Last visit was: Tue Nov 17, 2026 8:34 pm
It is currently Tue Nov 17, 2026 8:34 pm
Joined: Sat Feb 02, 2013 9:40 am Posts: 2550 Location: Canada
Declare() is a monster function comprised of several hundred LOC used in declaration parsing. It does a wide variety of miscellaneous things required for parsing the declaration. So, I’m trying to break it up into several smaller functions to make it more manageable. Been rearranging (refactoring?) the code somewhat today. Organizing parts of the parsing, optimization, and code generation to be underneath other classes. I’m not sure this is a wise choice. For instance rather than have a file called ParseEverything, parsing is broken up and falls under expression processing (ENODE.cpp), statement (Statement.cpp) processing and declaration parsing. This is based on the primary object that the parsing method is working with. It’s a matter of what’s the most convenient to work with. It was convenient for instance to have all the optimization code in one file.
| Tue Aug 28, 2018 3:40 am |
Global variables are slowly being moved so they are class members. Currently the compiler optimizes and generates code for functions one at a time as it’s parsing declarations. An eventual goal is to make it possible to do whole program optimizations. There are a lot of global variables that could really just be members of the ‘Function’ class or other classes. Right now, the compiler uses a ton of memory (approx. 20MB) just to compile in it’s function by function basis. But with a machine with gigabytes of ram perhaps some more state could be retained in the compiler for whole program optimizations.
| Wed Aug 29, 2018 5:08 am |
Played around with some of the CC64 language constructs. CC64 allows use of the ‘then’ keyword in an if statement. It now accepts a syntax where the brackets around the if expression are not required if a ‘then’ is used. A do-once loop construct was invented by allowing the ‘while’ at the end of a do loop to be omitted. In that case the body of the loop will be executed only a single time, unless… there’s a continue statement within the body of the do statement. Continue will cause a loop back to the top. Inserting a break statement causes the do to be broken as per usual operation. All statements are effectively ‘do’ (done) statements except the ‘do’ is missing. So the following code prints “hello” only one time. Code: do { printf(“Hello”); } // no while
OR
do printf(“Hello”);
Using a ‘do’ increases the loop depth tracked by the compiler. It may be used to help prioritize register allocations, giving a boost in priority to operations performed within the ‘do’. Note that following a do-once loop with the while loop is confusing. The ‘while’ keyword will associate with an immediately previous ‘do’ statement because it looks like a ‘do-while’ statement to the compiler. So, to follow a do-once with a while loop an extra statement separator (’;’) is required. I've been having fun debugging the register allocator. Something isn't working quite right yet. I suspect it has to do with the interference graph. There isn't enough interferences so the allocator uses too few registers.
| Sat Sep 01, 2018 3:49 am |
Slowly ironing out the bugs in the color graphing register allocator. A problem that held me up for quite a while was iterating backwards through the basic blocks, a loop termination condition wasn’t correct so only a single instruction was examined out of the block. It was a single character typo difficult to spot by inspection. It was also difficult to find by stepping through code. I finally got the register allocator to assign different colors to different live ranges. Another problem was clearing the set of used colors was being done inside a loop and it should have been outside. Yet another problem was reconsidering already colored ranges in subsequent passes of the colorizer. Too much state was effectively reset. I didn’t implement the renumber stage of allocator. Instead of going by a set of values, the virtual registers numbers are used directly. This takes significantly more memory in the interference graph which then has a lot of unused space. However, the amount of memory in use (20MB) is still small compared to the amount of memory in the workstation. I’ve found in recent times that I have a tendency to use memory hungry algorithms that are simplified versions of final ones.
It’s almost working. I still have to polish off the spill and fill code. I’ve noticed the allocator does a ton of stores and loads in larger routines. I’m not sure it’s worth the extra memory overhead. There likely is something wrong with the code yet. Compiling the code also seems sluggish compared to the simpler allocator. Still it only takes less than a second to compile a file. I have an ulterior motive for getting color graphing working. If it works well enough maybe a machine with only 16 regs could be in the works.
| Sun Sep 02, 2018 2:49 am |
| Sun Sep 02, 2018 5:33 am |
| Sun Sep 02, 2018 7:34 am |
| Sun Sep 02, 2018 7:36 am |
Labels on the mind tonight. Creating the control flow graph has to find labels. In my simple implementation it calls a routine called ‘FindLabel’ which searches the entire peep list of instructions for the label. Well that’s inefficient and slow. So, I switched it to looking up the label in a table of labels which uses the label number as it’s index. This is just directly reading a single word without having to search. The cost is the label table has to be built, but it turns out there’s a place to do this when the optimizer is checking for unreferenced labels. Upgraded the O(n^2) algorithm for removal of unreferenced labels to O(n). When I initially wrote it I didn’t worry too much about it as functions are generally small <100 LOC. I’ve made several improvements to the compiler but I’ve yet to notice much difference in speed. It’s likely limited by loading of the file to be compiled.
