Tor
robfinch wrote: 'C' does not guarantee the order in which the auto-inc and auto-dec operations take place. Different compilers support them differently. If one does something like p[ndx++] the index may be updated either before or after it's used to index the element depending on the compiler. This is not correct, as far as I know. N++ and ++N are well defined. Code: if (a++) /* Test, then increment */ if (++a) /* Increment, then test */
If the sequence is undetermined it would be impossible to do things like the above, or this snippet from BSD strlcpy: Code: while (--n != 0){ if ((*d++ = *s++) == '\0') break; }
Fri Aug 11, 2017 8:52 am |
robfinch wrote: If one does something like p[ndx++] the index may be updated either before or after it's used to index the element depending on the compiler. Are you absolutely sure? Although there are difficulties with the semantics of pre and post increment and decrement, I don't think this is one of them. Edit: oops, I see I failed to notice the reply from Tor.
Fri Aug 11, 2017 8:53 am |
hoglet
robfinch wrote: Okay, I have updated the compiler. I got little side-tracked trying to add a color-graphing register allocator. It's just a bit too complex for me to understand So I've been researching and scratching my head. Excellent, I'll continue testing the Pi program this morning. Current code is here: https://github.com/hoglet67/opc/tree/c_ ... i-spigot-cAre you happy for me to continue to report issues here? robfinch wrote: 'C' does not guarantee the order in which the auto-inc and auto-dec operations take place. Different compilers support them differently. If one does something like p[ndx++] the index may be updated either before or after it's used to index the element depending on the compiler. I think not even brackets are respected. When I found this out I started writing all the inc/dec operations as separate instructions with a semi-colon. So I write p[ndx]; ndx++; to guarantee the order and it's portable between compilers. (Yes I got burned on this issue before).
My understanding is the opposite. *ptr++ is evaluated as *(ptr++) because the precedence of the postfix increment operator is higher than the dereference operator. ptr++ should be evaluated as ptr, and the increment should happen afterwards. This is what section 6.5.2.4 of the ANSI C standard (C99) says: Quote: 2 The result of the postfix ++ operator is the value of the operand. After the result is obtained, the value of the operand is incremented. (That is, the value 1 of the appropriate type is added to it.) See the discussions of additive operators and compound assignment for information on constraints, types, and conversions and the effects of operations on pointers. The side effect of updating the stored value of the operand shall occur between the previous and the next sequence point
http://www.open-std.org/jtc1/sc22/wg14/ ... df#page=87This is consistent with the C89 version: http://port70.net/~nsz/c/c89/c89-draft.html#3.3.2.4Section 2.8 of K&R (2nd Edition) (page 46) says the same. As does the 1st Edition ( archive.org). There may be some compilers that get this wrong, but it seems pretty clear the compiler would be at fault, rather than the spec being ambiguous. Dave
Fri Aug 11, 2017 9:28 am |
More on #4.
outch(*ptr++);
Currently gets evalulated like: outch (*(ptr++));
If I move the ++ later it gets evaluated like:
outch((*ptr)++);
which increments the character, probably not what is desired.
However I have to admit that most C compilers do what the person programming expects.
I can probably put a hack in to see if there's an identifier directly before the ++. I'm not sure what'll happen with a more complex expression though.
Suppose its: outch(*structvar.member++);
The ++ would increment the struct member then, if it's just a simple identifier check. More head scratching. I think I can fix it. Some experimentation required.
