Last visit was: Mon Nov 03, 2025 7:52 pm
It is currently Mon Nov 03, 2025 7:52 pm
 [ 38 posts ]  Go to page Previous  1, 2, 3
Online
Nov 1977 Byte Mag, has "Build a computer from scratch".
It is a 8 bitter, 4 instructions In,Add,Store(negitive),Jump if Postitive.
linkified
Fri Nov 13, 2020 10:29 am
https://archive.org/details/byte-magazine-1977-11/page/n78/mode/1up
It is a very minimal instruction set, but neatly tackles the bootstrap problem with its WIO instruction.
”WIO    00xxxxxx    Wait for input to location N.  Display current contents of location N while waiting.”
Although entering a program by this method would be a little tedious, it seems good enough for entering a small secondary bootstrap.
It is very similar to the method used in the CARDIAC paper computer.
https://www.cs.drexel.edu/~bls96/museum/cardiac.html
Fri Nov 13, 2020 11:02 am
I've a feeling the 1802 similarly supports a front panel bootstrap
Fri Nov 13, 2020 12:04 pm
Nice to see a bit of home-built TTL computing history.
However it had a chip-count of 35 ICs, of which 8 were the RAM.
The instruction set was very minimal - leaving a lot of scope for future improvements.
I would have thought that using a pair of 74181s as the ALU would have encouraged a more diverse instruction set.
In the author's defense - it was his first electronic project, and he learnt a lot about TTL design from the exercise - and he got an article published in BYTE !
Fri Nov 13, 2020 12:32 pm
Dr Jefyll’s MISC gets another mention on Hackaday.
https://hackaday.com/2021/03/31/one-bit-cpu-runs-at-a-blistering-60hz/
Thu Apr 01, 2021 10:04 am
Online
Turing Machine's while not practical, could also be considered one, depending on you view the state table
and tape memory. They also look nice in mechanical form.
Wooden
https://hackaday.com/2018/03/08/mechani ... g-machine/
https://www.youtube.com/watch?v=vo8izCKHiF0
Taditional
https://www.youtube.com/watch?v=E3keLeMwfHY
Sat Apr 03, 2021 4:58 am
Thanks for that, B.Bibby. Sorry I've been slow to notice your post. I need to visit Anycpu.org more often!
Also belonging on the MISC list are three offerings from Myron Plichota:
-- Jeff
Sun Oct 31, 2021 2:32 am WWW
Online
Here is my idea for a Minimal Instruction Set CPU, compared to my current CISC design.
Added indirection (I) do I don't have self modifiying code.
A bit better move machine?
see: The Ultimate RISC
https://homepage.cs.uiowa.edu/~jones/arch/risc/
RISC
256K words of memory
62 PIN BUSS?
20 bit ALU 74LSXXX devices
1 us static memory cycle ~ summer 1976
4 uS for memory operation
3 uS for jump condition
+1 us for indirection
run is true
FF:NN:NNNN:NNNN:NNNN:NNNN   word #1 from
FF
00 read word N
01 special decode read word N
10 read word N indirect
11 read byte N indirect ,  Sign is odd/even data
normal decode
FF:NN:NNNN:NNNN:NNNN:NNNN   word #2 to
00 write word N
01 write word N and halt
10 write word N indirect
11 write byte N indirect ,  Sign is odd/even data
display i/o bus
special decode
00 write word N decrimented
01 write word N incrimented
10 jmp if zero N (constant data) write swr
11 jmp if zero N indirect        write swr
display i/o bus
PANEL run is false
00  idle      read swr   display mar
01  address   read swr   display mar
10  examine   read pc++          display data in
11  deposit   write pc++, swr    display data in
MEMORY MAPPED DEVICES
3FFFx   swr  read only
3FFEX   alu  func   write
             0011   add
             0111   sub
             nnnn   alu logic function 74181
                    active high data
             0Inn   read logic condition
             1ss0   read acc left shift
             1ss1   read acc right shift
             111-   read acc
3FFYX        Y=7..0 I/O devices
30000 to 3FEFF  ROM of some kind
MOVE-IT CARD
DATA PATH ~ 30 MSI LS CHIPS
STATE LOGIC ~ 4 CHIPS
DECODE ~ 7? CHIPS
TOTAL 41 CHIPS
ALU CARD
DATA PATH 74LS181 ~ 25 MSI CHIPS
DECODE ~ 10 CHIPS?
TOTAL 35 CHIPS
CURRENT 20 BIT MACHINE
CISC
16 REGISTERS
ADDRESSING MODES
+-R,R+-@
DIRECT,INDEXED
  20 BITS  DEC 20 2021
 0987 6543 2109 8765 4321
|COOO:AAAA:000B:XXXX:----| R INDEXED/DIRECT
|####:####:####:####:####| OFFSET
|COOO:AAAA:0010:XXXX:----| REG% / LEA
|-RSS:AAAA:0011:--##:####| SHIFT #-N
|COOO:AAAA:10YB:XXXX:####| R+
|IOOO:AAAA:01Y1:XXXX:####| BCC,JMP R+ / JSR R+
|IOOO:AAAA:0100:----:####| SCC #
|I111:AAAA:01Y0:XXXX:####| RETI
|COOO:AAAA:11+#:####:####| OP. R #  SHORT IMMEDATE
|-111:AAAA:1100:00CC:0000| CTL A
0 ADD   A   I
1 SUB   B   J
2 CAD   C   K
3 OR    D   S
4 XOR   E   W
5 AND   F   X
6 LD    G   Y
7 ST    H   Z
100 PIN BUS (S-100 STYLE)
CORE MEMORY CYCLE
ALU 2901'S
CONTROL SECTION
~ 15 MSI CHIPS FOR RANDOM LOGIC
  2 256 X 8 PROMS OR 22V10'S
  4 FPGA'S (82S100'S) OR 22V10'S
TOTAL 22 CHIPS
Tue Dec 21, 2021 4:28 am
