Garth wrote:
This was recently posted on another forum:
http://spectrum.ieee.org/geek-life/hist ... oprocessor(written by a microprocessor manager in TI's MOS division)
The Inside Story of Texas Instruments’ Biggest Blunder: The TMS9900 Microprocessor
The TMS9900 could have powered the PC revolution. Here’s why it didn’t
(I don't know anything about it other than what's in the article from a very credible source, but I'm always glad to see Forth ported to another computer.)
I always assumed that the x86 was a given for the IBM-PC because it is similar to the 8080 and this would allow easy porting of CP/M programs to the IBM-PC. There was an 8080 assembler available that generated x86 machine-code, so 8080 programs could be converted directly into MS-DOS .com programs.
Wasn't the BIOS pretty similar between CP/M and MS-DOS machines?
A lot of people think the MC68000 was far better than the x86. To a large extent it was.
I always thought the x86 ISA was pretty good for the 1980s though. Using segmented memory it was able to address more than 64KB while still using 16-bit registers --- using 16-bit rather than 32-bit roughly makes your data half the size, so you get less memory usage, which is important because RAM was very expensive in those days. Also, using 32-bit data when you don't really need to slows down the system because you have a 16-bit data-bus.
The advantage of the MC68000 is that it was forward-thinking. The designers expected the limitations of the 1980s (expensive RAM chips and a 16-bit data-bus) to go away --- that was true --- in less than a decade, building a computer with 1MB or more of RAM and a 32-bit data-bus became realistic.
