Last visit was: Mon Sep 15, 2025 12:18 pm
It is currently Mon Sep 15, 2025 12:18 pm
I have compacted the 20 bit cpu, to 16 bits. MMU's are a PTA, but you need split code and data, user and system. Code: draft JUNE 16 2024
16 BIT segmented CPU. 64Kb user data space, stack 64Kb user program space 64Kb sys data space, sys stack 64kb sys program space
Cpu: The cpu has a Carry flag and 7 general purpose registers and PC/Z special registers. ADX is addition that does not affect the carry flag. ADD/SUB/CAD and shifts affect the carry.
Adressing modes are register indirect: INDEXED r + # AUTO (A) -r r% r+
opcode postfix . byte , unsigned byte % register
Instruction format: +-+---+---+---+---+---+ |Q|OOO|AAA|C+#|###|###| 0 # QUICK 7 BITS +-+---+---+---+---+---+ +-+---+---+---+---+---+ |Q|OOO|AAA|CMM|XXX|?RR| 1 MEMORY REF +-+---+---+---+---+---+ OPCODE TABLES: REGISTER
AX RR MODE Q = 0 CTL,QUICK # Q = 1 0 A DIRECT JMP/JSR,SCC/JCC 1 B -R LEA/HLT,REG OP,SHIFT 2 C R% OP BYTE ? SIGNED,UNSIGNED 3 D R+ OP WORD ? USER SPACE,SYS SPACE 4 S 5 X 6 Y 7 Z/P MEMORY REF
OOO OP C 0 ST/STP (EFA) = AAA (EFA) = AAA PROGRAM SPACE 1 ADD/ADC AAA = AAA + (EFA) + ?0,C 2 SUB/SBC AAA = AAA + ~(EFA) + ?1,C 3 CAD/CAC AAA = ~AAA + (EFA) + ?1,C 4 LD/ AAA = (EFA) LDP AAA = (EFA) PROGRAM SPACE 5 OR/ AAA = AAA | (EFA) EQV AAA = AAA XNOR (EFA) 6 AND AAA = AAA & (EFA) XOR AAA = AAA ^ (EFA) 7 ADX AAA = AAA + (EFA) ATX AAA = AAA + (EFA)<<1
micro code 256 x 24 87 654 321 RA:SMM:CCC 01:1PP:CCC PANEL 00:100:CCC DI-EI/QUICK # 1a:smm:CCC NORMAL DECODE
This will be virtual machine for now, but a real cpu seems possible, once I get the micro code defined. One option is to have the carry flag select byte high,low and make atx ac = ac + (efa)>>1 setting carry. This will break C, how ever, but gives you 2x the data/code space.
Sun Jun 16, 2024 8:19 am |
Code: draft JUNE 18 2024
16 BIT segmented CPU. version #1 no segments
Adressing modes are register indirect: INDEXED r + # AUTO (A) -r r% r+ CPU 16 +----+----+----+----+ |OOOO:1AAA|?XXX:MMRR| MEMORY +----+----+----+----+ |OOOO:0AAA|+###|####| BYTE #/NOP +----+----+----+----+ opcode postfix . byte , unsigned byte % register
Instruction format: ST OP 0 A LEA OP REG 1 B JSR -R JCC -R 2 C JSR R% JCC R% 3 D JSR R+ JCC R+ 4 S - SFT 5 X CTL SCC #-1 6 Y CTL - 7 Z/# CTL SCC # 1 8 ST R) OP R) WORD 9 ST -R OP -R WORD A ST R% OP R% WORD B ST R+ OP R+ WORD C ST R) OP R) BYTE ?=UNSIGNED D ST -R OP -R BYTE ?=UNSIGNED E ST R% OP R% BYTE ?=UNSIGNED F ST R+ OP R+ BYTE ?=UNSIGNED QUICK NOP OP # -128+127
MEMORY REF
micro code 256 x 24 87 654 321 RS:MMA:CCC 01:PP0:CCC PANEL 01:001:CCC NOP,TRAP/QUICK # 1S:MMA:CCC NORMAL DECODE
Small C seems to compile. Off to find a bigger C
Wed Jun 19, 2024 4:32 am |
A milestone! Congratulations!
