Last visit was: Tue Nov 04, 2025 2:51 am
            It is currently Tue Nov 04, 2025 2:51 am
						I have compacted the 20 bit cpu, to 16 bits. MMU's are a PTA, but you need split code and data, user and system. Code:     draft  JUNE 16 2024
  16 BIT segmented CPU. 64Kb user data space, stack 64Kb user program space 64Kb sys  data space, sys stack 64kb sys  program space
  Cpu: The cpu has a Carry flag and 7 general purpose registers and PC/Z special registers.  ADX is addition that does not affect the carry flag. ADD/SUB/CAD and shifts affect the carry.
  Adressing modes are register indirect:       INDEXED   r + #        AUTO (A)  -r r% r+
  opcode postfix  .   byte                 ,   unsigned byte                 %   register
  Instruction format:  +-+---+---+---+---+---+  |Q|OOO|AAA|C+#|###|###|  0 # QUICK 7 BITS  +-+---+---+---+---+---+     +-+---+---+---+---+---+  |Q|OOO|AAA|CMM|XXX|?RR|  1  MEMORY REF  +-+---+---+---+---+---+      OPCODE TABLES:      REGISTER
            AX  RR        MODE       Q = 0                         CTL,QUICK #       Q = 1         0    A   DIRECT    JMP/JSR,SCC/JCC         1    B   -R        LEA/HLT,REG OP,SHIFT      2    C   R%        OP BYTE ? SIGNED,UNSIGNED      3    D   R+        OP WORD ? USER SPACE,SYS SPACE      4    S         5    X                  6    Y                   7    Z/P        MEMORY REF
       OOO  OP   C            0    ST/STP      (EFA) = AAA                       (EFA) = AAA PROGRAM SPACE                  1    ADD/ADC  AAA  = AAA +  (EFA) + ?0,C      2    SUB/SBC  AAA  = AAA + ~(EFA) + ?1,C      3    CAD/CAC  AAA  = ~AAA + (EFA) + ?1,C      4    LD/      AAA  = (EFA)             LDP    AAA  = (EFA) PROGRAM SPACE          5    OR/      AAA  = AAA | (EFA)              EQV   AAA  = AAA XNOR (EFA)      6    AND      AAA  = AAA &  (EFA)              XOR   AAA  = AAA ^  (EFA)      7    ADX      AAA  = AAA +  (EFA)              ATX   AAA  = AAA +  (EFA)<<1
       micro code 256 x 24      87 654 321      RA:SMM:CCC      01:1PP:CCC PANEL      00:100:CCC DI-EI/QUICK #      1a:smm:CCC NORMAL DECODE
     This will be virtual machine for now, but a real cpu seems possible, once I get the micro code defined. One option is to have the carry flag select byte high,low and make atx ac = ac + (efa)>>1 setting carry. This will break C, how ever, but gives you 2x the data/code space.
			| Sun Jun 16, 2024 8:19 am |
						Code: draft  JUNE 18 2024
  16 BIT segmented CPU. version #1 no segments
  Adressing modes are register indirect:       INDEXED   r + #        AUTO (A)  -r r% r+       CPU 16   +----+----+----+----+   |OOOO:1AAA|?XXX:MMRR| MEMORY   +----+----+----+----+   |OOOO:0AAA|+###|####| BYTE #/NOP   +----+----+----+----+   opcode postfix  .   byte                 ,   unsigned byte                 %   register
  Instruction format:         ST      OP 0   A   LEA     OP REG             1   B   JSR -R  JCC -R     2   C   JSR R%  JCC R%  3   D   JSR R+  JCC R+ 4   S   -       SFT 5   X   CTL     SCC #-1 6   Y   CTL     - 7   Z/# CTL     SCC # 1 8       ST R)   OP R)   WORD 9       ST -R   OP -R   WORD A       ST R%   OP R%   WORD B       ST R+   OP R+   WORD    C       ST R)   OP R)   BYTE ?=UNSIGNED  D       ST -R   OP -R   BYTE ?=UNSIGNED E       ST R%   OP R%   BYTE ?=UNSIGNED F       ST R+   OP R+   BYTE ?=UNSIGNED QUICK   NOP     OP #    -128+127
       MEMORY REF
       micro code 256 x 24      87 654 321      RS:MMA:CCC      01:PP0:CCC PANEL      01:001:CCC NOP,TRAP/QUICK #      1S:MMA:CCC NORMAL DECODE
   Small C seems to compile. Off to find a bigger C
			| Wed Jun 19, 2024 4:32 am |
  A milestone! Congratulations!
