Last visit was: Tue May 28, 2024 7:06 am
It is currently Tue May 28, 2024 7:06 am
 [ 9 posts ]
 The next design - a octal 20 bit cpu
Going back to more 1968 style computer. Word addressing. Accumulator design rather a register to register design.
Subroutine calls on even bountry, and single word 19 bit addressing. This way I can use CALL theading for threaded code. 8 registers including
the PC.
More inspection of the new oder code, conficts with some other decoding,thus I am back to two word calls and the orignal order code.
Thu Apr 04, 2024 7:32 am
Moving clock generation to the ALU card as well. The ALU gets to use the master clock first.
Moving up to 1984, with a 1.5 uS memory cycle time -- ram . A 1977 version 1.8 uS core or ram.
PS: Looking at the chips I have, I may tweek it for 150 ns ram, and add a wait state for IO.
Thu Apr 11, 2024 6:09 am
Gone back to a hex format.
The schematics are roughed out, but no layout is done yet. This will be a emulated design with stubbed IO
routines, for the next few months. Getting close to a "hello world" type test program.
PS: Last minute addition - signed bytes (10 bits).
Sun Apr 28, 2024 5:42 am
Changed from Big Endian to Little Endian, so I can read and write disk blocks on the PC and port over to Compact Flash
later. Disk IO would be a modified IBM patter drive from 203 tracks to 225 tracks. 4Kb per track like the PDP-8, 10 bit bytes, GCR. Some sort of strange fat system.
Now I need a name for this beast, and time for software.
Mon Apr 29, 2024 5:55 am
I have the emulator printing "Hello world".
I got dosbox-x running and cross compiling small c version 1.2.
I need to write a simple FAT file system ( 8 inch floppy 10 bits/byte GCR single sided)
and the small C libs. System setup 462 Kb per floppy, two floppies per system. 48K ram + ROM BIOS
+ 2 serial at 1200 baud?
about 1976.
Sat May 11, 2024 8:47 pm
I have improved the design, since I could only find 18 bits, in the bit bucket.
This is a serial design, 3 bit nibble. The only rare parts are a 13 mhz osc,
CY7C122 (256 x 4 ) 25 ns ram and a 74H74.
2.5 uS memory cycle time.
Operate 2.5 uS
auto 5.0 uS
index 7.5 uS
The emulator will print "hello world", but more testing needs to be done.
Sun May 19, 2024 10:32 pm
oldben wrote:
3 bit nibble
I've never heard of a n[yi]bble being anything other than 4 bits.
Fri May 24, 2024 2:05 pm
256 wrote:
oldben wrote:
3 bit nibble
Next you will tell me a byte is 8 bits.
Other notes.
The design of the serial 18 bit cpu is on hold, just too slow, and floating point
is still too small.
The order code of my 20 cpu will be revised from what I learned on the 18
bit machine, with 31,1,8 float.
PS: Evil laugh, bytes are now 10 bits, and nibbles half that.
Sat May 25, 2024 5:17 pm
(Welcome, 256! It does seem unconventional for a nibble not to be 4 bits, but as Ben notes, sometimes a byte isn't 8 bits, certainly on this forum where any CPU architecture decision is open for experimentation...)
Mon May 27, 2024 5:36 am
 [ 9 posts ]
Users browsing this forum: AhrefsBot and 3 guests
