Last visit was: Wed May 22, 2024 1:16 pm
It is currently Wed May 22, 2024 1:16 pm
 [ 9 posts ]
 b16 - 16 bit CPU
I found some old schematics for this project that I mentioned in another thread. I took the time to redraw them in a CAD program many years ago, before 1999. A bit of nostalgia. There may be a schematic missing; I thought there were five but I could only find four.
ALU
EXEC
OPFETCH - Opcode Fetch
SR - Status Register
Tue Jan 10, 2023 4:16 pm WWW
Some more info
Address Modes Implemented in Minimal Processor
opmode reg mneumonic description
000 rrr r ; register direct
001 rrr [r] ; register indirect
010 rrr [--r] ; register indirect pre decrement
011 rrr [r++] ; register indirect post increment
011 111 # ; immediate
Register Summary
Programmers Registers
bit pat. mneumonic
rrr
000 r0
001 r1
010 r2
011 r3
100 r4
101 fp frame pointer
110 sp stack pointer
111 ip instruction pointer
sr status (flag) register
status register bits
54321098 76543210
xxTxIIII xxxxNVZC-carry
| |||| ||+--zero
| |||| |+---overflow
| |||| +----negative
| ++++----------interrupt level
+---------------trace
Opcode Formats
Dual operand oooo sss SSS ddd DDD
Single operand 0000 oooo xx ddd DDD
Program control 0001 cccc xx ddd DDD
oooo - opcode
cccc - condition
sss - source addressing mode
ddd - destination addressing mode
SSS - source register
DDD - destination register
xx - don't care (reserved)
Dual operand instructions
oooo
0000 { single operand/ miscellaneous }
0001 { flow control }
0010 add
0011 addc
0100 sub
0101 subb
0110 cmp
0111 cmpb
1000 and
1001 or
1010 xor
1011 { set cccc } (maximal)
1100
1101 move
1110 test
1111 reserved
Single Operand Instructions
Shift/Rotate
0000 0ooo xx ddd DDD
ooo
|+-- 0 = normal, 1 = circular
+--- 0 = shift left, 1 = shift right
000 { miscellaneous instructions }
001 lsl,asl - arithmetic shift left or logical shift left
010 rol - circular shift (rotate) left
011 rolc - circular shift left through carry
100 asr - arithmetic shift right
101 lsr - logical shift right
110 ror - circular shift (rotate) right
111 rorc - circular shift right through carry
Negate/Increment/Decrement/Clear
0000 1ooo xx ddd DDD
ooo
000 not - ones complement
001 neg - twos complement (unimplemented)
010 inc
011 dec
100 clr
101 pea - push effective address (maximal)
110
111
Program Control Instructions
cccc flag combination
0000 cs/lo c
0001 cc/hs !c ; these are simple tests based on individual
0010 vs v
0011 vc !v ; condition code bits being set or clear
0100 eq/z z
0101 ne/nz !z
0110 mi n
0111 pl !n
1000 to 1111 0 ; always false
Tue Jan 10, 2023 4:34 pm WWW
Hi, Thanks for posting these schematics. Do you recall what was done for clocking...? It might be there somewhere, but I'm not seeing it. Also, do you have a photo of the project? Thanks! Michael
Tue Jan 10, 2023 7:43 pm WWW
It's really nice to see a hobby computer using SRAM for a register file. And hardware instruction decoding.
Took me a while to figure out why the carry out from the ALU was so busy, rotate instructions, duh. Also I've thought about using that trick of using an extra 181 to generate an overflow flag via a guard bit. If I recall correctly the extra XOR gate wasn't needed*.
*I remember now why the XOR wasn't needed, I was detecting signed carry not actual overflow.
Tue Jan 10, 2023 10:45 pm
No photo of the project. It never made it off the drawing board. The clock may have been on another schematic which I cannot find. I believe the clock was single phase canned oscillator possibly with a divider. There is a note on the schematic that all FF's are 74ls273's with a common clock and reset. There is a signal labelled 'CLK' which feeds a chip or two. Most of the synchronous logic uses the '273 ff. I have a bunch of '273s I collected for the project but did not end up using.
I wish the '181 had an overflow output, and a zero result output. Overflow can be calculated looking at the opcode, and high order bits of operands and the result. But it is a few more chips.
Wed Jan 11, 2023 12:05 am WWW
The 74181 seems to better designed for negative logic.
I remember having a design where I used 3 bits of data, for the 4 bit alu chip
Bit #4 input was always set to 0,1 so carry out would be correct. This had 2 9 bit alu cards.
Wed Jan 11, 2023 7:31 pm
I think it was designed to go along with buffers / multiplexors that used inverting logic to improve performance.
But the '181 has ripple carry input and output. Was it faster to use the input bit?
18 bit CPU?
Thu Jan 12, 2023 12:17 am WWW
18 bit CPU?
It was a a expanded 6800 like cpu, with a PC,AC,SP,IX. I never could get a instruction set I liked to fit into a 9 bit opcode.
Thu Jan 12, 2023 4:00 pm
Thinking of implementing something similar to the b16, but using higher scale integration.
As a result of drooling over am2901 chips but not really wanting to assemble a system using real chips, I created a Verilog code version of the am2901 with a couple of twists. More registers, up to 64, and better I/O for use in an FPGA. It also supports 3R access, 2 source 1 target, to the register file instead of 2R. Also worked on a 12-bit version of the am29112 microprogram sequencer but it is not completely coded yet.
Needs a second index register. Handy when copying source to destination. 6800 has two accumulators too.
Sat Jan 14, 2023 4:45 am WWW
 [ 9 posts ]
Users browsing this forum: Bing [Bot] and 0 guests