Fri Aug 11, 2017 9:57 am |
hoglet
Hi Rob, I can understand how postfix increment might be a pain to implement. As long as we know, it can easily be avoided. I'm continuing debugging the Pi program. Here's the next issue: 11. Array read not dereferenced properlyCode: x = 10 * pi[i]+ q * i;
Code: 018d 10c5 fea8 mov r5,r12,-344 # r5 is now the address of pi[0] 018f 0037 mov r7,r3 # r3 is i 0190 0457 add r7,r5 # r7 is now the address of pi[i] 0191 1005 000a mov r5,r0,10 0193 0071 mov r1,r7 # This should be ld r1, r7 as r7 is the address of pi[i] 0194 0052 mov r2,r5 0195 190d 02e9 jsr r13,r0,__mul 0197 0016 mov r6,r1 0198 17c5 fff9 ld r5,r12,-7 019a 0051 mov r1,r5 019b 0032 mov r2,r3 019c 190d 02e9 jsr r13,r0,__mul 019e 0017 mov r7,r1 019f 0065 mov r5,r6 01a0 0475 add r5,r7 01a1 0054 mov r4,r5
Dave
Fri Aug 11, 2017 10:17 am |
hoglet
And the next one. 12. Multiply by 2 not correctCode: int bug12() { int a = 123; int b = a * 2; return b; }
Code: _bug12: push r13,r14 push r12,r14 mov r12,r14 dec r14,2 mov r5,r0,123 sto r5,r12,-1 ld r5,r12,-1 add r5,r0 # should be add r5, r5 sto r5,r12,-2 ld r5,r12,-2 mov r1,r5 mov r14,r12 pop r12,r14 pop r13,r14 mov r15,r13
Fri Aug 11, 2017 10:42 am |
hoglet
And after manually patching the generated code for (11) and (12) we get: Code: *go 100 @ABCD 1234 5678 3.141592653589793238462643383279502884197169399375105820974944592307816406286208998628034825342117067 *
Dave
Fri Aug 11, 2017 10:55 am |
Hurrah - a milestone! Congrats to everyone involved!
Fri Aug 11, 2017 10:57 am |
hoglet
Here's 250 digits: Code: *go 100 @ABCD 1234 5678 3.1415926535897932384626433832795028841971693993751058209749445923078164062862089986280348 [line breaks] 253421170679821480865132823066470938446095505822317253594081284811174502841027019385211055 [added by mod] 596446229489549303819644288109756659334461284756482337867831652712019091 *
13. Compiler crashes:I'm hitting a couple of compiler crashes if I change the integer type from "int" to "unsigned int" or "long int": Using "unsigned int": Code: ./c64 pi.c GenerateTempRegPop()/2
Using "long int": Code: dmb@quadhog:~/atom/opc/examples/pi-spigot-c$ ./c64 pi.c Segmentation fault (core dumped)
And the latter in gdb: Code: dmb@quadhog:~/atom/opc/examples/pi-spigot-c$ gdb ./c64 core GNU gdb (Ubuntu 7.7.1-0ubuntu5~14.04.2) 7.7.1 Copyright (C) 2014 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "i686-linux-gnu". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>. Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/>. For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from ./c64...done. [New LWP 6714] Core was generated by `./c64 pi.c'. Program terminated with signal SIGSEGV, Segmentation fault. #0 0x0804d02d in GenerateBinary (node=0x9154e2c, flags=33807, size=1, op=0) at CodeGenerator.cpp:906 906 ap3->isAddress = ap1->isAddress | ap2->isAddress; (gdb) bt #0 0x0804d02d in GenerateBinary (node=0x9154e2c, flags=33807, size=1, op=0) at CodeGenerator.cpp:906 #1 0x0805085a in GenerateExpression (node=0x9154e2c, flags=33807, size=1) at CodeGenerator.cpp:2113 #2 0x080561d2 in Statement::Generate (this=0x9154d74) at GenerateStatement.cpp:742 #3 0x08056058 in Statement::GenerateCompound (this=0x9154d14) at GenerateStatement.cpp:677 #4 0x0805612a in Statement::Generate (this=0x9154d14) at GenerateStatement.cpp:713 #5 0x08054b07 in Statement::GenerateFor (this=0x9154c5c) at GenerateStatement.cpp:254 #6 0x08056260 in Statement::Generate (this=0x9154aec) at GenerateStatement.cpp:767 #7 0x08056058 in Statement::GenerateCompound (this=0x914fa94) at GenerateStatement.cpp:677 #8 0x0805612a in Statement::Generate (this=0x914fa94) at GenerateStatement.cpp:713 #9 0x0805dec3 in GenerateFunction (sym=0x809864c <compiler+43308>) at OPC6.cpp:560 #10 0x080709d1 in ParseFunctionBody (sp=0x809864c <compiler+43308>) at ParseFunction.cpp:468 #11 0x080703a7 in ParseFunction (sp=0x809864c <compiler+43308>) at ParseFunction.cpp:336 #12 0x080665fb in Declaration::declare (parent=0x0, table=0x808c000 <gsyms>, al=2, ilc=0, ztype=28) at ParseDeclarations.cpp:1385 #13 0x08066bb6 in GlobalDeclaration::Parse (this=0x9149a44) at ParseDeclarations.cpp:1527 #14 0x08051e43 in Compiler::compile (this=0x808dd20 <compiler>) at Compiler.cpp:105 #15 0x0804a850 in main (argc=1, argv=0xbfdf53d8) at Cmain.cpp:82 (gdb) print ap1 $1 = (AMODE *) 0x915f954 (gdb) print ap2 $2 = (AMODE *) 0x0 (gdb) print ap3 $3 = (AMODE *) 0x915f93c (gdb)