			| Wed Jun 19, 2024 7:08 am |
						 I now have the simple segmented version working, and small c outputting code (64kb) and (64kb) data segment. Planned software: Fat table disk format,sub directories,single user. 1977 ish hardware  time frame. 16Kb for the OS and 32Kb for user space. Next month to work on the hardware version.
			| Mon Jul 01, 2024 4:59 am |
						 Picked up a 68000 SBC, and plan to emulate a 32 bit cpu with18 bit addressing.
			| Fri Jul 12, 2024 8:01 am |
						 Which SBC?
			| Fri Jul 12, 2024 4:49 pm |
						robfinch wrote: Which SBC? The one now sent by Snail Mail.   https://www.tindie.com/products/rosco/r ... -full-kit/(You save by having no case, or floppies)
			| Fri Jul 12, 2024 6:05 pm |
						Code: draft  JULY 12 2024
  32 BIT segmented CPU. version #1 no segments 512 Kb address space.
  Cpu: The cpu has a Carry flag and 8 general purpose registers and PC/Z special registers.  (A,B,C,D) ADD/SUB/CAD and shifts affect the carry.
  Adressing modes are register indirect:       INDEXED   r + # SHORT        DIRECT    # ADR       AUTO      r% r+       PSH       -r
     CPU 32   +----+----+----+----+   |OOOO:UAAA|JSSI:xXXX| MEMORY   +----+----+----+----+
    opcode postfix  .   byte                 ,   unsigned                 %   register index     0xxx r%     1xxx r+     0xxx r] ####     1nnn Z  ####               ±nnn QK     ±nnn BR ####
  Instruction format:         ST      OP      JMP 0   A   CTL     QUICK   SCC             1   B   LEA     REG     BCC 2   C   B R+    B R+    SFT #X 3   D/# B R]    B R]    BSR 4   W   W R+    W R+    JMP R+ 4   X   W R]    W R]    JMP R] 4   Y   L R+    L R+    JSR R+ 4   S   L R]    W R]    JSR R]
       OOO  OP   C            0    ST/PSH                1    ADD/ADC  AAA  = AAA +  (EFA) + ?0,C      2    SUB/SBC  AAA  = AAA + ~(EFA) + ?1,C      3    CAD/CAC  AAA  = ~AAA + (EFA) + ?1,C      4    LD       AAA  = (EFA)      5    OR       AAA  = AAA |  (EFA)                  6    AND      AAA  = AAA &  (EFA)      7    XOR      AAA  = AAA ^  (EFA)
			| Fri Jul 12, 2024 9:22 pm |
						Code: draft  JULY 13 2024
  32 BIT segmented CPU. version #2 still no segments, 512Kb
  Cpu: Since this is planed to be emulated on 68000 endian is what ever the 68000 is. A quick and dirty C emulator is planned. The cpu has a Carry flag and 8 general purpose registers and PC/Z special registers.   ADD/SUB/CAD and shifts affect the carry.
  Adressing modes are register indirect:       INDEXED   r + # SHORT        DIRECT    # ADR       AUTO      -r r+
     CPU 32   +----+----+----+----+   |OOOO:-AAA|JSSI:IXXX| MEMORY   +----+----+----+----+   - reserved  opcode postfix      .R   REG     .Q   QUICK     .B   byte     .W   word     .L   long
      II     0   R+ or #     1   -R     2   Z]     3   R]           SS     0   OTHER     1   .B     2   .W     3   .L     J   JUMP     0   OPS     1   SHIFT and CONTROL
  index              low     0xxx r+  XXXX high     1xxx -r  XXXX     1xxx r]  XXXX ####     0nnn Z   XXX# ####               ±nnn QK  XXX#     ±nnn BR  XXX# ####
       OOO  OP   C            0    ST                1    ADD/ADC  AAA  = AAA +  (EFA) + ?0,C      2    SUB/SBC  AAA  = AAA + ~(EFA) + ?1,C      3    CAD/CAC  AAA  = ~AAA + (EFA) + ?1,C      4    LD       AAA  = (EFA)      5    OR       AAA  = AAA |  (EFA)                  6    AND      AAA  = AAA &  (EFA)      7    XOR      AAA  = AAA ^  (EFA)
			| Sat Jul 13, 2024 10:42 pm |
		Users browsing this forum: AhrefsBot, Chrome-12x-bots, chrome-9x-bots and 0 guests  |
