Last visit was: Mon Sep 15, 2025 12:19 pm
It is currently Mon Sep 15, 2025 12:19 pm
 [ 9 posts ]
 Ben's 16 bit computer
I have compacted the 20 bit cpu, to 16 bits.
MMU's are a PTA, but you need split code and data, user and system.
    draft  JUNE 16 2024
16 BIT segmented CPU.
64Kb user data space, stack
64Kb user program space
64Kb sys  data space, sys stack
64kb sys  program space
Cpu:
The cpu has a Carry flag and 7 general purpose registers and PC/Z
special registers.  ADX is addition that does not affect the carry flag.
ADD/SUB/CAD and shifts affect the carry.
Adressing modes are register indirect:
      INDEXED   r + #
      AUTO (A)  -r r% r+
opcode postfix  .   byte
                ,   unsigned byte
                %   register
Instruction format:
 |Q|OOO|AAA|C+#|###|###|  0 # QUICK 7 BITS
 |Q|OOO|AAA|CMM|XXX|?RR|  1  MEMORY REF
OPCODE TABLES:
     REGISTER
          AX  RR        MODE
     Q = 0
                        CTL,QUICK #
     Q = 1
     0    A   DIRECT    JMP/JSR,SCC/JCC
     1    B   -R        LEA/HLT,REG OP,SHIFT
     2    C   R%        OP BYTE ? SIGNED,UNSIGNED
     3    D   R+        OP WORD ? USER SPACE,SYS SPACE
     4    S
     5    X
     6    Y
     7    Z/P
     MEMORY REF
     OOO  OP   C
     0    ST/STP      (EFA) = AAA
                      (EFA) = AAA PROGRAM SPACE
     1    ADD/ADC  AAA  = AAA +  (EFA) + ?0,C
     2    SUB/SBC  AAA  = AAA + ~(EFA) + ?1,C
     3    CAD/CAC  AAA  = ~AAA + (EFA) + ?1,C
     4    LD/      AAA  = (EFA)
            LDP    AAA  = (EFA) PROGRAM SPACE
     5    OR/      AAA  = AAA | (EFA)
             EQV   AAA  = AAA XNOR (EFA)
     6    AND      AAA  = AAA &  (EFA)
             XOR   AAA  = AAA ^  (EFA)
     7    ADX      AAA  = AAA +  (EFA)
             ATX   AAA  = AAA +  (EFA)<<1
     micro code 256 x 24
     87 654 321
     RA:SMM:CCC
     01:1PP:CCC PANEL
     00:100:CCC DI-EI/QUICK #
     1a:smm:CCC NORMAL DECODE
This will be virtual machine for now, but a real cpu seems possible, once I get the micro code
defined.
One option is to have the carry flag select byte high,low
and make atx ac = ac + (efa)>>1 setting carry. This will break C,
how ever, but gives you 2x the data/code space.
Sun Jun 16, 2024 8:19 am
draft  JUNE 18 2024
version #1 no segments
Cpu:
      INDEXED   r + #
      AUTO (A)  -r r% r+
   CPU 16
  |OOOO:1AAA|?XXX:MMRR| MEMORY
  |OOOO:0AAA|+###|####| BYTE #/NOP
                ,   unsigned byte
                %   register
Instruction format:
        ST      OP
0   A   LEA     OP REG
1   B   JSR -R  JCC -R
2   C   JSR R%  JCC R%
3   D   JSR R+  JCC R+
4   S   -       SFT
5   X   CTL     SCC #-1
6   Y   CTL     -
7   Z/# CTL     SCC # 1
8       ST R)   OP R)   WORD
9       ST -R   OP -R   WORD
A       ST R%   OP R%   WORD
B       ST R+   OP R+   WORD
C       ST R)   OP R)   BYTE ?=UNSIGNED
D       ST -R   OP -R   BYTE ?=UNSIGNED
E       ST R%   OP R%   BYTE ?=UNSIGNED
F       ST R+   OP R+   BYTE ?=UNSIGNED
QUICK   NOP     OP #    -128+127
     MEMORY REF
     OOO  OP   C
     4    LD/      AAA  = (EFA)
     micro code 256 x 24
     87 654 321
     RS:MMA:CCC
     01:PP0:CCC PANEL
     01:001:CCC NOP,TRAP/QUICK #
     1S:MMA:CCC NORMAL DECODE
Small C seems to compile. Off to find a bigger C
Wed Jun 19, 2024 4:32 am
A milestone! Congratulations!