Dave
Fri Aug 11, 2017 11:37 am |
Tor wrote: robfinch wrote: 'C' does not guarantee the order in which the auto-inc and auto-dec operations take place. Different compilers support them differently. If one does something like p[ndx++] the index may be updated either before or after it's used to index the element depending on the compiler. This is not correct, as far as I know. N++ and ++N are well defined. This is something I ran into in the K&R C book, 2nd Edition, a few months ago. P.53-54 say, Function calls, nested assignment statements, and increment and decrement operators cause "side effects"—some variable is changed as a by-product of the evaluation of an expression. In any expression involving side effects, there can be subtle dependencies on the order in which variables taking part in the expression are updated. One unhappy situation is typified by the statement
The question is whether the subscript is the old value of i or the new. Compilers can interpret this in different way, and generate different answers depending on their interpretation. The standard intentionally leaves most such matters unspecified. When side effects (assignment to variables) take place within an expression is left to the discretion of the compiler, since the best order depends strongly on machine architecture. P.90 says, Reading the book (and part of another on C) in the extent of my expertise on C. You guys know the language much better than I; but I thought I'd bring this in, from the horse's mouth.
Fri Aug 11, 2017 5:22 pm |
It's true, there are pitfalls, but I think they are not difficult to avoid. If you were really nervous you could just avoid using increment and decrement in complex expressions.
But I think, other than Rob, we believe the simple case of func(a++) or even func(*a++) are not pitfall territory - they are well-defined.
Fri Aug 11, 2017 5:30 pm |
(I'm not sure if this will help anyone, but there's a thing called sequence points which define when C actually makes changes to values. Or something.)
Fri Aug 11, 2017 6:54 pm |
Okay, the latest fix for the compiler is available. An address mode spec of am_ind needed to be added to the GenerateIndex() function to fix the array reference problem. Shifts should be fixed too.
I tried several combinations of unsigned int / int but couldn't get the compiler to crash. Could I please have a sample program ?
The compiler sometimes generates better code if n++ is used rather than n = n + 1.
Fri Aug 11, 2017 9:40 pm |
Okay, the latest fix for the compiler is available. Fixes crashes having to do with long variables.
Fri Aug 11, 2017 11:12 pm |
Another fix for the compiler. It should fix references to globals variables. The compiler as it is outputs variable declarations as it encounters them in the program. For 'C' variables must be declared before they are referenced in the program. This means the compiler will output space for global variables *before* code is output. This is opposite to what is expected to be loaded. I could possibly have the compiler output a jump instruction first to jump around the global variables. Or it might be easier to output a couple of special labels "__begin_data" "__end_data" so that the variable space can be cut from the source file and pasted after the code. Could this be done by the assembler ? Code: # bss _pi: WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0 WORD 0
# code _main: # int pi[20]; push r13,r14 push r12,r14 mov r12,r14 # int x, i; dec r14,2 # x = 10 * pi[i]; ld r7,r12,-2 mov r6,r7 ld r6,r6,_pi mov r7,r0,10 mov r1,r6 mov r2,r7 jsr r13,r0,__mul mov r5,r1 sto r5,r12,-1 mov r14,r12 pop r12,r14 pop r13,r14 mov r15,r13
# rodata # global _main # global _pi
Sat Aug 12, 2017 5:07 am |
