Last visit was: Wed Jul 09, 2025 6:55 am
It is currently Wed Jul 09, 2025 6:55 am
 ben's20 bit cpu.
cpu with excess 3 math.
Mon Nov 18, 2019 6:59 am
   20 bits / 10 bit bytes
   X  0 Immedate      1 Indexed
      op        aa      xx      ccc
Mon Nov 18, 2019 8:07 am
Mon Nov 18, 2019 6:51 pm
and seems to work.
                *  reserved
Tue Nov 19, 2019 3:02 am
Tue Nov 19, 2019 6:55 pm
Thu Nov 28, 2019 2:56 am
Fri Dec 13, 2019 6:59 am
Fri Dec 20, 2019 11:59 pm
Sat Dec 21, 2019 10:36 am
Sat Dec 21, 2019 8:36 pm
** IT LIVES **
a assembler and text editor.
Mon May 18, 2020 2:01 am
oldben wrote:
** IT LIVES **
Nice work!
Mon May 18, 2020 9:27 pm
Fri Jun 05, 2020 6:52 pm
Wed Jun 10, 2020 10:06 pm
Fri Jun 12, 2020 8:15 am
