Last visit was: Tue Sep 16, 2025 12:13 am
It is currently Tue Sep 16, 2025 12:13 am
 a simple cpu 20 bits wide
I am now working on the ALU schematic and thinking of the PCB for it.
Some changes have been made for ALU with the CTL schematic.
Trial PCB layout will 9.5 inches x 7.5 inches.
The FPGA version for ALTERA DE1 (cyclone II) now stable and the programming
file for the cpu is avaible.
Sat Feb 29, 2020 6:31 pm
Fighting the system here, with Ki-Cad. Ball park is looking at 9 x 9 inch cards.
The main two schematics are drafted, the alu (36 TTL) and the control section (25 ttl). The front panel card is the other main section, with memory and I/O and the mother board,straight forward
logic. Memory is 16KB per card, with 32KB for user program/data and 12KB ram/prom for the OS.
Serial IO and a SD card emulating 2 8 inch floppies. 4.9 Mhz clock and a 6809 style memory cycle.
Mon Mar 02, 2020 11:10 pm
Hi Ben, I'm trying to understand your design.
I am missing a high-level block diagram and description. Since there are two LS170 I suppose there are 8 registers.
And also, a clear description of the instruction word.
At the beginning of the thread you did some ASCII diagrams but for me that is not sufficient to understand all.
It is difficult to reverse-engineer the design from your schematic. Especially the control section that mostly has gates and labels.
For ascii drawings I suggest http://asciiflow.com/.
Another great online tool for diagrams is draw.io I used that for my relay computer: https://cdn.hackaday.io/images/4603351507992625211.png
Why do you use counters as instruction register ?
Is there a reason for using obsolete components, I suppose you still have a lot of them laying around ? The LS170 could be replaced by HC670 (tristate) that is still available.
Your design goals are similar to my Kobold K2 (8 registers, 16 bit data, 18/20 bit address). Kobold is a lot simpler though, because it
has no microcode. See https://hackaday.io/project/167605-kobold-k2-risc-ttl-computer.
fix link
Tue Mar 03, 2020 8:17 am
The design of this computer was set to be the early 1970's, around the time of
the PDP-8/e, with small PROMS just coming out. The basic design was 18 bits with
9 bit bytes. 4 registers PC,AC,IX,SP and simple indexing. Later revision moved the design
to A,B,X,S and PC, thus two 74LS170's.
I needed a loadable register, with clear.
74170 is a 1970's part. The microcode is simple rom look up tables,
load from fetch, and bump state counter. The goal was good general puropse computer
with index and stack.
has no microcode. See https://hackaday.io/project/167605-kobo ... l-computer.
The Alu data path is simple, 18 bits data in bus, 18 bits data out. Ram and alu in the middle.
Memory cards latch data out for address and data. The complex part is 9/18 bit data,
a bit messy with byte i/o chips. The front panel makes use of data out, on a instruction fetch
on some instructions to display information. Still a work in progress until draft out some PCB's.
Thank you for the url's.
fix quoting tags
Tue Mar 03, 2020 8:57 pm
Thank you for your explanation. I now understand that you want to build a computer that could have been build in the 1970's.
Good luck with design and construction, I will follow it !
Tue Mar 03, 2020 9:11 pm
I have expanded the 18 bit computer, to 20 bits on the DE1.
This required new connectors 23x2 for the TTL version.The control section is now down to 23 chips. The alu section has expanded to 46 chips.
Bytes are 10 bits. Words 20 bits. Load,store,and,or,eqv,add,sub,adc,sbc binary logic.
Adx,Axc are excess three decmal addition, normal and add with carry.
This gives a me a Octal Computer (~7 digits) that has the feel of computing from
the Cretaceous era, or before C ~ 1971..1973 with core memory and early MSI TTL.
This version is LS TTL version, from about 1976-1977 with MOS ram interfacing, but
same instruction set as the core memory version. A SDC card provides 2 drives of 255 K,
10 bit bytes. Serial is 2400 baud. No IRQ is used by the I/O devices. Most of the development
now will be software (rom) libraries for decmial and long arithmitic (40 bits).
Sat Mar 07, 2020 6:36 am
I'd be interested to hear more about the SD card interface- is there any software layer or a microcontroller?
Sat Mar 07, 2020 2:17 pm
A simple 8 bit shift reg in hardware and BIOS routines for reading/writing 512 x 10 bit sectors.
This site was very usefull for SD details: http://elm-chan.org/cc_e.html
Later I will use Sparkfun SD breakout PCB for a 74X breadboarded prototype off the DE1 expanson
connectors. FPGA routing race conditions tends to delay DE1 development for days when
the hardware config fails to work for that unlucky day.
Sat Mar 07, 2020 10:42 pm
Now working on version #2
Sun Mar 15, 2020 12:23 am
I had to shufflle opcode encoding around to get LEA (load effective Address)to work
with Y registor. S and Z(ero) page are now word addressing only. Encodng is a bit messy
as it adds a few more gates to encode register operands.
Tue Mar 17, 2020 4:42 am
The hardware and software have reached a stable state, and considered version #1.
Development is halted as I am moving to bigger things like 32 bits.
Sun Mar 22, 2020 7:52 pm
Users browsing this forum: AhrefsBot, MojeekBot and 0 guests
