| Donn Stewart's homebrew CPUs (CPUville) http://anycpu.org/forum/viewtopic.php?f=3&t=669 |
Page 1 of 1 |
| Author: | BigEd [ Fri Jan 03, 2020 12:50 pm ] |
| Post subject: | Donn Stewart's homebrew CPUs (CPUville) |
A couple of interesting projects from Donn Stewart: The original CPUville homebuilt processor of 2004 ![]() and ten years later, another one: My Home-Built 8-bit TTL Computer Processor (CPU) Video demo: ![]() Quote: The original processor had a single instruction format (4-bit opcode, 12-bit operand), and a 16-bit memory width so I could fetch instructions in one step from a 16-bit wide memory. It had only a 12-bit memory space (4K words). The ALU was 12-bits wide, but because of that I was unable to load instructions over a serial interface as two 8-bit words -- the processor could not assemble a 16-bit instruction from two 8-bit input bytes! I cobbled together a port that that would shift the first of two input bytes into the high-order byte of a 16-bit word, but it was a kludge. The processor worked, but it was far from elegant. It had a very small memory space, and an ALU that did not do subtract-with-borrow correctly. |
