Last visit was: Tue Oct 06, 2026 10:22 am
It is currently Tue Oct 06, 2026 10:22 am
 [ 15 posts ]
- Mouse
- Keyboard
- Virtual keyboard
- Touchscreen
- Multitouch
- 4 force-feedback joysticks
- 16 RGB cameras
- CPU hotplug
- Disk drive hotplug
- UTF8, unicode, ASCII
- Fast boot and shutdown
download: http://users.atw.hu/gerigeri/DawnOS/download.html
Fri May 11, 2018 5:48 pm
Welcome Geri!
Sat May 12, 2018 7:20 am
Sat May 12, 2018 1:09 pm
Hi Geri,
Sat May 19, 2018 4:04 am WWW
Mon May 21, 2018 6:00 pm
Mon May 21, 2018 6:06 pm
Mon May 21, 2018 10:37 pm
Tue May 22, 2018 12:34 pm
Tue May 22, 2018 8:48 pm
Tue May 22, 2018 8:52 pm
Tue May 22, 2018 8:53 pm
Tue May 22, 2018 8:57 pm
Tue Nov 06, 2018 8:33 pm
Sun Nov 11, 2018 10:54 am
Thanks
Sun Nov 11, 2018 12:52 pm
 [ 15 posts ]
Users browsing this forum: chrome-9x-bots and 1 guest