| Mon Sep 03, 2018 3:19 am |
| Fri Sep 07, 2018 3:19 am |
| Sat Sep 08, 2018 2:17 am |
| Sun Sep 09, 2018 9:12 pm |
| Sun Feb 16, 2020 3:31 am |
Ported the compiler over for RTF64. It is being fixed up based on a test suite found here: https://github.com/c-testsuite/c-testsuiteIt passes about 75% of the tests. Most of the test that fail are due to things not being supported or not available yet. For instance the stdint.h file is needed by some of the tests and CC64 does not yet have a version of this file. Another thing not supported by the compiler is the _Generic() operation that is newer in C. The compiler does not handle function pointers very well. It is easy to come up with cases that cause it to spew out error messages. Since function pointers are rarely used I do not know if I will fix this or not. I believe the compiler does handle the original C style function pointers. Just eyeballing the compiler generated code because the RTF64 processor isn't working in an FPGA yet.
| Wed Nov 11, 2020 3:30 am |
Spent too much of the day trying to fix the following. For f1 the compiler is associating (c and b) as the parameters not a, b. This causes an undefined symbol error on 'a' which leads to a bunch of other errors. I am not sure I want to try and fix many of the things that are legal to do in C that nobody ever does. Code: 1 int 2 f2(int c, int b) 3 { 4 return c - b; 5 } 6
*** local symbol table ***
7 int (* 8 f1(int a, int b))(int c, int b) 9 { 10 if (a != b) *** error 20: E Expression expected *** error 6: E Bad punctuation *** error 6: E Bad punctuation *** error 20: E Expression expected *** error 6: E Bad punctuation *** error 20: E Expression expected *** error 4: E Undefined symbol 11 return f2; *** error 6: E Bad punctuation 12 return 0; 13 } 14
15 int 16 main() 17 { 18 int (* (*p)(int a, int b))(int c, int d) = f1; *** error 0: E Syntax error 19 20 21 return (*(*p)(0, 2))(2, 2); 22 } 23
| Sat Jul 17, 2021 4:04 am |
This is the current work in progress, getting the compiler to correctly compile test case #T00124 . It is a little further along than a couple of days ago. What is missing is the generation of the function f1. The compiler says “aha” a function pointer so it does not expect a function body to follow, and skips spitting it out. It is interesting because of the way the pointer is declared. Since f1 is just a pointer to a func. an anonymous function is needed to set f1 to point to. In main() the f1 pointer is used to initialized another pointer. The code generated looks like it could be right even though a dereference error is reported. Code: 1 int 2 f2(int c, int b) 3 { 4 return c - b; 5 } 6
7 int (* 8 f1(int a, int b))(int c, int b) 9 { 10 if (a != b) 11 return f2; 12 return 0; 13 } 14 15 int 16 main() 17 { 18 int (* (*p)(int a, int b))(int c, int d) = f1; 19 20 21 return (*(*p)(0, 2))(2, 2); *** error 18: E Dereference 22 } 23
13 _p =fffffff8 - Auto Pointer to Long 13 _d =fffffff8 - Auto Pointer to Function returning Pointer to Long
29 _main =000018 - Global Function returning Long Parameters: Type array: Stack Space: Argbot: 0 Tmpbot: -8 Stkspc: 8 28 __new =000000 - 28 __delete =000000 - 13 _p =fffffff8 - Auto Pointer to Function returning Pointer to Long 28 __autonew =000000 - 7 _b =000010 - Global Long 7 _c =000008 - Global Long 13 _f1 =000000 - Global Pointer to Function returning Long 29 _f2 =000000 - Global Function returning Long Parameters: Type array: 007 007 Stack Space: Argbot: 0 Tmpbot: 0 Stkspc: 0 *** structures and unions ***
Generated code: Code: code align 16 ;==================================================== ; Basic Block 0 ;==================================================== public code _f2: link #32 ldo $t1,16[$fp] ldo $t2,24[$fp] sub $a0,$t1,$t2 T00124_8: unlink add $sp,$sp,#16 ret endpublic
bss align 8 public bss _f1: fill.b 8,0x00
endpublic align 2 public bss _c: fill.b 8,0x00
endpublic align 2 public bss _b: fill.b 8,0x00
endpublic code align 16 code align 16 ;==================================================== ; Basic Block 0 ;==================================================== public code _main: sub $sp,$sp,#40 lea $gp,__data_start sto $s0,0[$sp] ; int (* (*p)(int a, int b))(int c, int d) = f1; ldo $s0,_f1[$gp] ; return (*(*p)(0, 2))(2, 2); ldo $t0,[$s0] push $x0 ldi $t1,#2 push $t1 jal $ra,[$t0] mov $t0,$a0 ldi $t1,#2 push $t1 ldi $t1,#2 push $t1 jal $ra,[$t0] mov $t0,$a0 mov $a0,$t0 T00124_13: T00124_16: ldo $s0,0[$sp] add $sp,$sp,#40 ret endpublic
rodata align 16 ; global _main ; global _b ; global _c ; global _f1 ; global _f2
| Sun Jul 18, 2021 6:16 am |