Wed Jun 19, 2024 7:08 am
I now have the simple segmented version working, and small c outputting code (64kb) and (64kb) data segment.
Planned software: Fat table disk format,sub directories,single user. 1977 ish hardware time frame. 16Kb for the OS and 32Kb for user space.
Next month to work on the hardware version.
Mon Jul 01, 2024 4:59 am
Picked up a 68000 SBC, and plan to emulate a 32 bit cpu with18 bit addressing.
Fri Jul 12, 2024 8:01 am
Which SBC?
Fri Jul 12, 2024 4:49 pm WWW
robfinch wrote:
Which SBC?
The one now sent by Snail Mail. :)
https://www.tindie.com/products/rosco/r ... -full-kit/
(You save by having no case, or floppies)
Fri Jul 12, 2024 6:05 pm
draft  JULY 12 2024
32 BIT segmented CPU.
version #1 no segments 512 Kb address space.
Cpu:
The cpu has a Carry flag and 8 general purpose registers and PC/Z
special registers.  (A,B,C,D) ADD/SUB/CAD and shifts affect the carry.
      INDEXED   r + # SHORT
      DIRECT    # ADR
      AUTO      r% r+
      PSH       -r
   CPU 32
  |OOOO:UAAA|JSSI:xXXX| MEMORY
                ,   unsigned
                %   register
index
    0xxx r%
    1xxx r+
    0xxx r] ####
    1nnn Z  ####
    ±nnn QK
    ±nnn BR ####
Instruction format:
        ST      OP      JMP
0   A   CTL     QUICK   SCC
1   B   LEA     REG     BCC
2   C   B R+    B R+    SFT #X
3   D/# B R]    B R]    BSR
4   W   W R+    W R+    JMP R+
4   X   W R]    W R]    JMP R]
4   Y   L R+    L R+    JSR R+
4   S   L R]    W R]    JSR R]
     OOO  OP   C
     0    ST/PSH
     4    LD       AAA  = (EFA)
     5    OR       AAA  = AAA |  (EFA)
     7    XOR      AAA  = AAA ^  (EFA)
Fri Jul 12, 2024 9:22 pm
draft  JULY 13 2024
version #2 still no segments, 512Kb
Cpu:
Since this is planed to be emulated on 68000
endian is what ever the 68000 is.
A quick and dirty C emulator is planned.
special registers.
      INDEXED   r + # SHORT
      DIRECT    # ADR
      AUTO      -r r+
   CPU 32
  |OOOO:-AAA|JSSI:IXXX| MEMORY
  - reserved
opcode postfix
    .R   REG
    .Q   QUICK
    .B   byte
    .W   word
    .L   long
    II
    0   R+ or #
    1   -R
    2   Z]
    3   R]
    SS
    0   OTHER
    1   .B
    2   .W
    3   .L
    J   JUMP
    0   OPS
    1   SHIFT and CONTROL
index
             low
    0xxx r+  XXXX high
    1xxx -r  XXXX
    1xxx r]  XXXX ####
    0nnn Z   XXX# ####
    ±nnn QK  XXX#
    ±nnn BR  XXX# ####
Instruction format:
        ST      OP      JMP
0   A   CTL     QUICK   SCC
1   B   LEA     REG     BCC
3   D/# B R]    B R]    BSR
     OOO  OP   C
     0    ST
     4    LD       AAA  = (EFA)
Sat Jul 13, 2024 10:42 pm
 [ 9 posts ]
Users browsing this forum: AhrefsBot and 1 guest
