View unanswered posts | View active topics It is currently Sun May 05, 2024 10:00 am
Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Introduce yourself
Hi all, Warren here. I grew up with Apple ][s and I've mainly done software and network admin in my life. Now I'm discovering the hardware side of things. I somehow managed to build my own 4-bit TTL CPU just by nutting things out myself (https://github.com/DoctorWkt/CSCv2), and I'm still amazed that it works.
Along the way I've learned some Verilog, and now I'm discovering things like ROM latencies and propagation delays that I'd never considered before. Still so much to learn.
Wed May 15, 2019 1:37 am
Hi Warren,
Welcome to the forums. As you can see from a couple of posts before, I am very new to this forums too. I will be interested to know more and learn from your project, as my set of skills regarding hardware are absolutely basic. As a side note, I also attempt to make my own designed TTL CPU, but in my case it will be a very long journey because I have set a relatively large set of project goals, and I have some health issues that prevent me to work on it for as much as I would like. Anyway, delighted to have someone joining the forums with a particular interest in TTL chips!
Joan
Wed May 15, 2019 1:19 pm
joanlluch wrote:
I am very new to this forums too. I will be interested to know more and learn from your project, as my set of skills regarding hardware are absolutely basic. ... Anyway, delighted to have someone joining the forums with a particular interest in TTL chips!
Joan
Joan, if you are also new to hardware and want to build a TTL design, that's exactly where I was a couple of years ago. I'd highly recommend you look at my CSCv2 CPU (and video series).
There's only 12 chips, each one has a specific job and there is very little "glue" logic. The video series builds it step by step, and also explains the concepts behind each section of the build.
Cheers, Warren
Edit: also apologies Joan, I've just read the 7400 TTL CPU thread and I can see you are much more informed than I assumed!!
Thu May 16, 2019 12:47 am
commodorejohn checking in - I'm around on a variety of vintage-computing forums, particularly vcfed.org, 6502.org, and the IRIX Network forums. Decided to check this place out when I ran across the link on 6502.org, as I've had an interest in DIY CPU projects for some time. Still need to do a lot of brushing up on low-level electronics before I'd be ready to put anything together in hardware, but I've been scheming out a couple instruction set/architecture designs to suit my preferences for a while, and I've gotten to the point of starting to implement one in software...but more on that in a dedicated thread...!
"'Legacy code' often differs from its suggested alternative by actually working and scaling." - Bjarne Stroustrup
Wed Oct 23, 2019 2:50 am
Welcome!
Wed Oct 23, 2019 8:38 am
Nice to see a familiar name or two here from other forums!
I'm Alastair, I grew up first with a Commodore64 before moving onto an Amiga, so naturally I have soft-spot for 68K assembly language.
I've tinkered a fair bit with FPGAs over the last few years, learning enough of both Verilog and VHDL to hack on the Minimig FPGA Amiga replica project. I seem to be de-facto maintainer of the Turbo Chameleon 64 port of Minimig, and have ported cores to that platform and others, as well as tinkering with various FPGA-based SoC projects.
I forked the ZPU_small CPU a few years ago, and created a flexible variant of that, ZPUFlex, for use as a support CPU in retro-computing FPGA cores.
I'm now in the process of creating my own experimental CPU core from scratch, which I shall post about elsewhere in due course.
I stumbled across this forum a couple of days ago, having first found the OPC CPU series mentioned on Hackaday - my search for more information led me here. I'm especially interested in OPC5 because of its amazingly small logic footprint - it will fit as a supporting CPU where others won't.
Wed Nov 20, 2019 8:40 pm
Welcome! Nice to hear you find the OPC5 attractive, and that it attracted you here!
Thu Nov 21, 2019 9:27 am
Finally joined here... been out on the 6502.org forum for almost 7 years now.... have been involved with computers since the early 70's. Had a great career... 38 years with IBM, early transfer to Boca Raton in '84 to support the IBM PC Products and was part of IBM Software Group before it was called Software Group. Traveled the world for 25+ years working with large account customers, filled up 2 passports, was involved with lots of early technologies but still played with the 6502 during all of it as a hobby. Now retired after 45 years in the workforce and enjoying my hobbies, family and friends. It's a small world, as many same names out here as with the 6502.org forum... who knew.
Regards, KM
https://github.com/floobydust
Mon Feb 03, 2020 4:33 am
Welcome to the forum !!
Mon Feb 03, 2020 10:47 am
Hi Everyone,
Interesting small forum you have here; the talk of 6800's etc takes me back to my youth ...
