View unanswered posts | View active topics It is currently Sat Apr 27, 2024 2:20 pm
Reply to topic  [ 1 post ]
 Details of T42 a transputer in VHDL (no source yet)
There's a preprint of an interesting paper by Uwe MIELKE and Martin ZABEL, in collaboration with Michael BRUESTLE, about the T42 transputer re-implementation:
http://wotug.cs.unlv.edu/cpa2018/prepri ... eprint.pdf
The T42 Transputer in FPGA is a full binary-code compatible opensource VHDL implementation of the Inmos IMS-T425 32bit microprocessor.
This is an integer-only, simple microarchitecture, microcoded machine. Many links in the references, and comparisons within to other re-implementations and other cores.
There seems to be an intent to publish source but it seems not to have happened yet.
Our T42 open-source Transputer-in-FPGA is a full binary-code compatible design to the Inmos IMS-T425 32bit version of the Transputer. Our self-developed microcode will cover the full instruction set. Any still available Transputer software should run. Support of many cores in FPGA was intended from the beginning and quite a large number of interlinked T42 cores can be loaded on suitable sized FPGA boards. For external memory extension state-of-the-art DDR-SDRAM can be connected to the T42 core. Therefore all initial design targets have been achieved.
Sat Jan 04, 2020 1:13 pm
Users browsing this forum: No registered users and 125 guests
