View unanswered posts | View active topics It is currently Sat May 04, 2024 2:10 am
Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
Fri May 22, 2015 1:49 pm
-- Jeff
* Clock Rate: 60 Hertz
* Instruction Repertoire: 1
Sat May 23, 2015 2:02 pm
Sat May 23, 2015 2:55 pm
-- Jeff
Sat May 23, 2015 4:14 pm
The DVG features:
• Four-level stack
• Vector timer
• 16-level brightness control
Mon May 25, 2015 3:51 pm
where the question is
Dajgoro wrote:
Is it possible?
and Arlet:
http://betaic.com/SW5000/
Finally, Arlet says
(Programmable State Machines)
by Ken Chapman: pdf here.
Tue May 26, 2015 1:17 pm
Sat Apr 15, 2017 6:31 pm
Thu Apr 27, 2017 4:03 pm
Ed,
regards
Ken
Mon Aug 14, 2017 1:11 pm
Mon Aug 14, 2017 2:17 pm
Hi Ed,
; Ken Boak May June 2017
; SIMPL_430ASM_16
; Input and Output
; ADD +
; SUB -
; SHR /
; SHL *
; AND &
; OR |
; XOR ^
; INV ~
; DUP “
; DROP `
; PUSH ,
; POP ‘
; SWAP $
; OVER %
; FETCH @
; STORE !
; CALL :
; RETURN ;
; JMP \
; JE =
; JGT >
; JLT <
; TO-R {
; FROM-R }
; LOOP-Strt (
; LOOP-End )
; IN [
; OUT ]
; KEY ?
; PRINT _
; NOP Space
; LIT #
;a
;b
;c
;d
;e
;f
;g
;h set port pin high
;i input byte from port
;j
;l set port pin low
;m milliseconds delay
;n
;o output byte to port
;r read input pin
;s sample the ADC
;t
;u microseconds delay
;v
;w
;x
;y
;z
;A
;B
;C
;D
;E
;F
;G
;H
;I
;J
;L
;M
;N
;O
;P
;Q
;R
;S
;T
;U
;V
;W
;X
;Y
;Z
; Examples of SIMPL phrases
; 123 456+p
; 10(_Spurs are Fab!_)
; 10(h100ml200m)
; That's all folks!
Mon Aug 14, 2017 3:39 pm
;   DUP       “
;   DROP      `
;   PUSH      ,
;   POP       ‘
;   SWAP      $
;   OVER      %
;   FETCH     @
;   STORE     !
;   CALL      :
;   RETURN    ;
;   JMP       \
;   JE        =
Instead, you'll get
Mon Aug 14, 2017 7:23 pm
Mon Aug 14, 2017 7:31 pm
Mon Jan 13, 2020 2:55 pm
But the reference to
as found in the repository
Mon Jan 13, 2020 4:51 pm
