View unanswered posts | View active topics It is currently Thu Apr 25, 2024 7:58 pm
Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
 A good CPU to start with?
Online
Sun Mar 04, 2018 9:10 am
The TOYF assembly-language is about 4x more difficult than the MSP430 assembly-language --- but also about 4x easier than than the MiniForth assembly-language.
I'm not trying to make the assembly-language programmer's life easy --- I'm trying to wring as much performance out of the processor as possible --- my latest design is about 2x more efficient than the last one posted on this forum, but somewhat more difficult to program.
The 8051 is somewhat "scrappy" --- it is also not documented well (it wasn't in 1994, anyway), so I had difficulty learning it --- it is the most popular micro-controller of all time though, so it is worth learning.
The 80c320 has two DPTR registers whereas the 8032 (and 8051, etc.) had one DPTR. This helps a lot! For example, copying a block of data is more efficient.
The 80c320 executes an instruction in 4 clock cycles, whereas the 8032 needed 12 clock cycles, so the '320 is 3x faster. The '320 also runs at 33 Mhz. max, which is pretty fast (by 1994 standards).
In 1994 there was an 80c320 version with 2KB of RAM internal, plus the low-memory --- this was very inexpensive, assuming that it was adequate --- using external memory boosts the price a lot.
There is a version of the 80c320 that is designed to be secure. There is foil over the internal non-volatile memory that is supposed to prevent the chip from being dismantled and the non-volatile memory probed to obtain the machine-code. I don't know how well this works.
As an historical note, Testra used the 80c320 for their motion-control boards for the laser-etcher. This was not competitive in speed with the competitor's MC68000 system. This was primarily because the 80c320 has only an 8x8 multiply, but 16x16 was needed. The MiniForth (built on a Lattice isp1048 PLD) was designed to fix this problem. The MiniForth was both faster and less expensive than the M68000 system --- that was in 1995 --- now the MiniForth has been upgraded to an FPGA and is several times faster (the name has been changed to RACE).
I would expect my TOYF to be roughly comparable to the RACE --- maybe more efficient --- I'm not familiar with the RACE, but afaik it is pretty much the same design as the MiniForth (they still use my MFX for development).
Anyway --- getting back to the question of a good CPU to start with --- the 80c320 seems powerful enough to support interesting projects, but still fairly simple if you can get by with 2KB of RAM and have a single-chip board.
I would certainly go with the 80c320 rather than the 6803/6303 etc.. OTOH, the 6502 is just a lot of fun, and there is a huge nostalgia aspect --- the problem with the 6502 is that you necessarily have a multi-chip board which is complicated and expensive.
Tue Mar 06, 2018 2:55 am
Garth wrote:
Hugh Aguilar wrote:
The 65c816 is a lot more powerful than the 65c02 for working with 16-bit data and/or programs that are large enough to need data-structures --- the '816 also can access up to 16MB of memory.
The reason why I like the Dallas 80c320 though, is that it has instructions for working with 1-bit data.
I have read that in the late 1980s there was a 6502 version that had instructions for working with 1-bit data. If such a thing is available today, and it has on-chip RAM and PIA so you don't need a complicated multi-chip board, then I would prefer that to the '320 --- the '320 lacks an indexed addressing-mode so it is pretty hard to program --- the 65c02 is much easier to program.
My 65ISR has instructions for working with 1-bit data (borrowed from the '320), and it has an indexed addressing-mode (borrowed from the 65c02) --- the 65ISR-abu can access up to 16MB of memory --- so it is intended to be the best of both worlds!
Sun Mar 11, 2018 3:01 am
Sun Mar 11, 2018 4:33 am
Sun Mar 11, 2018 4:39 am
Those are pretty good techniques. :-)
The 65c02 has the (zp),Y addressing-mode --- this allows it to work with data-structures --- you can have as many pointers in use in zero-page as you need.
The 65c02 (and 6510) was used in personal computers in the 1980s --- I would still consider the 65c02 to be a good choice for small computers --- for example, a POS terminal.
I'm dubious of the 65c134 that you mentioned above that has 192 bytes of RAM and 4KB of ROM. You aren't going to use your (zp),Y addressing-mode at all --- a lot of the features of the 65c02 aren't going to be used.
For a tiny application that needs only 192 bytes of RAM, the PIC16 or ye olde 8051 seem like more appropriate choices.
