Amazing! Done amazingly fast too.
Thu Oct 01, 2020 3:03 am |
No slow, I had the one bug that takes up the other 90% of the debugging time. Now that I have most of my ideas developed and bug free, I am redesigning my 9 bit cpu from a few years ago. Code: OPCODE LAYOUT 987 654 321 +---+---+---+ |OOO|JAA:WXX| +---+---+---+
REG IX AC!=S AC=S 0 A # ST(ORE) - - 1 B Z LD Z Z 2 X X ADD S !C 3 S S SUB Z+S Z+!C 4 AND !(ODD) TRUE 5 OR !(Z) - 6 XOR !(S) !(!C) 7 ADX !(S+Z) !(Z+!C)
ADC/SBC or LOGIC REG S used a special decode. AC is reg A OP MATRIX 3 1 2 0 ST # # ST X X 0 BYTE CTL BYTE BYTE 1 WORD RET WORD WORD 2 JSR JCC LEA JCC 3 LD% SCC LD% SFT
Ben. I will take over the word, my cpu is a bit (1) better than any 6502, after I change may name to Ben Gates.
Wed Oct 07, 2020 7:24 pm |
Ideas from the 9/18 bit cpu, gives me a simple 20 bit cpu.
The original goal was a 6800 stretched to 18 bits, in the 1974-1977 time frame, with the concept bytes need to 9 bits, so you don't lose addressing space over a word addressed cpu as well as 8 bit opcode limits what operations you can do. Expanding to 20 bits lets me now use a 2901 bit slice.
The PDP 8 has emulated floating point, and a floating point trap is added to my instruction set. This will give me REAL numbers, so I can have a ALGOL type language. Thinking how this would compete with a real PDP8 price wise (memory was $$$ but dropping in price) 20 bits gives me the best value for the money over a 12 or 16 bit cpu. The use of Dual 8" floppy drive with GCR would give me a low cost system, compared to DEC and 25% more over a CP/M system in 1976.
All the changes, lets me use cheap 72 pin .156" card edge connectors to make a simple mother board, compared to bigger projects with more connectors. SDC cards, fake dual floppies drives. Ben.
Sat Oct 17, 2020 6:58 pm |
I have been designing too early ~ 1975. I need to wait untill ~ 1977, just after the APPLE I. By then 16K drams were out, and early FPLA's like the 82S100 as well as the 2901 bit slice and 512x8 proms. Using them I can cut the data path to 4 chips per 4 bit slice (25+glue) and about 25 chips for the control logic. I have gone to a 24 bit computer because that is next standard size for problem solving, rather than a bigger address space. Cards will be on a mother board with S-100 style connector, and about a S-100 card size for 16Kb x 24 bit memory, 48Kb for programs and 32Kb for the OS. The OS is rather small, just that ~ 12K is for Disc and 4Kb stack. 200ns ram lets me have 6.144 MHZ clock. 8" floppies with unknown a GCR will give me 6Kb (1K blocks) per track ~462K per disk. Ben.
Wed Oct 28, 2020 7:50 am |
I am dropping the 16/32 bit CPU as it is too big a project, as well as the 20 bit cpu. The 24 bit cpu wil use core style timing, and all the pins on the S100 bus connector. BDP ( Ben Data Processor ) will have 48Kb of memory, with 768 byte disk blocks on DSSS 8" floppies. 76 tracks with 5 sectors / track GCR. ~ 530K per floppy. 1.5 us Memory cycle. Data Path 5 chips per 4 bit slice+ glue. Control Path 5 22v10's , 74ls161/74ls163 counters +buffers + glue. 19 bit addressing. Opcodes similar to the 9 bit cpu, but 7 registers+ PC. Ben.
Mon Nov 09, 2020 9:31 pm |
Is the 768 size disk block because of the use of 24 bit values? It would seem more natural for disk blocks to be 512 or 1024 bytes.
Wed Nov 11, 2020 7:13 am |
I would guess it's 256 words.
Wed Nov 11, 2020 8:42 am |
I read /write 3 256 x 12 disk block from the SD card, with 0's to pad the 16 bit words. 4 blocks make a disk sector of 768 12 bit bytes. block number = sector << 2. This lets me emulate 8" floppy drive with 76 tracks and two heads. I use a FAT table disk format and 760 sectors per disk. Disc Buffers take up most of 16Kb I have reserved for the OS. I still have wire in the 2 Arduino SD (standard) shields to the FPGA expansion bus. I have lots of cheap chinese SD cards to use as floppies. ~ 520Kb per floppy make a usable development system. $2 floppies and $10 drives VS $20 floppies $1K drives of the 1970's. Ben.
Wed Nov 11, 2020 9:33 pm |
Ah, I see: you're using 12 bit bytes, but necessarily padding into 16 bits to access an SD card. Makes sense!
Thu Nov 12, 2020 9:00 am |
That is an interesting mish-mash of old and new technology. Using the SD cards as floppies to emulate 8” disks, wouldn’t that leave a lot of space on the SD card unused? Could they be partitioned like a hard-disk?
Thu Nov 12, 2020 1:28 pm |
For that era mass media was rather sparce, 8" floppies or the RK05 hard disk @ 1.6MB.(DEC) As the goal here is a small computer, a RK05 is out of place. RK05's were for UNIX. A 8" floppy about $1,200. RK05 about $8,000. A 16 meg SD covers most removable media from that era. Ben.
Thu Nov 12, 2020 6:44 pm |
Revised to add R++ and --R to the instruction layout of the 32 bit cpu with a 2901 ALU. The new BIOS now can load a bootstrap from the serial port, but disk I/O needs to be revised for the new hardware and system jmp tables moved. One meg of address space is reserved, giving me a DOS dual floppy like computer system. Ben.
Tue Dec 22, 2020 2:37 pm |
1MB of address space is a lot for 1976. At 32 bits is this a mini/mainframe equivalent? R++, --R address modes are hard for a compiler to use.
I am tempted to try a come up with a TTL based computer myself. But then I think: someone already did this and for what I'd want it would be a whole cabinet of electronics. Still it might be fun.
Wed Dec 23, 2020 4:51 am |
Quote: R++, --R address modes are hard for a compiler to use. More often called POP and PUSH if R is the Stack pointer. The design more a Mini-computer for the simple reason I have no MMU and Floppy Style Drives. I have been using several 22V10 PALS to simplifiy control decoding, that replace 5 or 6 TTL compnents per PAL. 82S100 FPLA's would have been used in the 70's time frame.
Wed Dec 23, 2020 9:46 am |
Found several bugs in the microcode, mostly cut and paste errors as I revised the Instruction Order Codes. It seems now to be working as 3 chip err card cpu, proving that a 32 bit cpu could be home built design, providing one had the money as it is 4x the cost of 8 bit cpu.Disk Block size is 1Kb blocks so I could run FORTH. No C compiler prevents me from doing a small Unix style OS. Ben.
Tue Dec 29, 2020 9:09 pm |
Users browsing this forum: AhrefsBot, Applebot and 4 guests |
