Nov 1977 Byte Mag, has " Build a computer from scratch". It is a 8 bitter, 4 instructions In,Add,Store(negitive),Jump if Postitive. Ben.
linkified
Fri Nov 13, 2020 10:29 am |
B.Bibby
https://archive.org/details/byte-magazine-1977-11/page/n78/mode/1upIt is a very minimal instruction set, but neatly tackles the bootstrap problem with its WIO instruction. Code: ”WIO 00xxxxxx Wait for input to location N. Display current contents of location N while waiting.” Although entering a program by this method would be a little tedious, it seems good enough for entering a small secondary bootstrap. It is very similar to the method used in the CARDIAC paper computer. https://www.cs.drexel.edu/~bls96/museum/cardiac.html
Fri Nov 13, 2020 11:02 am |
I've a feeling the 1802 similarly supports a front panel bootstrap
Fri Nov 13, 2020 12:04 pm |
monsonite
Nice to see a bit of home-built TTL computing history.
However it had a chip-count of 35 ICs, of which 8 were the RAM.
The instruction set was very minimal - leaving a lot of scope for future improvements.
I would have thought that using a pair of 74181s as the ALU would have encouraged a more diverse instruction set.
In the author's defense - it was his first electronic project, and he learnt a lot about TTL design from the exercise - and he got an article published in BYTE !
Fri Nov 13, 2020 12:32 pm |
B.Bibby
Thu Apr 01, 2021 10:04 am |
Turing Machine's while not practical, could also be considered one, depending on you view the state table and tape memory. They also look nice in mechanical form. Wooden https://hackaday.com/2018/03/08/mechani ... g-machine/https://www.youtube.com/watch?v=vo8izCKHiF0Taditional https://www.youtube.com/watch?v=E3keLeMwfHY
Sat Apr 03, 2021 4:58 am |
Dr Jefyll
B.Bibby wrote: Dr Jefyll’s MISC gets another mention on Hackaday. Thanks for that, B.Bibby. Sorry I've been slow to notice your post. I need to visit Anycpu.org more often! Also belonging on the MISC list are three offerings from Myron Plichota: -- Jeff
Sun Oct 31, 2021 2:32 am |
Here is my idea for a Minimal Instruction Set CPU, compared to my current CISC design. Added indirection (I) do I don't have self modifiying code. Code: A bit better move machine? see: The Ultimate RISC https://homepage.cs.uiowa.edu/~jones/arch/risc/ RISC
256K words of memory 62 PIN BUSS? 20 bit ALU 74LSXXX devices 1 us static memory cycle ~ summer 1976 4 uS for memory operation 3 uS for jump condition +1 us for indirection
run is true FF:NN:NNNN:NNNN:NNNN:NNNN word #1 from FF 00 read word N 01 special decode read word N 10 read word N indirect 11 read byte N indirect , Sign is odd/even data normal decode
FF:NN:NNNN:NNNN:NNNN:NNNN word #2 to 00 write word N 01 write word N and halt 10 write word N indirect 11 write byte N indirect , Sign is odd/even data display i/o bus special decode
FF:NN:NNNN:NNNN:NNNN:NNNN word #2 to 00 write word N decrimented 01 write word N incrimented 10 jmp if zero N (constant data) write swr 11 jmp if zero N indirect write swr display i/o bus PANEL run is false
00 idle read swr display mar 01 address read swr display mar 10 examine read pc++ display data in 11 deposit write pc++, swr display data in
MEMORY MAPPED DEVICES
3FFFx swr read only 3FFEX alu func write 0011 add 0111 sub nnnn alu logic function 74181 active high data 0Inn read logic condition 1ss0 read acc left shift 1ss1 read acc right shift 111- read acc
3FFYX Y=7..0 I/O devices 30000 to 3FEFF ROM of some kind
MOVE-IT CARD DATA PATH ~ 30 MSI LS CHIPS STATE LOGIC ~ 4 CHIPS DECODE ~ 7? CHIPS TOTAL 41 CHIPS
ALU CARD DATA PATH 74LS181 ~ 25 MSI CHIPS DECODE ~ 10 CHIPS? TOTAL 35 CHIPS ----------------------------------------------------------------- CURRENT 20 BIT MACHINE CISC 16 REGISTERS ADDRESSING MODES +-R,R+-@ DIRECT,INDEXED
20 BITS DEC 20 2021 0987 6543 2109 8765 4321 +------------------------+ |COOO:AAAA:000B:XXXX:----| R INDEXED/DIRECT +------------------------+ |####:####:####:####:####| OFFSET +------------------------+ +------------------------+ |COOO:AAAA:0010:XXXX:----| REG% / LEA +------------------------+ +------------------------+ |-RSS:AAAA:0011:--##:####| SHIFT #-N +------------------------+ +------------------------+ |COOO:AAAA:10YB:XXXX:####| R+ +------------------------+ +------------------------+ |IOOO:AAAA:01Y1:XXXX:####| BCC,JMP R+ / JSR R+ +------------------------+ +------------------------+ |IOOO:AAAA:0100:----:####| SCC # +------------------------+ +------------------------+ |I111:AAAA:01Y0:XXXX:####| RETI +------------------------+ +------------------------+ |COOO:AAAA:11+#:####:####| OP. R # SHORT IMMEDATE +------------------------+ +------------------------+ |-111:AAAA:1100:00CC:0000| CTL A +------------------------+
0 ADD A I 1 SUB B J 2 CAD C K 3 OR D S 4 XOR E W 5 AND F X 6 LD G Y 7 ST H Z
100 PIN BUS (S-100 STYLE) CORE MEMORY CYCLE ALU 2901'S CONTROL SECTION ~ 15 MSI CHIPS FOR RANDOM LOGIC 2 256 X 8 PROMS OR 22V10'S 4 FPGA'S (82S100'S) OR 22V10'S TOTAL 22 CHIPS
Tue Dec 21, 2021 4:28 am |