I've been fascinated by electronics since my childhood and first worked with embedded in 1976 while a electronics technician as a busy electronics company. Back then I learnt all about building embedded gear while prototyping an iron ore flow gauge which used radioisotopes to measure the flow rate of ore falling off a vibrating feeder in Port Headland, Western Australia. The CPU was a National PACE 16 bit, 40 pin unit in a ceramic package and cost about $275 I was told.
Later I fell in love with the 6800 ISA on a HC11 and built projects using an old second hand SWTP development machine (I bought at a disposal auction for $25 AUD) with two 8" hard sectored floppy disks, a editor and assembler and eprom burner. That love still continues to this day, tho I have no desire to revisit the hardware.
After a couple of years using a Intel 8085 SDK and programming in machine code, the SWTP box seemed like I had died and gone to Heaven, even if it was plagued by horribly unreliable Molex connectors.
Add all the usual suspects, 6502, CDP1802, Z80, 6802, 6805, PIC, 8051, MSP430 etc and we arrive at the present where I use Forth on Cortex-M, mainly STM32F051 and maintain what is basically my blog as I progressed learning Forth starting around 2014.
I figured that as there was so little Forth online these days I might as well put my Mecrisp-Stellaris blog online, maybe the information may prove useful to others starting Forth. https://mecrisp-stellaris-folkdoc.sourc ... index.html
I also produce XSLT recipes for transforming SVD files to Forth Memory Maps and Bitfields, and Assembly equate files for Cortex-M (mostly STM chips), which automatically generates stuff like this:
$40021000 constant RCC \ Reset and clock control
RCC $0 + constant RCC_CR (  )  \ Clock control register
RCC $4 + constant RCC_CFGR (  )  \ Clock configuration register  RCC_CFGR
RCC $8 + constant RCC_CIR (  )  \ Clock interrupt register  RCC_CIR
RCC $C + constant RCC_APB2RSTR ( read-write )  \ APB2 peripheral reset register  RCC_APB2RSTR
and this
\ RCC_CR (multiple-access)  Reset:0x00000083
: RCC_CR_HSION ( -- x addr ) 0 bit RCC_CR ; \ RCC_CR_HSION, Internal High Speed clock  enable
: RCC_CR_HSIRDY? ( -- 1|0 ) 1 bit RCC_CR bit@ ; \ RCC_CR_HSIRDY, Internal High Speed clock ready  flag
: RCC_CR_HSITRIM ( %bbbbb -- x addr ) 3 lshift RCC_CR ; \ RCC_CR_HSITRIM, Internal High Speed clock  trimming
: RCC_CR_HSICAL ( %bbbbbbbb -- x addr ) 8 lshift RCC_CR ; \ RCC_CR_HSICAL, Internal High Speed clock  Calibration
: RCC_CR_HSEON ( -- x addr ) 16 bit RCC_CR ; \ RCC_CR_HSEON, External High Speed clock  enable
Nowadays I'm retired and spend my time making projects, gear and simple software. Everything I publish is either GPL'd or MIT depending on my obligations.
Mon Mar 08, 2021 8:01 am
Welcome, Terry, great to hear your story!
Mon Mar 08, 2021 8:12 am
Welcome!
Mon Mar 08, 2021 4:15 pm
Hi, My name is Michael and I am new to this forum. I've spent alot of time over at the Vintage Computer Forum (vcfed.org) with the same user name. I entered computing in 1975 using paper punch cards running Fortran at the Michigan Terminal System (MTS) in Ann Arbor, Michigan USA. About 10 years ago I launched a kit to build a nearly-identical clone of the IBM 5150 PC Motherboard, which I still offer on my side hustle website MTM Scientific, Inc.
For the last couple of years I have been designing and building a 12 bit computer which uses a hard-wired controller with 74181 ALUs to do the logic and math. I am in the process of writing a threaded interpretive language for the project. I call the computer I am building the TTL-Retro.
I found this forum pretty much by accident, but I see you all are interested in many of the same topics. I really appreciate the help I have gotten in the past from other people! Here is a link to my latest project.
http://www.mtmscientific.com/stack.html
My avatar is Mr. Peabody, a cartoon character scientist. He is the inventor of the WABAC machine ("Wayback"), a device for time travel, which seems appropriate for vintage computing enthusiasts.
Mon Dec 20, 2021 11:02 am
Welcome Michael, great project!
Mon Dec 20, 2021 2:04 pm
My full introduction is on the 6502 Forum.
I write awful 6502 assembly and even worse 68000 assembly. I am a very reluctant user of Raspberry Pi and Arduino. (Both can be improved by dumping most of the default software.) I've had mad ideas for processor architectures for far too long but I now concentrate on 6502 extensions. Although, much of my work is generic and not specific to 6502. This includes:
Beep, Beep! I'm a sheep!
Tue Mar 22, 2022 1:14 pm
