Last visit was: Wed Sep 17, 2025 11:56 pm
It is currently Wed Sep 17, 2025 11:56 pm
Geri
Helo, i decided to post Dawn OS here too, i am sure some of the users here alreday aware of this system, any question is welcome, if i have time, i will answer them. Dawn operating system is the first high-level operating system built for URISC computers. Other operating systems are designed to run on extremely complex hardware environments, but Dawn operating system is designed for the SUBLEQ architecture, which have no traditional instruction set. This allows a Dawn compatible processor and computer to be designed from a millionth costs than a traditional CPU. Dawn is a modern graphics operating system, it supports the folowing features: - Big-endian 64-bit SUBLEQ CPU - Mouse - Keyboard - Virtual keyboard - Touchscreen - Multitouch - 64-bit sound input and output on 8 channels - 4 force-feedback joysticks - 16 RGB cameras - up to 32-bit RGBA graphics output, transparent screens are also supported - An own p2p wireless networking protocol based on geolocation and requiring no external network provider cormprations - CPU hotplug - Disk drive hotplug - Up to 100 individual disk-drive - Basic tools like document reader, paint, wave player, process explorer, etc - Some simple games like chess, amoeba - C/C99 compiler that is capable of compiling codes written for the C programming language - SMP support, up to basically unlimited CPU cores - Very simple IO system that will stay constant for all future versions - Memory and disk size support up to 2^63 bytes - Battery, and power-saving features - UTF8, unicode, ASCII - Fast boot and shutdown Dawn currently has precompiled emulator for x86 (windows and linux) and arm (android) platforms. Dawn is also capable to run on the GPU (with opencl). The package contains several opensource emulators as well, to guide others to write they own emulator if interested. download: http://users.atw.hu/gerigeri/DawnOS/download.html
_________________Dawn - the operating system for SUBLEQ architecture: http://users.atw.hu/gerigeri/DawnOS/download.html
Fri May 11, 2018 5:48 pm |
Welcome Geri!
Sat May 12, 2018 7:20 am |
Geri
yes, i provide c compiler for subleq (its selfhosting, so it also compiles the os and itself). it can be accessed in the os (start menu / tools / coder). the codes compiled with it can also be runned on bare hardware, if you dont use operating system calls like fopen or malloc, etc.
Sat May 12, 2018 1:09 pm |
Hi Geri, I find the choice to build an operating system around a SUBLEQ processor interesting. I would think the operating system for a SUBLEQ processor would be built around some sort of virtual machine running on the SUBLEQ. Is Dawn component based or monolithic ?
Sat May 19, 2018 4:04 am |
Geri
robfinch: thankyou for the questions, Dawn is a monolithic kernel. and it is compiled natively for subleq for performance reasons (running a virtual machine on top of subleq would not give satisfactory performance to run an os).
Mon May 21, 2018 6:00 pm |
Mon May 21, 2018 6:06 pm |
Geri
BigEd subroutine call: yes, as the architecture have no registers or hardware stack handling, and it would be too much clock to compute addresses for local variables every time, so the compiler generates a ,,function-call-heavy'' code for function calls which creates and syncs a fake stack to avoid local variable access overhead. most of the higher level language elements (such as bitshifts with variable or so) are implemented in runtime, to keep the development time low (as i had a planned time peroid which i was able to spend on this project, which i of course exceeded at the end). the compiler is of course self hosting, as it compiles itself and the OS as well, its basically the soul of the project. meanwhile it generates suprisingly optimal code, from an engineering standpoint its not a great work, it lacks some features (like switches and structs) and its very slow and unscientifical (it uses 70 or 80 pass to morph the code to turn into subleq binary into the end in a giant monolithic code snippet).
Mon May 21, 2018 10:37 pm |
Tue May 22, 2018 12:34 pm |
Geri
Tue May 22, 2018 8:48 pm |
Tue May 22, 2018 8:52 pm |
Tue May 22, 2018 8:53 pm |
Geri
Tue May 22, 2018 8:57 pm |
MichaelM
_________________ Michael A.
Tue Nov 06, 2018 8:33 pm |
Geri
Sun Nov 11, 2018 10:54 am |
MichaelM
Thanks
Sun Nov 11, 2018 12:52 pm |
