Last visit was: Tue Oct 28, 2025 2:09 am
It is currently Tue Oct 28, 2025 2:09 am
quadrant
Hi! I'm looking for some insight into how systems that use an address bus that is larger than 8 bits in size achieve byte addressing. For example, consider the case of a 32 bit system that implements the x86 architecture (and uses 32 bit internal registers). From what I've gathered by searching the web, even though you specify memory addresses in bytes when using x86 assembly, the system does not fetch single bytes from memory. Instead it fetches 32bit words from memory (four bytes at a time). Consider the code below. It loops through the byte string "helloWorld" and prints each character in a newline. Register ebx is set to point to the location of the string in memory. Suppose that the string resides at memory location 100 bytes. Register ecx is loaded with the current character (that ebx is pointing to) so that we can compare it against zero as a way to check when we have reached the end of the string. Specifically, the lower byte of register ecx (named cl) is loaded with the character. Is the following diagram how the string's bytes are loaded from memory? If so, how does cl (the lowest byte of register ecx) get the appropriate character when the character's index modulo 4 does not equal zero? I.e. how do the ?? below end up with the correct character? Is some byte shifting performed behind the scenes by the system? Code: desired | byte address | actual address | value loaded | value loaded character | requested | sent to memory: | into ecx | into cl | | floor( a / 4 ) | register | (lowest byte) -----------|---------------|------------------|----------------|--------------- h | 100 | 25 | (l, l, e, h) | h e | 101 | 25 | (l, l, e, h) | ?? l | 102 | 25 | (l, l, e, h) | ?? l | 103 | 25 | (l, l, e, h) | ?? o | 104 | 26 | (r, o, W, o) | o W | 105 | 26 | (r, o, W, o) | ?? o | 106 | 26 | (r, o, W, o) | ?? r | 107 | 26 | (r, o, W, o) | ?? l | 108 | 27 | (., 0, d, l) | l d | 109 | 27 | (., 0, d, l) | ?? 0x0 | 110 | 27 | (., 0, d, l) | ??
Full assembly code for reference: Code: global _start
SYS_EXIT equ 60 EXIT_CODE equ 0 SYS_WRITE equ 1 STD_OUT equ 1
section .data
newline db 0xA msg db "helloWorld", 0x0
section .text
; Based on https://stackoverflow.com/a/7614431 _start:
mov ebx, msg ; pointer to string
mLoop:
mov cl, [ ebx ] ; Read the next byte from memory
cmp cl, 0 ; Compare the byte to null (the terminator) je exit ; If the byte is null, jump out of the loop
; Output the character mov eax, SYS_WRITE mov edi, STD_OUT mov esi, ebx ; pointer to character... mov edx, 1 syscall
; Ouput new line mov eax, SYS_WRITE mov edi, STD_OUT mov esi, newline mov edx, 1 syscall
; Move to the next byte in the string add ebx, 1 jmp mLoop
exit:
mov eax, SYS_EXIT mov edi, EXIT_CODE syscall
*Disclaimer, the code might not work as is. It was originally written for and tested in 64bit. I swapped the registers to 32bit for brevity (example rcx to ecx).
| Tue Mar 26, 2019 12:20 am |
barrym95838
Quote: Hi! I'm looking for some insight into how systems that use an address bus that is larger than 8 bits in size achieve byte addressing. No, I am relatively certain that the number of bits in the address bus dictate the number of addressable memory cells, not the widths of those cells. The most popular cell width is still 8-bits, at least in the 65xx, 68xx, x86, 80xx, and Z80 crowds ... Quote: From what I've gathered by searching the web, even though you specify memory addresses in bytes when using x86 assembly, the system does not fetch single bytes from memory. Instead it fetches 32bit words from memory (four bytes at a time). I am not an x86 programmer, but that statement does not agree with my understanding of how the x86 works. AIUI, the destination register 'cl' in the mov instruction is only 8-bits wide, so the x86 should effectively only be reading one byte from RAM and depositing it in cl, at least from a programmer's point of view. If you had specified 'cx' or 'ecx' or 'rcx' as a destination register, the x86 would recognize the width of the register and read the appropriate number of bytes from RAM starting at the byte address specified in the effective address. The byte at [ea] would deposit into cl, [ea+1] to ch, [ea+2] and [ea+3] to bits 16:31 of ecx, etc. From a hardware standpoint, there are issues of "aligned addresses" which can allow some versions of x86 to greatly improve performance by copying more than one byte simultaneously, but I'll leave that discussion to those more experienced in the subject. Mike B.
| Tue Mar 26, 2019 5:37 am |
It's a good question quadrant (I'm sure you meant to speak of a wide data bus rather than mention the width of the address bus)
[My answer is coming out a little different from yours Mike, which is not to say I think you're wrong!]