Wed Jun 19, 2024 7:08 am |
I now have the simple segmented version working, and small c outputting code (64kb) and (64kb) data segment. Planned software: Fat table disk format,sub directories,single user. 1977 ish hardware time frame. 16Kb for the OS and 32Kb for user space. Next month to work on the hardware version.
Mon Jul 01, 2024 4:59 am |
Picked up a 68000 SBC, and plan to emulate a 32 bit cpu with18 bit addressing.
Fri Jul 12, 2024 8:01 am |
Which SBC?
Fri Jul 12, 2024 4:49 pm |
robfinch wrote: Which SBC? The one now sent by Snail Mail. https://www.tindie.com/products/rosco/r ... -full-kit/(You save by having no case, or floppies)
Fri Jul 12, 2024 6:05 pm |
Code: draft JULY 12 2024
32 BIT segmented CPU. version #1 no segments 512 Kb address space.
Cpu: The cpu has a Carry flag and 8 general purpose registers and PC/Z special registers. (A,B,C,D) ADD/SUB/CAD and shifts affect the carry.
Adressing modes are register indirect: INDEXED r + # SHORT DIRECT # ADR AUTO r% r+ PSH -r
CPU 32 +----+----+----+----+ |OOOO:UAAA|JSSI:xXXX| MEMORY +----+----+----+----+
opcode postfix . byte , unsigned % register index 0xxx r% 1xxx r+ 0xxx r] #### 1nnn Z #### ±nnn QK ±nnn BR ####
Instruction format: ST OP JMP 0 A CTL QUICK SCC 1 B LEA REG BCC 2 C B R+ B R+ SFT #X 3 D/# B R] B R] BSR 4 W W R+ W R+ JMP R+ 4 X W R] W R] JMP R] 4 Y L R+ L R+ JSR R+ 4 S L R] W R] JSR R]
OOO OP C 0 ST/PSH 1 ADD/ADC AAA = AAA + (EFA) + ?0,C 2 SUB/SBC AAA = AAA + ~(EFA) + ?1,C 3 CAD/CAC AAA = ~AAA + (EFA) + ?1,C 4 LD AAA = (EFA) 5 OR AAA = AAA | (EFA) 6 AND AAA = AAA & (EFA) 7 XOR AAA = AAA ^ (EFA)
Fri Jul 12, 2024 9:22 pm |
Code: draft JULY 13 2024
32 BIT segmented CPU. version #2 still no segments, 512Kb
Cpu: Since this is planed to be emulated on 68000 endian is what ever the 68000 is. A quick and dirty C emulator is planned. The cpu has a Carry flag and 8 general purpose registers and PC/Z special registers. ADD/SUB/CAD and shifts affect the carry.
Adressing modes are register indirect: INDEXED r + # SHORT DIRECT # ADR AUTO -r r+
CPU 32 +----+----+----+----+ |OOOO:-AAA|JSSI:IXXX| MEMORY +----+----+----+----+ - reserved opcode postfix .R REG .Q QUICK .B byte .W word .L long
II 0 R+ or # 1 -R 2 Z] 3 R] SS 0 OTHER 1 .B 2 .W 3 .L J JUMP 0 OPS 1 SHIFT and CONTROL
index low 0xxx r+ XXXX high 1xxx -r XXXX 1xxx r] XXXX #### 0nnn Z XXX# #### ±nnn QK XXX# ±nnn BR XXX# ####
OOO OP C 0 ST 1 ADD/ADC AAA = AAA + (EFA) + ?0,C 2 SUB/SBC AAA = AAA + ~(EFA) + ?1,C 3 CAD/CAC AAA = ~AAA + (EFA) + ?1,C 4 LD AAA = (EFA) 5 OR AAA = AAA | (EFA) 6 AND AAA = AAA & (EFA) 7 XOR AAA = AAA ^ (EFA)
Sat Jul 13, 2024 10:42 pm |
Users browsing this forum: AhrefsBot, SemrushBot and 1 guest |
