Last visit was: Wed Sep 02, 2026 5:28 am
It is currently Wed Sep 02, 2026 5:28 am
 [ 2 posts ]
 clike a retargetable C-ish compiler
As mentioned over on the myStorm forums:
Nearby, @metaprogrammer said:
Hi! I also explored using tiny ice40 FPGAs for compute acceleration with HLS, have a look at SoC - you can fit quite a surprising amount of logic into those puny 8k cells.
I'd like to know more about the c2 RISC in this project (one of 3 CPUs included!) and also about how readily portable the clike compiler is to other simple machines (and I have in mind OPC7)
Wed Apr 10, 2019 3:56 pm
Notes from the repo:
A simple C-like language compiler with an extensible syntax and typed macros support
CLike 0.1 is a low-level programming language with an extensible syntax based on C.
CLike targets LLVM, tested with LLVM 3.5.
CLike is implemented in PFront, a domain-specific language for compiler construction.
C is a very low level language, without any built-in means for extensibility... CLike was designed to expore the design space of extensible syntax languages and a Lisp-style metaprogramming in a statically typed environment.
Wed Apr 10, 2019 5:39 pm
 [ 2 posts ]
Users browsing this forum: claudebot and 4 guests
