View unanswered posts | View active topics It is currently Sun Apr 28, 2024 5:26 pm
Reply to topic  [ 7 posts ]
 A2Z Computer
Hello,
I am new to this forum. I am F4HDK, a hobbyist from France.
I would like to present my last project that I have just completed and documented here :
https://hackaday.io/project/18206-a2z-computer
Video: https://www.youtube.com/watch?v=76hnOPgyzr0
It is called “A2Z computer”. It is a computer made from scratch. Every part is invented, designed, and built/coded by me. I have not copied/ported existing architectures or code or software library. This is a didactic project, the goal is to learn about every part of a simple computer, from low level hardware to software, compiler.
Hardware (programmed in Verilog on a small FPGA) :
  • Custom CPU RISC 16bits (address bus 24 bits), with a custom instruction set, with Integer ALU, without interrupt capabilities
  • SRAM 2MB
  • VGA with 2 parts :
    1) Graphics 640 x 480 x 60Hz ; 256 colors; double buffering; video RAM shared with CPU
    2) Text overlaid (over graphic) 80 x 30
  • PS/2 keyboard interface
  • Serial port (interface with development PC)
  • SPI interface with a 16MB Flash chip
Software:
  • Custom basic language, with a homemade compiler
  • Assembler
  • Basic file system, and (very) simple OS
  • A text editor
  • Image viewer and map viewer
  • A car game like MicroMachines
Do not hesitate to give me feedback, or ask any question!
F4HDK
Sat Jan 14, 2017 8:58 am
Welcome! Very impressive!
Sat Jan 14, 2017 9:20 am
Fantastic job, well done - and welcome!
I'll read through your project logs and have a look at your sources - should be very interesting.
Sat Jan 14, 2017 11:49 am
Allo. Quite an accomplishment.
Sat Jan 14, 2017 3:31 pm
Amazing work! And welcome to the forum.
Sat Jan 14, 2017 5:51 pm
Congratulations.
Do you plan on making any upgrades?
Is this computer scalable?
Sat Mar 25, 2017 8:08 pm
Thank you all for your feedback.
Currently, no, I consider that this project is finished.
I have lots of other projects in my "to do" list.
So unless someone wants to really use this project (as an educationnal material for example), I will not work anymore on it.
If someone is really interested, I will probably change my opinion.
It depends what you mean by "scalable".
* RAM and Flash : that's the easy part. It would be very easy to add SRAM and Flash. The computer has 24 address lines, and can address 16MB or RAM (minus peripherals). I could easilly change the memory module to a module on a PCB with SRAM, exactly like yours (http://wilsonminesco.com/)
* peripherals : The easiest way to add peripherals would be to use the SPI bus (currently used only for Flash Memory). Adding a Wiznet Chip for Ethernet interface for example. There is still space on the veroboard for that.
* Software : currently, this CPU is compatible with... nothing. That's good for educational purpose : I had to code everything from scratch. "Learning by doing" is the main goal of this project.
But if you want to add a new functionnality, you need to code it!
So a major improvement for scalability would be to retarget an existing C COMPILER. That is necessary if I want to port existing code. A sofware enthousiast has already thought about it. And he has proved that the core of this CPU lacks too many things : indirect addressing, some operations in ALU, etc...
* CPU : so if I want to make this CPU really usable, and really scalable, the first thing to do is to make modifications inside the CPU, and add vital features : indirect addressing, ALU operations, interrupts, etc...
F4HDK.
Sun Mar 26, 2017 5:52 am
Users browsing this forum: No registered users and 103 guests
