [ 60.45 KiB | Viewed 8107 times ] In PiTubeDirect it was about a days work to add OPC6 support: - a C emulation of the CPU (opc6.c) - an implemention of the PiTubeDirect debug interface (opc6_debug.c), which describes the CPU to a generic debugger - a Co Processor wrapper for the CPU (copro-opc6.c) (this is pretty much boiler plate code) Dave |
Author: | BigEd [ Sat Aug 12, 2017 5:04 pm ] |
That's excellent Dave - thanks! |
Author: | robfinch [ Sat Aug 12, 2017 5:32 pm ] |
There's a fix for bugs 16,17 now. The fix caused a fair amount of change to the code generated in my test files. Generates smaller code with the fix to boot. I hope I didn't break something else with the fix. I've just been comparing output from one set of test files to the next generation and reviewing the changes. Usually it's only a couple of lines that change. |
Page 3 of 6 | All times are UTC |