The Dallas 80c320 has 2KB of RAM internal to the chip --- as I said though, the '320 is more difficult to program.
If there were a 65c02 version with at least 2KB of RAM internal to the chip, that would be pretty cool --- this could likely be accomplished with an FPGA using a 65c02 core, as FPGAs can have a lot of RAM internal to the chip.
Mon Mar 12, 2018 4:56 pm
Garth wrote:
Here is the latest/greatest in the 8051 family: http://www.keil.com/dd/docs/datashts/da ... 89c420.pdf
I have used the PIC16. I agree that it is pretty prickly, although after you develop some macros it gets better.
I am more interested in the 8051 family because they can either be used in single-chip mode (similar to the PIC chips) or they can have external memory. So, you have a wider range of applications, but only have to learn one instruction set.
I didn't know the PIC chips had: "availability in many variations from many distributors." I thought they were only from MicroChip.
The 8051 family has been second-sourced by a lot of chip makers during its three decade history, and there are many variations available with different I/O configurations.
This thread asking for a "good CPU to start with" is unlikely to provide any useful information. How do we know where we should start if we don't specify where we want to end up? What is the goal? There is a lot of difference between Garth's favorite processor, the 65c816, and this DS89c420. That doesn't mean that one is better than the other though. There is some overlap in what they do, but they are really for different purposes --- and there are yet other ISAs that are also quite different from either of these --- my TOYF and 65ISR designs are both pretty far out; not similar to each other or to anything else.
Tue Mar 20, 2018 6:27 pm
Yes, I think Microchip is the only manufacturer; but you can get their parts from lots of different distributors, "distributor" meaning for example Mouser, Digi-Key, Jameco, Allied, Arrow, Avnet, Future Electronics, etc..
I had to review where this topic started, to refresh my memory. We haven't heard from Koriban in almost four years, and there was a gap between posts of about two and a half years in the middle of the topic. I originally understood it to mean, "What's a good processor to start with to learn about building a computer and about programming in assembly language" (even if a higher-level language is used also).
"There is a lot of difference between Garth's favorite processor, the 65c816,"
For me, what it has going for it is familiarity, and that there's more power there than meets the eye, and that I'm somewhat optimistic about its future. The familiarity point won't be true for everyone, only those already into the 65 family, mainly meaning people who have gotten a start in 6502 somewhere along the way. It does have appeal though in its having a relatively simple bus structure and programming model. It's not quite as simple as the 6502's, but it's a natural step up from the '02.
And rather than jumping around on different processor families or trying to get cozy with lots of processors, I think there's something to be said for focusing on one and getting really good at it, whether it's the 65 family or another family. For my interests, the 65's are well suited. If I were interested in certain other fields of computing, it might not be so well suited. I take the same "stick with one" approach to other parts in my work as well, for example op amps or switching regulator controller ICs, because through use, you learn important nuances that might not be obvious or clear in the data sheets. There are thousands of these on the market. Certainly one op amp or switching regulator controller IC can't be best the whole range of things you might want, nor can you be familiar with very many; but the required learning investment keeps me from jumping to a new one without good reason.
Wed Mar 21, 2018 7:30 am
Online
Wed Mar 21, 2018 8:46 am
The 65c816 was originally designed to be used in the Apple-IIgs computer, and that lasted for a while. Later on, the '816 was used in the Super Nintendo game computer (Mario and his dinosaur Yoshi), and that lasted for a while.
I agree --- don't be a: "Jack of all processors and a master of none" --- find one that is reasonable, then get good at it.
I invented the TOYF because I wanted to be good at something. :)
I could pick an existing processor, such as the hugely popular ARM Cortex, but I doubt that I would ever distinguish myself at all. The bottom line is that I don't have a college degree, so I'm automatically disqualified from programming mainstream processors --- there will always be somebody with a college degree applying for the same job.
It does seem unlikely that anybody else will be interested in the TOYF --- I think it is a pretty efficient design --- it is not backed up by any major chip-maker though, so the TOYF is destined to be a VCIW (voice crying in the wilderness).
The 65c816 and eZ80 are VCIWs too --- a small computer such as I described above (POS terminal or factory data-entry terminal) is likely to be built on the ARM Cortex (the Raspberry Pi, Beagle Bone, etc.) --- there is not much call for 8-bit computers any more.
Wed Mar 21, 2018 5:39 pm
Users browsing this forum: No registered users and 15 guests
