Last visit was: Fri Sep 11, 2026 7:56 pm
It is currently Fri Sep 11, 2026 7:56 pm
 [ 3 posts ]
 An 8 bit TTL CPU in 16 chips: CSCvon8
This very small CPU design implemented in TTL might be of interest, 8 bits and only 16 chips:
See also Warren's previous tiny machine:
Warren’s Crazy Small CPU (4 bit machine, 11 chips)
See also previously
Fri Apr 05, 2019 4:58 pm
An interesting design - utilising heavily upon the availability of large ROMS
The ALU is implemented using a M27C322 2Mx16 bit EPROM and the decode logic is performed using a M27C1024 64K x 16 EEPROM.
https://processmodeling.org/theory/elec ... 27C322.pdf
This is in a 42 pin DIP and will require a special eprom programmer and adaptor socket to program - which may be a limiting factor to some home constructors.
The access time of the large ROM used in the ALU is 80nS which will be a limiting factor to the clock frequency. Similarly the decode logic ROM has at best a 45nS access time.
Nevertheless, the design shows how an 8 bit Von Neumann architecture can be implemented in a handful of TTL devices and four large memory chips.
The project detail, including devices used, instruction set etc can be found from this link:
https://github.com/DoctorWkt/CSCvon8/bl ... _design.md
Sat Apr 06, 2019 9:20 am
An interesting observation: not so many chips, but a great many transistors! Those are big EPROMs in impressively big packages.
Still, the principle of making moderately simple hardware and then putting the detail into a lookup table or in microcode is a good one, when those things are cheap.
Sat Apr 06, 2019 6:50 pm
 [ 3 posts ]
Users browsing this forum: Baidu [Spider], claudebot and 10 guests