I think I'm right in saying that there are several ways for an architecture to offer byte access. In your example, you are loading a wide register at a byte address which isn't aligned with the size of the register. That's called an unaligned access. - some architectures will forbid an unaligned access, so you get an exception - some will barrel-roll the databus: the word containing the byte in question is rotated by 8, 16 or 24 bit shifts: for address 0x0101 'ELLH' or rather 'H', 'L', 'L', 'E' with 'E' in the least significant byte - some will access the word containing the byte of interest and also the next word, and shift the pair to give you the byte you want and the three bytes after it: for address 0x0101, 'ELLO' or rather O, L, L, E, again with 'E' in the least significant byte
Getting an unaligned word is going to cost two accesses. In a machine with a cache, the penalty might be less if the two words are in the same cache line.
Writes are even worse, because the machine needs to read the affected word, modify it, and then write it back. Unless the memory system provides byte enables for writes, which it might do.
But note: you could have chosen to load only a byte-wide register at an unaligned address, instead of loading a word-wide register. The same analysis applies, but there's no longer a need to read two words.
| Tue Mar 26, 2019 6:06 am |
GaBuZoMeu
You can find a detailed description how the 32bit 68020 will handle this in the User Manual (ch.5.2).
| Tue Mar 26, 2019 1:32 pm |
Joined: Sat Feb 02, 2013 9:40 am Posts: 2405 Location: Canada
The processor / I/O may also reflect narrow data multiple times on a wider data bus. Rather than just shifting an eight-bit value, the same eight-bit value will be output on all byte lanes. Which lane gets written is usually controlled by a select signal (sel_o for WISHBONE bus). Getting or setting I/O values has a similar issue when the bus widths mismatch. Suppose there’s an eight-bit keyboard controller connected to a 64-bit bus. To write to the I/O the cpu reflects the same data byte across all eight-byte lanes when outputting data. Even though it may be trying to write byte #3, byte #0 has the same contents so the keyboard databus needs to be connected to only bit 0 to 7. The keyboard must check the low order address bits or the byte lane select signals to determine which register to write. On readback from the keyboard, it must copy the data bits to all byte lanes of the cpu. Following is code for feeding a 64-bit databus from 8,32, and 64 bit peripherals. Code: always @(posedge cpu_clk) casez({rnd_ack,cs_led,kbd_ack,aud_ack}) 4'b1???: br2_dati <= {2{rnd_dato}}; // 32 bits reflected twice 4'b01??: br2_dati <= {2{led_dato}}; 4'b001?: br2_dati <= {8{kbd_dato}}; // 8 bits reflect 8 times 4'b0001: br2_dati <= aud_cdato; // 64 bit peripheral default: br2_dati <= br2_dati; endcase
| Tue Mar 26, 2019 7:27 pm |
quadrant
barrym95838 wrote: No, I am relatively certain that the number of bits in the address bus dictate the number of addressable memory cells, not the widths of those cells. The most popular cell width is still 8-bits, at least in the 65xx, 68xx, x86, 80xx, and Z80 crowds ... Ohhh. I was under the impression that memory was 32/64bits wide. I didn't realize it was actually 8bit. @BigEd Thanks for the insight! Do you know which of the three is the most popular approach? It seems forbidding unaligned access (and throwing an error) would be the simplest... GaBuZoMeu wrote: You can find a detailed description how the 32bit 68020 will handle this in the User Manual (ch.5.2). Thank you, will give it a read.
| Tue Mar 26, 2019 8:08 pm |
quadrant
robfinch wrote: Rather than just shifting an eight-bit value, the same eight-bit value will be output on all byte lanes. Which lane gets written is usually controlled by a select signal (sel_o for WISHBONE bus). Oh, that's neat!
| Tue Mar 26, 2019 8:12 pm |
I think forbidding unaligned accesses is the kind of thing a fresh-start RISC machine will do. Whereas a machine with layers of legacy, like x86, has to allow them. Here's a doc on what they are and how they can arise and how to avoid them in C: https://www.kernel.org/doc/Documentatio ... access.txtSome nice details in this slide set: https://www.cl.cam.ac.uk/teaching/2004/ ... ynotes.pdf(Edit: start at page 65 for unaligned accesses, but for a big lecture course on comparing architectures, read it all!)
| Tue Mar 26, 2019 8:53 pm |
GaBuZoMeu
IIRC the 68000 does not allow odd values for the system stackpointer.
| Wed Mar 27, 2019 12:16 am |
Users browsing this forum: Amazonbot and 0 guests |
