Last visit was: Fri Nov 13, 2026 3:53 pm
It is currently Fri Nov 13, 2026 3:53 pm
 [ 8 posts ]
 Pineapple ONE a RISC-V Computer in TTL
A multi-board design, running up to 500kHz, started in Logisim-Evolution:
After 6 months of fiddling with Logisim, I had a working 'simulation.' The next step would be to create schematics for all of the modules, design all PCBs and order them from JLCPCB.
Article here:
Filip Szkandera's Pineapple ONE
Video here:
https://www.youtube.com/watch?v=NUAVKNVrPh0
(Via the El Correo Libre newsletter, for free and open source silicon solutions.)
Tue May 11, 2021 10:45 am
What's amazing is that this is a 32 bit processor that only takes up this much space. I figured it'd be more like the size of a desk. Pretty darn cool. I wish there was more info...
Fri May 14, 2021 9:56 pm
Well remember it is using a modest amount of modern memory, and I/O are 1 chip per device, thus only one slice of the pinaple. Can't tell if a SD card is hiding in that stack. A 'Pineaple' could have be a apple II clone,as Fruit names were popular back then. I have used a DESK sized computer, a IBM 1130 for about a hour or two. I think it had 32KB of memory from the mid 1970's. The card reader, punch and printer took up most the computer room.
Nice to see the pineaple one working on the first revision. Ben.
Sat May 15, 2021 10:24 am
More details available on his Hackaday project page :-
https://hackaday.io/project/178826-pineapple-one
 Specifications:
"Max" clock speed: 500 kHz
Program memory: 512 kB
RAM size: 512 kB
VGA Output: 200x150 px (black and white)
2x 8-bit Input ports
2x 8-bit output ports
Using mostly 74HCT chips.
Quite impressed that he got the 230 chips into such a small volume.
Sat May 15, 2021 11:42 am
I was just reading about RetroBsd and that needs about 1 meg of memory. http://retrobsd.org/wiki/doku.php
"SmallerC" is the compiler used. https://github.com/alexfru/SmallerC Pineapple may need a bit of tweeking to run unix.
Sat May 15, 2021 6:49 pm
Nothing is impossible - I want to release it as open-source and find some people wanting to take this project to another level. Main goal would be to improve upon what I have already done and maybe even run (very slowly though) retrobsd or something else. After some redesign (and if there will be some demand), this could become a sort of DIY kit for advanced soldering (or pre-assembled, who knows) - you would be able to build a 32 bit CPU yourself, which is not really a common thing to do :).
But I cannot do this alone. There are many things to improve (or redesign in some way) that would needed to be done in order of becoming a "product" - for example like the Gigatron computer.
I will be making a short video explaining all this in upcoming days. If you think you can help - In any way - please drop me an email (filip.szkandera@gmail.com) or message me on Twitter (https://twitter.com/ten_filip), it would be very appreciated.
Tue May 18, 2021 8:51 pm
Welcome Filip - great project!
Tue May 18, 2021 8:56 pm
Thank you! Took a lot of work but it was totally worth it!
Tue May 18, 2021 9:05 pm
 [ 8 posts ]
Users browsing this forum: Baidu [Spider], claudebot, DotBot, KakaoBot, SemrushBot and 26 guests
